09-05-2016, 07:41 PM | #1 |
Rep 184
Proper E85 mix Ratio
Hi after doing some research on the forum I haven't quite found the answer i am looking for.
What is the proper ratio of E85 i can put in my M3 with JB4 on map 2? I currently use 93 octane fuel but would like to add e85 to up the ante. I do have other mods done to the car as well. Also can i run full e85 or 60/40 (E85) mix with out doing anything else to my car except put it on map 2? will my cars fuel system and computer automatically adjust or is there something else i have to do to my CPU or fuel pump and lines to run full E85 or mix? Thank you for any input. |
09-05-2016, 07:58 PM | #2 |
Rep 390
09-05-2016, 08:36 PM | #3 | |
Rep 2,809
The stock fuel tuning can't handle much more than 10% ethanol. However, if you are running a JB4 and have the fuel pressure sensor connected, you should be able to run just over E30-ish. Do you have the connect kit or the ability to connect your laptop to datalog? If so, start with 3 gals of E85 and slowly work your way up until your trims start rising to the point that AFRs (Air/Fuel ratios) start to dip into the low 11:1 range during WOT pulls. Set the JB4 up with a Fuel Open Loop setting of "70" before you start testing. If you go slow, you should be able to get to 4-5 gals of E85, depending on the actual ethanol content in your region. ProTip: When I say go slow, I mean go slow. Start with 3 gals of E85 and run the whole tank down to almost zero. Then, if trims look good and AFr's aren't too rich, move to 3.5 gals of E85 and run the whole tank down. If all looks good, move to 4 gals. Once you get to 4 gals of E85, go in increments of .10 (4.2, 4.3, 4.4....etc.) until you max your trims out to the point that AFRs are in the low 11:1 range. The reason you go slow, is to allow the LTFT (Long Term Fuel Trim) time to adjust to the added ethanol content. The STFT (Short Term Fuel Trim) is based off the LTFT and the STFT is what you're datalogging using the JB4. The reason AFRs go rich is because if the DME sees fuel trims go too lean, the DME will start to slowly richen AFRs up to protect the engine as the trims go leaner and leaner (this is a protection protocol for trims that are starting to max-out lean). The fuel system has plenty of overhead, but the DME's trims are the limiting factor. The key here is to find the happy spot where trims aren't too lean and AFRs aren't too rich. When AFRs start to get into the low 11:1 range and richer (10:1-11:1), it will cause the engine to misfire due to the S55 being a DI (Direct Injection) engine and the S55 can't tolerate such rich AFRs with that much ethanol. The JB4, when using the Fuel Pressure Sensor connector, is able to raise fuel pressure by faking low fuel pressure to the DME, effectively causing the DME to raise fuel pressure, which allows more trim headroom. This is what the FOL setting is in the JB4. I wouldn't recommend going beyond "70" as if you move that number up too far, the DME will eventually throw a DTC for low fuel pressure. I've been able to run about "72" before running into this issue. Last edited by CaryTheLabelGuy; 09-06-2016 at 07:43 AM.. |
09-05-2016, 08:40 PM | #4 | |
Rep 184
09-05-2016, 08:47 PM | #6 | |
Rep 184
thanks this clears things up for me. I need to get a fuel pressure sensor. and ill stick to running maybe 3-4 gallons E85 and mix the rest with 93 octane. Unless i can find race fuel around me. |
09-05-2016, 08:48 PM | #7 |
Rep 2,809
The fuel pressure sensor connector is on your JB4. Is it connected to the fuel pressure sensor on the engine?
09-05-2016, 08:55 PM | #8 |
Rep 184
i didnt hook up my JB4 i had a tuner do it. he never mentioned that it wasn't. I asked him if everything was connected right and he said yeah, then i mentioned i wanted to do a mix of 93 octaine and E85 and i honestly forgot the reply he gave me. the sales person pulled him off the floor quickly to chat with me while he was working on another car and I dont know if he was 100% sure of fuel ratios and the programing of the JB4
09-05-2016, 08:57 PM | #9 |
Rep 184
im thinking about taking my car up to THE SHOP in norwalk to double check my tune and to adjust me for E85 if need be. Thats where my brother took his GTR and hes running straight E85 and the before and after difference is insane.
09-05-2016, 08:59 PM | #10 |
Rep 2,809
As long as everything is hooked up correctly and you know how to datalog, you'll be fine doing this yourself.
09-05-2016, 09:08 PM | #11 |
Rep 184
i dont know how to data log im a noob im just getting back into cars and i have a little bit of catching up to do. havent been on a car forum since 05!
09-06-2016, 07:41 AM | #12 | |
Rep 2,809
I wouldn't recommend running ethanol mixes in your car until you figure out how to do basic JB4 stuff like datalogging and changing settings. Don't get the cart in front of the horse. I also seriously recommend the JB4 Connect Kit. It allows you to datalog and change settings using your phone as opposed to using a USB cable and laptop. |
09-07-2016, 11:23 AM | #14 |
Rep 190,725
09-07-2016, 07:19 PM | #16 | |
Rep 2,809
Datalogging is key here. Some people report not being able to even get to 4 gals of E85 depending on actual E85 quality and other factors such as ambient conditions. |
09-07-2016, 07:36 PM | #17 | |
Rep 4,033
16 F82 M4 DCT - ZCP - JB4 - 556WHP / 570WTQ
08 E92 M3 DCT - Bolt Ons - 60-130MPH 10.71s - 11.88 @ 118MPH - 377WHP ESS VT2-625 SC 60-130MPH 6.80s - 11.30 @ 129.3 MPH 586WHP / 379WTQ ESS VT3-750 - 60-130MPH 6.14s - 10.81 @ 135.13 MPH 690WHP/463WTQ Shift-S3ctor E92 M3 - 1/2 Mile Trap Speed WR - 174.13 MPH |
09-07-2016, 10:48 PM | #18 |
Rep 198
Saw this a few days ago
https://www.instagram.com/p/BI-IBlNB...ken-by=rktunes 86whp 155wtq Gained with our DME tune!!! Our tune with E60 fuel vs the factory Competition package tune with 93. Only mod is downpipes. The car still has the factory airbox. We will soon publicly release Map switching through the obd2 port so you can easily swap between tunes. Last edited by wakeofdeath; 09-07-2016 at 10:58 PM.. |
09-07-2016, 10:53 PM | #19 |
Rep 1,200
Proper way to do ethanol would be ... go to E85 pump... fill up car...drive and not care what % because the ECU should be flex fuel :P Hopefully one day BM3 will have full flex blending capabilities.
09-07-2016, 11:27 PM | #20 | |
Rep 2,809
I'm in Florida and my E85 is really close to 85% ethanol and my happy medium is 4.5 gals of E85 and the rest 93 (10% ethanol). |
wakeofdeath70.50 |
09-07-2016, 11:40 PM | #21 | |
Rep 1,095
2016 M3 Alpine White / Sakhir Orange BM3 Stage 2 / AWE Exhaust (Non-Res) / VRSF Cat-less Downpipes / CG Precision Valve Control / AFE Drop In Filters / 20% 3M Tint / Blackvue DR650GW-2CH / Escort Redline (Blendmount) |
09-07-2016, 11:51 PM | #22 | ||
Rep 4,033
