11-16-2020, 07:42 PM | #1 |
Rep 129
New amp from Bavsound for HK system, what's your thoughts
Have them trying to upgrade my sound, bought a set of used Bavsound stage 1 and still need to install it.
Want to get your thoughts on the new Bavsound amp: https://www.bavsound.com/products/ba...mium-top-hi-fi It seems to be using a Mobridge to convert the signal. No details on the installation, or detailed spec yet. It cost a bit more than what I like, was expecting low $1K. I read through this, it seems to have two different tunes, one for stock speakers and 1 for Bavsound speakers. I am trying to see if this is a good option for the price. The other choice is to tap the underseat woofer output, then run it to a 4 channel amp (2 channel for underseat woofer, 2 channel bridged to trunk sub). I have some old amps and Rockford Fosgate DSP that should worked. What do you all think? I think this Bavsound option still doesn't have power for a trunk sub, it seems to have a RCA output that can be used for sub. Is the extra power on all the speakers (besides underseat woofer and trunk sub) make such a big difference? |
11-16-2020, 08:04 PM | #2 |
Rep 2,161
Wow looks like $1600. I have their speakers and ghost woofers paired with JL amp and sub.
Hard pass at that price point especially since I'd only be changing the amp which powers the mids and highs. Pretty tho. Get a JL xd1000 5v2 and power your sub and woofers. They just dropped to $900 |
11-16-2020, 08:49 PM | #3 |
Rep 1,397
When I replaced my hifi amp in my f30 with the bimmertech amp it cost me $1k and was worth every damn penny. Having a dsp, and knowing how to tune it, is the absolute best thing you can do. I didn’t know this existed and I’m now highly considering this.
Pauldunlop13425.00 |
11-16-2020, 09:23 PM | #4 | |
Rep 129
11-16-2020, 09:25 PM | #5 | |
Rep 129
I am hoping there's some sales for BF... I wonder how this will be installed since it seems a bit big. Do you think this can go straight into the stock location? |
11-16-2020, 09:28 PM | #6 | ||
Rep 1,397
My intent was to compare the 1k in the hifi and the 1.6k for the HK and my opinion of it being worth it. Seems a small price to pay for the ability to utilize a DSP in our cars with plug and play. I do believe if they are claiming it's a 30 minute install it has to fit in the factory spot. |
11-17-2020, 02:59 PM | #7 |
Rep 2,161
For anyone interested I checked and it'll be March before they're available
fiveohwblow3633.00 |
11-19-2020, 12:40 AM | #8 |
Rep 3,726
I like the solution from Integral Audio better. $1600 is cheap for an amp and DSP. However I think Integral caters to more of the audiophile crowd and their custom arc amps and DSP look solid.
I used to run a dex-p99rs with tru billets, active 3 way and morel ultimo subs. that whole setup cost about 10 grand with custom pods on the dash for the mids. I'm pretty sure I lost a bit of hearing from that setup over the span of 10 years lol https://integralaudio.com/soundstagedsp-ultra.html
deebodeebo3.00 BitchinManWheels343.50 |
11-19-2020, 12:45 AM | #9 |
Rep 6,723
I have the Integral Audio DSP system and love it.
ARC Audio is a solid brand and as much as I heat up my exhaust, I have not had any issues with the amp or DSP unit overheating/clipping. Overall unit is stealth and pretty nicely laid out. |
11-19-2020, 07:36 AM | #10 | |
Rep 2,161
11-19-2020, 07:45 AM | #11 |
Rep 6,723
All the front drivers are replaced in addition to both under seat subs.
No rear drivers are replaced since the rear fill isn’t really contributing much (no rear shelf speakers) as they are just smaller door speakers. |
11-19-2020, 01:13 PM | #12 | |
Rep 129
In my other old car (E60), I had the Rockford Fosgate 8250 with 3 Zapco DC amps and some Seas component sets, that was done below $3K but that's like 12 years ago. Just wish things are simpler to upgrade. Tru billets, I thoughts those were build like a tank |
11-19-2020, 01:15 PM | #13 |
Rep 129
Where are you located? I saw you are in Nor Cal. If you are close by (I live in Fremont work in San Jose), definitely like to check out the system. Did you install in yourself and paid a shop to do it?
11-19-2020, 01:24 PM | #14 | |
Rep 2,180
This Bavsound amp is for the complete replacement of the HK OEM amp, not to power a trunk sub.
11-19-2020, 01:32 PM | #15 | |
Rep 6,723
I did the install myself. |
rkyan66145.50 |
11-19-2020, 03:17 PM | #16 | |
Rep 129
1. custom solution, at least $6-$7K, replace front sets, underseat sub, add trunk sub, new amplification for all replaced components with DSP 2. Replace all speakers with Bavsound stage 1, replace HK amp with this new Bavsound amp, replace underseat sub (either Bavsound Ghost/Jehnerts/Earthquake/Gladen/etc). If I want a trunk sub, I will need to add separate amp, and not 100% sure if there's RCA output from new Bavsound amp for dedicated trunk sub. Cost is around $1.6K (amp) + $550 (bavsound stage 1 used) + $300-$500 (underseat woofers depending on which one) + $300 (icebox from Ebay and sub, I have some old amps to use) 3. Keep original HK amp, only add new amp for underseat sub, and dedicated trunk sub. Still change out all speakers to Bavsound stage 1 ($550). $300-$500 (underseat woofers depending on which one) + $300 (icebox from Ebay and sub, I have some old amps to use for both trunk sub and underseat woofers). Option 3 will be the cheapest option, really, don't know how much will the $1600 buys me. Again I missed out on the Integral which I think seems to be a great solution... I have an old Rockford EPX that I can use to play around the sound for the underseat sub and trunk sub, but it's old stock and not sure how well this works... |
BMWjunkie89.50 |
11-24-2020, 07:04 AM | #17 |
Rep 195
Drives: '17 F80 Avus Blue/Sakhir full
I've had the Bavsound Stage 1 plus underseat Ghost woofers for 4 years running off the stock H/K amp. While much better than the cheap stock speakers, they need more clean power across the board, especially for crap sources like streaming. I looked through all the options listed but I didn't want a custom install with unknown complications and cost. So I just held off - until yesterday, when I saw the preorder for the Bavsound Revenant Pro amp! It's definitely pricey but the plug-n-play capability, the DSP settings preset for the Stage One speakers plus the ability to still add a trunk sub and amp (yes, I asked - it has pre-outs) made it worth it to me. So now a long wait until March for delivery!
In the meantime I'm looking at the MusicarNW custom sub box that fits over the battery, plus a JL Audio sub and mono amp for it. Crazy Christmas gifts🎄 I'm buying myself this year 🤡 Anyway, for me this setup will be very install-friendly and look pretty stock, plus not take up much space in the trunk. Too old for giant sub boxes anymore!
BMWCCA #156196 since 5/1998
Current - F80 Avus Blue/SO - ED in Nov 2016 - Bootmod3 and BSW Stage1/Ghost Subs/Amp, '13 Ferrari 458 Italia, '17 X6M (wife's!) Past - '12 X5 35i, '13 335i EBII/Black M-Sport PPK, '10 335i M-Sport, '03 M5, '02 530ia M-Sport, '01 330i Sport 5spd, '01 540ia M-sport (RIP), '97 M3, '96 328i Sport |
11-24-2020, 07:31 AM | #18 |
Rep 2,161
I'm actually warming up to the idea of this amp after some more consideration around other options to provide adequate power and tuning to the mids and highs. Since I have already added the Bavsound Stage 1/Ghost woofers plus a sub, the preamp out just cuts out my need for an LOC - no real benefit other than a cleaner install. But the fact that it's tuned for those speakers is enticing and anything with OEM plug n play is attractive to me. Might could justify the cost over other options based on what I have today.
Thankfully I have 4 months to think about it. 😆 |
11-24-2020, 03:17 PM | #19 |
Rep 916
i like the sound of my fabspeed midpipe and M performance exhaust over all these options.
pikkagtr3896.50 paul.teets36.00 |
11-25-2020, 05:42 PM | #20 | |
Rep 4
11-26-2020, 01:26 PM | #21 | |
Rep 2,180
The MOST converter alone is between $500 (mObridge, Helix) and $750 (NavTV Zen). So this custom amp real price is as much or cheaper than Bavsound Revenant amp for the HiFi system - with more power and more output channels. The MOST converter is what makes this custom amp a plug and play replacement, and itself the best sounding option to the OEM amp as you are completely bypassing the OEM amp digitally, straight to an aftermarket amp without LOC or analog input losses. This method of using a MOST converter to replace the MOST OEM amp is not new, it just that this is the first company to package this solution with a custom aftermarket amp and bring it to market. |
