10-03-2016, 09:19 PM | #1 |
Rep 1,718
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
Bolts for Fire Extinguisher
So orders the OEM fire Extinguisher and it didn't come with the 4 bolts to attach it to the seat delete.
Real OEM didn't seem to have the part number which I found odd. I ordered the bolts that attach the seat delete to the rear part number 07149168393. I am hoping these work. Anyone else done this yet?
10-03-2016, 09:23 PM | #2 | |
Rep 1,523
10-03-2016, 11:23 PM | #3 | |
BMW for Life
138
Rep 210
Drives: 08 e93 M3 HT
Garage List 2015 Alfa 4C [9.00]
1998 BMW M3 Coupe [0.00] 2005 BMW Dinan Coop ... [0.00] 2008 BMW E93 M3 HT ... [0.00] 2011 BMW 1M [10.00] 1971 Alfa 1750 GTV [10.00] 2003 Porsche C4S [0.00] 2003 BMW Alpina Z8 [0.00] 1998 BMW M3 4 door [0.00] 2007 BMW Alpina B7 [0.00] 2002 BMW e46 M3 [0.00] |
10-04-2016, 03:02 PM | #4 | ||
Rep 1,718
02-07-2017, 02:58 PM | #8 |
Rep 11,374
Do you happen to own the AW GTS that was at Fall-line?
02-07-2017, 03:06 PM | #9 |
Rep 47
I am wondering if you can help me? I ordered everything but I cannot figure out how to install. It only came with 4 screws??? I figure the 4 screws secure the
" base " plate, but what about the other brackets??? |
02-07-2017, 05:15 PM | #10 |
Rep 1,394
02-07-2017, 05:51 PM | #11 |
Rep 929
The 4 bolts do indeed anchor the base, you need three additional bolts (not the same as the other four) to mount the extinguisher carrier to the base, the higher side of the carrier is designed to face forward. The plastic straps have a molded pin that corresponds to an opening in the carrier to locate and capture the straps. Only thing I'm not clear on is where the German extinguisher decal goes, I know it's a window sticker, but just wondering how it's done in Deutschland. Hope this helps, Fran
02-07-2017, 05:54 PM | #12 | |
Rep 47
02-09-2017, 08:04 AM | #13 | |
Rep 10,185
Order 3
BMW if you are reading, I need a job, Please. |
02-09-2017, 08:21 AM | #15 | |
Rep 10,185
They have been in all BMW extinguisher kits ive seen, but never seem to be fitted
02-18-2017, 02:20 PM | #16 |
Rep 132
Nate-I'm missing the bolts that fasten the fire extinguisher hlder to the car as well. Purchased thru you early last fall. PM w/any questions. Note: On vacation, out of country, be back this Monday, the 20th. Thanks.
02-21-2017, 01:50 PM | #17 |
Rep 11,374
PM sent over. Will get you taken care of
02-25-2017, 07:50 AM | #18 |
Rep 132
02-25-2017, 07:56 AM | #19 |
Rep 47
02-25-2017, 10:35 AM | #20 |
Rep 261
Drives: M4 GTS, M3 GT4, E30 M3...
02-26-2017, 06:54 AM | #21 | |
Rep 10,185
I am confused. You said above you have the 4 Screw pack. These mount the lower bracket to the car. Then you said you did not receive the 3 screws that mount the upper bracket to the lower bracket. Those are no 9 in the diagram as I posted. Now you want the 4 screws again ? I believe the base to car 4 screws come in the extinguisher pack. They are not in the diagram I listed No 6 screws are 8 screws to fasten down part no 2 in the diagram.
02-26-2017, 10:40 AM | #22 | |
Rep 1,523
The parts diagram is not always clear on ETK and there can be mistakes. #6 on the diagram is used to secure the angle bar and floor boards to the car and only 4 is needed for that. The other 4 is used for mounting the base of the base plate of the fire extinguisher to the car. This is why a total of "8 qty" is listed as required. |
redrumm3417.00 |
