02-10-2017, 04:49 PM | #1 |
Rep 908
Correct Tire Sizes and Offset for HRE FF01?
Hey guys,
Thinking about purchasing a used set FF01's in this size: Front: 20x9.0" ET25 Rear: 20x10.5" ET26 Will these fit w/o spacers and what are the correct tire sizes I would need? Thanks! |
02-10-2017, 06:06 PM | #2 |
Rep 1,481
They'll fit, but they aren't ideal if you want to run wider than stock tires. You can run a 255/30 275/30 setup without issue, maybe a 285/30/20 on the rear, depending on the type of tire. The front with a 255/30/20 will be similar to stock fitment, so a 10mm spacer would make it more flush to the fender like the rear.
