10-12-2019, 12:45 PM | #1 |
Rep 285
Drives: 2017 M3 Comp
M3/M4 CS EDC coding with Bimmercode?
Hello,
Is it possible to use Bimmercode to code M4 GTS and/or CS EDC settings on an F80 ZCP? Thanks |
10-20-2019, 09:23 AM | #2 |
Rep 134
It may be possible to fdl code the settings with BimmerCode if the vehicle i-step level is new enough. I’m not sure that BimmerLink will be able to perform edc start up procedure (or others) if you run into that fault after coding however.
I documented the values you can try to fdl code in expert mode in the diy guide validation section at https://f80.bimmerpost.com/forums/sh....php?t=1649232. This is written for coding with esys and Ista+ however. |
10-20-2019, 09:28 AM | #4 | |
Rep 285
12-19-2019, 07:08 PM | #7 |
Rep 3,143
01-01-2020, 10:28 AM | #8 |
Rep 140
Drives: F80, G01
There was a thread about the Thor app here but it's been removed. Any reason why? I was trying to find out more information about the app. I was looking to do some coding as well.
jbed39.50 |
01-10-2020, 06:45 PM | #10 |
Rep 587
Yes. I used Thor for GTS tuning for the DCT, steering, diff, MDM, etc and Carly for all the usual coding like iDrive warnings, mirror folding, and all that other stuff.
bimmercode, code, coding, f80, zcp |
