04-17-2016, 06:56 PM | #1 |
Rep 217
Which fuse is live only when switched on or running?
On my M4 at the rear trunk fuse box, does anyone know which fuse number is only on when the car is switched on or running (NOT when I open door)
04-18-2016, 09:32 PM | #2 |
Happy M Driver
241
Rep 390
Hey Op,
Check out my post below, re: my Dash Cam install: http://f80.bimmerpost.com/forums/sho...&postcount=197 Basically only 2 types of fuse slots in the rear trunk fuse box: MAIN type, where the power is always on, regardless of whether or not the car is running, and ACC-Ignition type, where the power is on when the ignition is on. Not sure there's the type of power source you refer to where the fuse slot, intended to be an Ignition type, is not affected by the doors being opened. Also, a number of fuse slots where they are typically turned on when the ignition is on, and/or when a door is open, will usually stay on for about 20 minutes after the car ignition is turned off or when a door/trunk is left open constantly for about 20 minutes. The fuse slot I used, for ACC/ignition, was fuse slot 125 (refer to my post pictures). A quick way for me to confirm that the slot 125 did NOT have power was when the trunk light would turn off (when leaving the trunk open for about 20 minutes). So, I'm curious as to why you're asking. What's the project you have in mind? Hope this helps. -Tony
2020 X5 40i M Sport - The "Unicorn" (B&W Sound, Touch Screen, Heated/Cooled Cup Holders, Soft Close Doors, Acoustic Glass, Full Alcantara & Glass Controls, Luggage Compartment Package, Heated/Ventilated Seats, Laser Lights, Fog Lights)
2016 M4 Coupe; 2008 Dinan S1 M5; 2006 530i; 1998 328i Last edited by Cooltones; 04-19-2016 at 09:25 AM.. |
damageprone580.50 |
04-20-2016, 10:23 PM | #3 | |
Rep 217
I am adding a LUKAS Dashcam Battery backup to my Blackvue dashcam. The Battery charges when the power is live and when the power is cut off the dashcam uses the battery backup while parked. I wanted to have the battery charge only while the car was either running or switch ON and NOT when the car is on the 20 minute mode supplying power. The load on the battery I fear will be too great and possibly drain the car battery while charging the backup battery for 20 minutes. (does this make sense?) Here is the backup battery in case you are interested. http://www.amazon.com/LUKAS-LK-570-L...ilpage_o09_s00 |
04-21-2016, 09:21 AM | #4 | |
Happy M Driver
241
Rep 390
FWIW, Here's my "daily/weekly drive" activity: Monday - Thursday: I'll drive my M4 to work (about 35 minute drive one-way), it sits in the parking garage for about 8 hours, then I drive home into the garage. A few times I've taken a look at the Cellink Battery as soon as I parked in my garage to see the green light confirming it's fully charged. The next morning the BlackVue is still operating. From Thursday night to Saturday morning my M4 typically sits in the garage, with me occasionally going to the trunk to put in/get out something. Sometimes I just jump in the driver's seat, not starting the car, but just to be in an environment that helps me think and makes me smile... Saturday morning arrives and when I start up the M4 I don't get any "battery drained" notifications or comfort access not working (which appears to happen when our F8x's have battery draining events...). Just wanted to share my experience thus far. No "visible" battery concerns; HOWEVER, I totally agree with you -- It would be GREAT to find a fuse slot that only turns on when the ignition turns on, AND NOT when the doors/trunk opens... Let's be sure to share notes if one of us finds such a fuse slot... Cheers, -Tony
2016 M4 Coupe; 2008 Dinan S1 M5; 2006 530i; 1998 328i |
04-21-2016, 09:32 AM | #5 |
Rep 2,371
Agreed. I tried to find one for my amp install, but didn't have any luck at all.
2015 Black Sapphire Metallic 6MT M4
04-26-2016, 01:36 PM | #7 |
Rep 217
07-08-2016, 06:06 AM | #8 |
Rep 147
I need to bump this.
Has anyone managed to find a reliable 12V and ACC set of fuses tested over time to work with the PowerMagic Pro for the BlackVue? Also how did you handle the ground wire? I can't find a way to attach it to the chassis reliably. Thanks. |
12-29-2017, 11:40 AM | #9 |
Rep 564
I know this is an old thread but I spent some time searching for info as I needed a power source which is not powered on every time I open the door, and shuts down when I turn off ignition. And I found the correct fuse. In my car (2018 M3) that is fuse 146.
I opened the chart with all the fuses and found the ignition symbol - I guess any one of these are good, but 146 was the first one I tried. Fuse 146 location - on the way out. Properly wired: Hope this helps whoever need an ignition source in the trunk which isn't powered on when you open the door and for 20 minutes after locking the car.
2018 F80 M3 6MT | San Marino Blue | Amaro Brown
2021 G01 X3 30e | Alpine White | Cognac Brown instagram: @ frode_m3 |
04-08-2018, 05:02 PM | #10 | |
Rep 285
Drives: 2017 M3 Comp
04-08-2018, 05:50 PM | #11 |
Rep 955
10 amp for battery backup
5 amp for radar It will turn off when u turn off car immediately. Make sure on the wire tap you put the stock fuse amperage on the bottom. And whatever amp you need for your hardware you stack on top. If you put the wrong fuse amperage you will blow 10 fuses like I did |
damageprone580.50 |
12-29-2018, 03:24 PM | #13 | |
Rep 1,696
I start the car and get an iDrive error saying that the Parking Aid is disabled. I go check the 5 Amp fuse on the fuse tap, and sure enough, it was blown. What have I done wrong? I can confirm that when you kill ignition on Fuse 146, power is cut immediately (no stupid 20 min of residual power). |
12-29-2018, 06:17 PM | #14 | |
///M SubDriver
1832
Rep 2,782
Drives: 2017 M3, 2020 X7 40i
This is one of the reasons I plan to use the OEM fuse tap method .
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
12-29-2018, 06:32 PM | #15 | ||
Rep 1,696
I don't believe my fuse tap is faulty. Because I used the same fuse tap and tapped into Fuse 145 (which ordinarily holds a 15 Amp from the factory) to hard wire the B-124 battery. My volt meter showed that Fuse 145, like Fuse 146, shuts off immediately when ignition is killed. Everything works perfect now. No errors reported by car. I doubt I had a faulty 5 amp fuse from factory. Maybe what happened is that 5 amp factory and the 20 amp that came with my B-124 are too far apart and my B-124 draws 9 amps. That 9 amps was too much current for the factory 5 amp fuse. I think that if you use a fuse tap with the B-124, you must choose fuses that occupy 10 amp or higher. This, Fuse 145 is a no go since it is rated for only 5 amp. But Fuse 146, which is rated for 15 amp from factory, is sufficient to power the B-124 (draws 9 amp). So using the B-124 20 amp fuse in the fuse tap with the factory 15 amp fuse in Fuse 145 works perfect! |
12-29-2018, 06:57 PM | #16 |
///M SubDriver
1832
Rep 2,782
Interesting.... My basic understanding of how they worked was that the size of the fuses used did not matter as long as the factory fuse and the aftermarket accessory fuse were installed in the correct position in the add-a-fuse tap, everything would work. Your experience is very weird - makes me wonder if that is something unique to BMW (and the F8X/F3X platform)...
12-29-2018, 08:04 PM | #17 | |
Rep 1,696
Check out my comprehensive thread I just wrote here: Which Fuse in Trunk for Blackvue B-124 / Cellink Neo? https://f80.bimmerpost.com/forums/sh....php?t=1568426 |
12-29-2018, 08:40 PM | #18 | |
///M SubDriver
1832
Rep 2,782
12-30-2018, 10:52 AM | #19 | ||
Zymurgist
89
Rep 161
