04-22-2024, 09:53 PM | #1 |
Rep 1
F80 M3 Misfires and Drivetrain Error
So I've owned my 2016 F80 M3 for 4 months now and have had no issues with it until about a month ago. Got "drivetrain malfunction: drive moderately. maximum drivetrain output is not available, consult nearest service center" and check engine light and car went into limp mode. Ran the codes and had 4 cylinders misfiring. Dealer said I had an intake air leak (dinan intakes were on it), so I took it to a private shop and they replaced the dinan intakes with stock ones. Just got it back and got the exact same problem once I hit around 100 mph. Ran the code again today and now only one cylinder is misfiring. Has anyone had a similar issue and, if so, what was the reason behind it for you?
04-24-2024, 09:25 AM | #4 |
Rep 24
Drives: 2016 M3 6mt
Not sure why I’ve been seeing posts like this lately. These cars are surprisingly reliable and take extremely well to mods. Only reason you see so many problems posted on here is because that’s the main reason to use this forum at this point.
04-24-2024, 09:39 AM | #5 |
Rep 1,221
Good point and I agree. I have a bone stock F series car and it’s been super reliable. Not against modifying at all. I just find myself reading a post title regarding an issue and think to myself it’s probably modified in some fashion and usally it is. Whether it be a tune or bolt ons. Not judging, just a casual observation.
04-24-2024, 11:58 AM | #6 |
Rep 1,022
Drives: BMW X5M, BMW M3, MB E63 AMG
I don't think it is a intake issue, but if it were you would have unmetered air going thru the car which could cause some of these issues. But I think that it's a bad ignition coils. I just went thru a similar issues with the E63 AMG. I got a CEL, the car was misfiring, loss of power, slow to accelerate, car was vibrating. So we swapped coils around and read the results from the Autel, by using this method we determined that it was the number 4 cylinder coil that was bad. Then we replaced it, with a new one and no more CEL or issues and this was less than two weeks ago.
04-24-2024, 02:08 PM | #7 |
Rep 170
these cars love mods. just built it right. quite simple. people love doing bolt ons with no supporting mods and then wonder why the car won’t work properly. for example, lot of people just throw on bigger turbos but do nothing on the fueling side of things. people change ignition coils and spark plugs but don’t actually do research on using the high power spark plug (which is better) than what everyone uses 97506. it’s really not that hard
2015 Liberty Walk M4
F80Paul Tuned New Jersey |
