04-19-2022, 06:09 PM | #1 |
Rep 25
Trunk Won't Open
Went to open the trunk to my 15 M4 and there's no click when I hit the trunk button, the fob doesn't open it, and the button on the dash doesn't do anything either. It went from works fine one day to not opening at all the next time I used it. Any ideas would be greatly appreciated.
04-20-2022, 12:58 AM | #2 | |
Rep 268
04-21-2022, 08:04 AM | #3 |
Rep 25
04-23-2022, 06:04 AM | #4 | |
Rep 77
2018 M3
04-25-2022, 05:57 PM | #5 |
Rep 25
04-25-2022, 08:19 PM | #6 | |
Rep 77
2018 M3
04-28-2022, 10:47 AM | #7 | |
Rep 661
Does anything happen when using the handle on the trunk itself? Sounds like you may need a trunk latch.
Winter: 13 PGM 3.5 E70|MHD
Summer: 15 6MT BSM F80|MHD|KW|SM-10 Gone: 09 AWD 6MT AW E90|FBO|MHD|XHP|KW|ARC-8 IG: 475_f80 Last edited by WordOnRoad; 04-28-2022 at 10:57 AM.. |
04-28-2022, 12:48 PM | #8 |
Rep 397
Drives: 2019 M4
I have a 2019 M4. There is a release latch behind the headrest inside the car. And a pull latch in the trunk in the trunk lid.
OP, have you gotten it open yet?
2019 M4 Coupe MG SS DCT ZCP
2015 M4 Coupe MG SS DCT (Trade) 2009 335xi Coupe Dinan Stage 2 (Sold) 2003 M3 Coupe (Sold) 1998 M3 Sedan (RIP) |
Pauldunlop13425.00 |
04-28-2022, 04:20 PM | #9 |
Rep 25
Nope. I haven't messed with it too much since the trunk is empty and I don't really use it much. I figured it was probably the trunk latch since there's not a click or anything when ii hit the release whether it's the fob or the trunk itself.
08-09-2022, 06:14 PM | #10 |
Rep 16
Trunk refuse to open on my 2017 BMW M3.
I have the same issue. Have you found a solution?
Trunk refuse to open on my 2017 BMW M3. My battery seems to be ok, the car starts up no problem. I have tried the valet switch in the glovebox, does not help. I can lock/unlock and activate the alarm with the keyfob. But, the trunk will not release with either of the buttons, the trunk, the key fob, or inside the car. I really don't want to disassemble my rear seat and fish for the release cable. P.S. To make it more "fun", right before it happened, I bought some fruit from local grocery store, and placed them in the trunk. Drove one block to my house and this happens |
08-11-2022, 04:25 PM | #12 |
Rep 16
Update: Ended up taking rear seat off to get to emergency release cable in the trunk.
The fusebox is inside the trunk, no way to get to, before you release it. All of which are ok. Last edited by E92toF80M3; 08-11-2022 at 04:40 PM.. |
08-11-2022, 07:02 PM | #13 |
Rep 502
I vaguely remember seeing options in BimmerCode to deactivate some trunk access related functions. Did you code recently and deactivate by accident?
08-13-2022, 03:06 PM | #15 |
Rep 13
Had the same issue on my ‘18 M2. Took the dealer a few days but they found a short in the locking mechanism.
Ironically, my ‘19 M4 has a trunk that refuses to stay shut. |
02-09-2023, 12:43 AM | #16 |
Rep 16
Quick Update: Finally took my '17 M3 to the dealer, they found R.E.M. (Rear Electronic Module, Part# 61-35-9-499-001) has failed.
$1500 later my trunk is working again. |
02-24-2024, 08:39 AM | #18 | |
Rep 254
In my case the trunk opening was not working occasionally for last couple months, but figured low battery voltage was the culprit bc it always worked eventually. Now it’s just dead, going to see if I can read it with BimmerCode. Ordered a REM from ‘16 F30, (same part #) on eBay for $40. Will see if that fixes the trunk when swapping. If so I’ll need to code it to have rear windows & camera work, and remove trunk dash light. If it doesn’t fix it I guess the latch could be the issue…but based on the amount of REM failures I’m seeing I’ll bet it’s that. Last edited by Alpine-F80; 02-24-2024 at 08:50 AM.. |
03-12-2024, 11:29 AM | #19 |
Rep 274
Interesting thread - didn't know this was as pervasive as it seems, definitely something I'm going to look out for! Alpine - would be curious how your REM replacement goes.
Current: 2018 M3 ZCP Tanzanite / 6MT | 2022 X3 M40i Brooklyn Gray
Old: 2016 M4 / Yas Marina Blue / 6MT / Dinan Stage 1 / EDC / Black Kidney Grilles / MPerf CF Spoiler / Exec Pack |
