09-28-2020, 11:18 PM | #1 |
Rep 229
F8x to amg c63s
Hello everyone ,
Just want to know if anyone has had extensive driving time behind the wheel of a c63s. How does the drive compare to the f8x generation ? Any reliability issues ( if you owned one prior ). Maintenance cost compared to the Ms. Driving dynamics if terms of cornering / steering feel : braking .. etc. . I've had both the e9x m and f80 , but I'm looking to try something new , also this would be the first vehicle without a manual. The car will Also be used as a daily driver . Any help would be greatly appreciated thanks. |
09-29-2020, 07:21 AM | #2 |
Rep 3,422
C63 S sedan owner.
After my wife insisted we test a Cayenne and she started eyeing Range Rovers, my son and I conspired to redirect focus. So, this took the place of my beloved (2nd) E90 as our family car. Generally speaking, car has a very different vibe as compared to M3's. Modern tech and transmission aside, it reminds me far more of my E39 M5 than my E90s or an F80. I have a '20. Basically fully loaded, I think. Engine is killer, enjoyable 100% of the time, trans is just alright. I am a fan of the interior and tech, well thought out. AMG you're covering all oil & maintenance inside of the warranty term. Not really inspired enough for a full review But let me know what feedback areas would help you out and I can get into more details.
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
stein_325i25086.00 minn1914055.50 |
09-29-2020, 07:28 AM | #3 |
Rep 1,370
^ Can you comment on ride quality because last time I test drove a ‘18 C63S and it was more firm than my F80 comp.
E92TiAg335i216.00 |
09-29-2020, 08:26 AM | #4 | |
Rep 3,422
19's, PSS, and 48 psi front, 45 psi rear cold specs. Highest psi specs of anything I've owned. Larger bumps are soaked up pretty well.
09-29-2020, 09:15 AM | #5 | |
Rep 3,422
I think even in a straight line the M4 is probably the more visceral experience. The engine is more high strung. Again I'd emphasize AMG M177 is more S62 (E39 M5) than S65 or S55. As for which is actually faster 40-100, I'd guess the Merc, but probably just comes down to which hooks up better in 2nd. On that point, Merc's 9 stage traction control could be an advantage. Think my Solo2 (lap timer) might have some acceleration settings. Could grab some real world #'s if we have base or comp M4 data to compare.
09-29-2020, 12:04 PM | #6 | |
Rep 229
09-29-2020, 02:15 PM | #7 |
Rep 131
I jumped from a 17 zcp m3 to a 19 c63s and now back to a 18 zcp m3. The c63's transmission is lacking, it doesn't shift as fast, and is clunkier. While the c63s is probably faster, it doesn't necessarily feel that way.
SCCThree816.00 |
09-29-2020, 02:15 PM | #8 |
Ring Leader of G8X Haters
25086
Rep 8,762
AMG's tend to be more about German muscle than sports sedans that BMW have typically been in the past, however these days that seems to be changing especially in the E63S (which seems more like an M than the M5). Either way, don't go in expecting it to be zippy and nimble like the F8X, like FormulaMMM said its very close to E39 type of car, most of this of course is due to the fantastic V8 over the front end. It will weight more than an F8X, and it does ride firmly like the F8X but it is still a fun car, and the exhaust provides a lot of theater, and the MCT is is overall good (at times a bit clunky in town like other DCT's though) but overall a different experience from the M3 that you may have to adjust your expectations to.
I was looking forward to the new M3, however of course looks killed that, and then the loss of a DCT, the weight gain (C63 is only 30lbs more, and C63S only 10lbs more (compared to comp) coupe is weirdly heavier (possibly due to bracing?)) really just made me lose excitement, and after driving the X3M, I'm not very interested in the S58 engine. As for aspects I can tell you OP, the interior is very nice. My wife has a GLC 300 which shares the interior of the C, and its a nice cabin. Some people have complained of creaking however I have only found that present if you put direct pressure on the trim pieces which my wife and I never do (of course YMMV). The C-Class doesn't have MBUX but rather the older COMMAND system which is just okay, but with Apple Carplay, I rarely interact with it outside of ambient lighting and drive modes. The digital gauge cluster is very nice and extremely customizable (with traditional gauges and even a center tach). With the C63 possibly losing its V8, now may be the best time to buy one, hell, it may even hold its value better. If you are looking for something closer to your F8X I advise you check out the Giulia QF (though reliability concerns may cause you to look away) as well as wait for the upcoming Blackwing products from Cadillac. I would also try asking the guys over MBWorld any other questions you have as there may be some F8X converts over there as well. Good luck!
Current Garage: 2022 Mercedes-Benz S 580 / 2023 Genesis GV70 2.5T / 2007 Mercedes-Benz E 350 / 1999 Mazda MX-5 Miata
Retired: '95 E36 325i 5MT / '04 E46 330i 6MT / '05 E83 X3 3.0i / '11 E90 335xi / '17 G30 540i / '19 F87 M2C 6MT / '19 MB CLS 53 / '20 MB GLC 300 |
09-29-2020, 02:21 PM | #9 | |
Rep 229
stein_325i25086.00 |
09-29-2020, 02:23 PM | #10 |
Rep 229
Any other pro's or cons that you have experienced ? Dct is far superior than the merc Mct but i won't be trying to kill lap times or anything like that . Maybe take the car to the track once or twice
09-29-2020, 02:50 PM | #11 |
Rep 131
I'm actually in the same boat as you, definitely not worried about lap times. It just bothered me with how clunky the transmission was magnified by the fact that it's not as quick at shifting. The MCT is just a fancy marketing term for a normal AT. The DCT feels special. I think the interior of the c63 is great and the 19+ tech is great as well. The screen is huge.
09-29-2020, 02:59 PM | #13 | |
Rep 229
09-29-2020, 03:57 PM | #14 |
Rep 3,422
On driving entertainment value alone, it’s a tough transition from a 6MT E90. The modern tech and features, and yeah, creature comforts would have to offset the loss of pure driving factor.
Bias alert: I think the E90 M3 is the best all-around car ever made. If I could snap my fingers and have a track ready, mechanically sound (rod bearings, etc.) E90 instead of the AMG, I’d do it no hesitation. But as indicated, was time for the wife to win one and I only have so many garage spaces. Are you entertained by tech? It has plenty. Two big screens, both of which can be pretty intuitively controlled on the updated wheel. (You basically don’t have to visit the center console controls.) Bluetooth music, apple carplay, Burmeister system all excellent. Full spectrum ambient lighting options, multiple instrument cluster design themes, numerous settings for the info displayed inside of the speedo and tach… head up display (also customizable), etc. etc. etc. It’s jumping to an iphone 11 from flip phone coming from an E90. The drive mode dial in the lower right, and customizable buttons lower left that can be set to toggle exhaust, dampers, trans, and more, are great. The wheel itself is good, but too hard imo. nobody does steering wheels as well as M. Lane assist + distance control = autopilot. Not as good as Tesla’s, but still very usable on well-marked roads. Despite the relaxed vibe overall, the current gen C63 S AMG is probably more track ready in my experience than a stock E90 or F8X. I don’t know if mine will ever see the track, but I hammered on my buddy’s ’17 pretty hard and enjoyed it. Brakes, cooling, everything was solid. It’s just lacking tires for advanced pace – 245 front, 265 rear stock. (Rear is narrower than incoming G8X front.) Updated 9 stage traction control would be an advantage for track newcomers or casuals vs. M’s of any gen up to G8X. Performance seats are better than anything M pre-G8X in terms of track/performance driving support + day to day use + looks. I have the heated & cooled. Transmission – there’s no getting around, it’s just alright. To add to, I don’t like the thick paddles or clunky paddle action, but still use them from time to time. I’m probably in comfort setting and auto 90% of the time. That’s just what suits the character of the car. It doesn’t constantly goad you into bad behavior like an M car. Or, maybe I’m just getting old. In auto, it is responsive. Dial up the modes toward sport plus and race and it stays ready to rip. It is not sloppy, that's not how I'd describe it. It's a big step forward from the old Merc slushbox, just not M dct. Engine – in the context of modern options, it’s fantastic. Anyone who says otherwise is full of it. Loud, responsive, powerful, and always present. Cruising at 50 mph and between 1-2k rpms in 9th gear, it’s still rumbling away. And as pointed out above, rumor is a 4 cylinder for the next gen 63. I’m a sucker for “end of the line” types of vehicles and features. Hope this helps. It would be a major departure from the E90, but if you’re ready for a transition vs. a replacement that would be close in character, then it could be a match.
09-29-2020, 04:37 PM | #15 | |
Rep 229
FormulaMMM3662.50 |
09-29-2020, 04:51 PM | #16 | |
Rep 3,422
09-29-2020, 04:59 PM | #17 | ||
25086
Rep 8,762
FormulaMMM3662.50 |
09-29-2020, 07:22 PM | #18 | |
Rep 1,144
the 2019 are also have a quieter exhaust and best part is the new digital screen display and winter driving modes. |
09-29-2020, 07:25 PM | #19 | |
25086
Rep 8,762
09-29-2020, 08:15 PM | #20 | |
In The Rain
8177
Rep 6,261
Drives: '24 GT4RS, '24 Macan GTS
I personally like the C63. My complaint has and always will be the shifter style (ignoring the slapped on iPad screen). I do not like it. I am able to get used to it, I am tech savy but I don't want to. I don't like it >.< The more subtle styling of Benz cars is a plus in a lot of situations actually. Especially if you travel through... suspicious places, having a car that hides in the crowd is better. A car like the M3/M4, RS5 will scream attention to anyone. C63 will hide in the crowd, until you step on the gas and hear the V8.
'24 Porsche Cayman GT4RS Arctic Grey "Alice"
'24 Porsche Macan GTS Dolomite Silver "Gina" |
09-30-2020, 09:53 AM | #22 | |
Rep 10,081
stein_325i25086.00 FormulaMMM3662.50 |
