      05-13-2018, 09:17 AM   #1
Throttleblip
Throttleblip's Avatar
Drives: BMW M4 ZCP 2016
M4 CS vs M4 ZCP Torque Curve
This difference between both models are rarely covered in the CS reviews/comparisons, but for me, as a previous M4ZCP owner, this is one of the primary reasons I upgraded to to the CS. In the graphs one can clearly see that BMW has made the torque delivery of the CS more linear (similar to the Porsche 991.2 turbo torque delivery) which builds as RPMs and HP increases. As few reviewers have stated, this change makes the CS more manageable at the limit and makes it feel more "naturally aspirated" than the ZCP setup. Thought it was interesting to share this difference in torque delivery between both models. Graphs below:
      05-13-2018, 09:22 AM   #2
CanAutM3
CanAutM3's Avatar
Looking at the graphs, I'd say that the CS torque delivery is in fact LESS linear.
But I understand what you mean.
Also, I am not sure where the data for the graphs comes from, but the CS' and CP's torque and power curves shown do not match the ones published by BMW: http://f80.bimmerpost.com/forums/sho....php?t=1376759
stormlv930.50
      05-13-2018, 09:27 AM   #3
Throttleblip
Hahaha...yes, literally, less "linear" hahaha
      05-13-2018, 09:28 AM   #4
CanAutM3
CanAutM3's Avatar
I was also still editing my post. These power-torque curves seem at odds with what BMW publishes for the CP and CS. Something is off (it says "approximation").
      05-13-2018, 09:31 AM   #5
Throttleblip
I was also still editing my post. These power-torque curves seem at odds with what BMW publishes for the CP and CS. Something is off (it says "estimated").
Got them from: http://www.automobile-catalog.com/bi...ckage_dct.html
It could very well be that something is off... not sure
      05-13-2018, 09:35 AM   #6
CanAutM3
CanAutM3's Avatar
According to the BMW charts, the CS makes more torque than the CP from 2400RPM to 7300RPM, which is not what is shown on these charts. It is only below 2400RPM that BMW has tamed the torque output.
Further, according to dyno plots from Evolve, it appears BMW have also tamed the low RPM torque output for all F8X with a software update.
      05-13-2018, 09:46 AM   #7
Throttleblip
According to the BMW charts, the CS makes more torque than the CP from 2400RPM to 7300RPM, which is not what is shown on these charts. It is only below 2400RPM that they have tamed the torque output.
Couldn't find the torque curve of the ZCP in the chart from your thread
      05-13-2018, 09:58 AM   #8
Throttleblip
The graph I posted for the CS (at least the top of the torque curve) seems to be correct from BMW specs 600nm from 4000-5380rpm
      05-13-2018, 10:02 AM   #9
CanAutM3
CanAutM3's Avatar
Look at the power curves, if the CS makes more power than the CP at a given RPM, it inherently makes more torque.
      05-13-2018, 10:05 AM   #10
CanAutM3
CanAutM3's Avatar
Sorry to say, but no it is not correct. In the chart from my thread (which is the official BMW chart), in CS tune the S55 makes ~580N-m at 2400 RPM, which is more than the 550N-m of the base and CP tunes. Your graphs show the CS making less torque at that RPM. They also underestimate the torque above 5400RPM. The only portion they got right is the 4000-5380 peak torque plateau. The rest of the curve is off.
      05-13-2018, 11:56 AM   #11
Throttleblip
Your right that the graph I posted of the CS initially in the OP isn't the official one, I checked, the correct one is the one you posted which I'm attaching below. But still, the peak torque for the ZCP of 550nm is reached and maintained from 1850 to 5500 RPM. From my understanding, this means from the official CS graph below that at 1850RPM the CS makes aprox. 370nm of torque (less than the ZCP of 550nm @1850RPM). The CS only reaches the ZCPs peak torque of 550nm until 2300RPM aprox. So, there is a difference in that the CS reaches higher torque figures until later in the initial stages of RPM range than the ZCP . I'm guessing that this is why some reviewers have said it is more manageable and less spikey when you start leaning on the throttle after the apex of a curve. Anyways, thanks... this discussion has made some questions I had clearer.
      05-21-2018, 04:54 PM   #12
Throttleblip
Joe Achilles reviews the M3CS and mentioned how linear power/torque delivery feels @4:50 aprox
      05-31-2018, 10:08 AM   #13
MWM4ZCP
Drives: M4ZCP
Was on a dyno yesterday with my M4CS the only mod is the MPE, results are as follow, data are not corrected with EWG......
CanAutM321113.50
      05-31-2018, 01:35 PM   #14
Throttleblip
Seems more "linear"
      06-01-2018, 10:28 AM   #15
bimmerfrk
bimmerfrk's Avatar
Drives: Ferrari Red F83
Bootmod3 and it wont make difference. More torque than both. Car equals beast mode.
      06-10-2021, 11:52 AM   #16
marconi118
Drives: 06/07 e93 335i
Will bootmod3 restore the full torque at 1750rpm like the older m4 zcp software?
Or once updated there is no way to restore full torque at 1750rpm?
