03-01-2018, 08:29 AM | #1 |
Rep 370
Temporary AC Issue - Anyone Else?
I was driving yesterday and during my drive I had the AC on high but no air coming out. You could hear the blower working behind the right front part of the dashboard, but no air. If I turned the fan off while driving and turned it back on same issue. however, if I came to a stop and turned the ignition off and then on issue went away. I have not had the issue since, but curious if anyone else experienced this and if this resulted in service.
03-03-2018, 02:14 PM | #2 |
Rep 891
I had the same problem, no fault codes, changed the fan relay but the problem came back. I noticed it starts during longer drives and after the car cools down it runs normally.
03-03-2018, 03:09 PM | #3 |
Rep 623
This happened once on my 2016. I let the car rest for a day or two and then the problem went away and never came back.
2018 F80 M3
Instagram: @steven_f80 |
03-14-2018, 08:30 PM | #4 |
Rep 15
Yes i had that happen to me too, brought car in and they said it is more common as some adapter is too close to the evaporator causing the line to freeze and such make your ac non functioning. Or something like that, search the forum for the thread, your dealer should know about it.
03-21-2018, 07:38 PM | #5 |
Rep 708
Dealership says AC has "known design problem" https://f80.bimmerpost.com/forums/sh....php?t=1402100
Bye bye E93 M3 - Hello F83 M4! |
08-16-2018, 06:52 PM | #6 |
Rep 4,784
Same happened to me this past weekend. But the blower quit working completely. Had to drive back home (346 miles) in the texas heat. I let the car sit for a few days, turned it on to take it to the mechanic and started working perfectly. Only thing is that a warning light came on saying "increased battery drainage when off" AC and blower have been working fine ever since...
ERnie
2016 BSM/f80/ZCP |
08-16-2018, 07:57 PM | #7 | |
X3M Comp
443
Rep 718
08-21-2018, 12:09 PM | #8 |
Rep 83
It is known problem not only for F80/82, but it is also Mercedes and Porsche.
The advisors told me to turn the AC to "Auto" mode if I go on a long trip. The car will know how to adjust the temp to not freeze the lines. |
08-21-2018, 11:44 PM | #9 |
Rep 4,784
I wonder what they would charge being that I no longer have warranty
ERnie
2016 BSM/f80/ZCP |
08-22-2018, 07:46 AM | #10 | |
Rep 4,387
Drives: 2022 F97 X3M Comp LCI
i just came back from a 5 hour drive on 90+ degree humid day. i initially set the HVAC to "MAX" which puts the fans at full speed and the temp gauge to the coldest at 60 degrees. once the interior temperature was bearable, i set the AC on "Auto" set at 70-75 degrees. the central hot(red)/cold(blue) dial at dead center. the car HVAC takes care of everything and i have never had any issue with AC not blowing or the lines freezing.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
08-28-2018, 12:59 PM | #11 |
Rep 421
the other day I turned on my AC, the same way I normally do and it was just blowing in hot air. I hit the AC button to turn it off, then back on... and the air turned cold.
