10-22-2019, 12:47 PM | #1 |
Rep 1,862
Drives: powered by bootmod3
bootmod3 - Direct USB connection via OBD Hardware agent - option for iOS/Android
Wanted to share a connectivity update with the forum members that over half the people in the poll on Facebook weren't aware of, see picture attached.
For those of you with the OBD Agent hardware device there's an option to connect using a USB cable to your iOS and Android phone/tablet for a direct cable connection. This doesn't require WiFi setup of any sort on your phone/tablet and is probably one of the easiest setups when ti comes to using bm3 as there's no WiFi setup to be done and there are is no need to worry about a firewall on the laptop. OPTIONAL power source hookup: To take it a step further, device can be installed on a piece of velcro in the driver's footwell area on the top plastic, run a short flat ENET cable from the OBD port over to the device's ethernet port and power it using power from the back of the OBD port (pin16 is 12v power, pin4 is ground). You can use this 12 to 5v converter: https://www.adafruit.com/product/1385 and connect OBD power/ground pins to the device pins 2 and 3 (you need to open the case). This provides the most current to the device and runs it at its optimal performance as well. Once the device is connected you can connect your iOS or Android phone/tablet running the bm3 app to any of the 4 USB ports on the device for a direct wire connection, or, use the WiFi that's on it.
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
10-22-2019, 05:56 PM | #2 |
Rep 191,163
whatnotsomuchf80247.50 |
10-28-2019, 10:55 PM | #3 |
Rep 502
I am still a little confused about what’s needed. Can you please clarify the questions below:
1) if one has the Wi-Fi agent and an iOS device, can the communication connection be made using a USB cord from lightning port (on the iPhone) to one of the 4 USB plugs on the WiFi agent. This means there is no need to create a WiFi connection and app will communicate over the cable? If true, this is useful because Sprint blocks me from making hotspots on my phone without paying them more money. 2) WiFI agent will still need to be powered by being plugged into a USB spot. The center console USB should be sufficient and reliable source of power? 3) are there cable options that can connect directly from ODB port to lightning or USB-C, removing a need for the WiFi agent? 4) I don’t own a laptop right now. Can I have full bootmod3 functionality over my iOS device? 5) unrelated question. Will you offer coding of other computers/modules (steering, MDM, diff) like Thor does for an all-in-one solution? Would it be possible to get EDC coding? My goal is to be able to quickly code when needed with my phone, but I don’t need the phone always plugged in. Thanks |
10-29-2019, 04:23 AM | #4 | |
Rep 1,207
10-29-2019, 08:01 AM | #6 | |
Rep 1,207
See images attached to what I mean... The iPad Pro will come in handy once BM3 release their updated app with the agent built-in. Until then.... a laptop or a BM3 agent device.
10-29-2019, 11:57 AM | #7 |
Rep 502
I am an Apple user, so this might still be the best option.
Main issue for me is that Sprint disabled my use of hotspots. I am on some old plan of theirs. But I could call them to complain to enable that. The rest is simple but it’s described in a complicated way. ProTuning should hire a marketer to clean up messaging and product offerings / descriptions to be easier to use and understand. It looks like their messaging and support is written by engineers that developed the solution (nothing wrong with that when talking to other engineers or developers). If I get a little confused then others might too - which would make them hesitate before a purchase. It should feel plug and play with no chance that I can F it up. There isn’t even enough YouTube videos explaining how easy it is to use (I found two videos). Luckily their support and responsiveness is a huge strength and that goes a long way. This seems like such an amazing product with additional (even larger) market growth opportunity if it’s packaged and positioned slightly better. Last edited by Keca10; 10-29-2019 at 12:06 PM.. |
10-30-2019, 08:33 PM | #8 |
Rep 2,164
Thank you for this post!
I noticed when I had CarPlay enabled, my connection to my WiFi agent is always hit or miss via the standard WiFi connection method. In order to successfully connect to my WiFi agent, I would first need to disconnect CarPlay, then it will work 100 percent of the time, after flashing I would re-enable CarPlay. It was kind of a mess. I tried the USB method last night and it worked 100 percent every time. |
10-31-2019, 04:26 PM | #12 |
Some random guy
292
Rep 312
The answer is.... that's correct. All platforms provide full functionality. (one caveat being the delay between the website/agent updates and those changes appearing on the iOS app, but this is inherent to the App Store approval process and not a bm3/PTF issue)
11-01-2019, 02:42 PM | #13 | |
Rep 1,862
In addition, we've pushed out an update for the agent device. Here's what we've shared in the bootmod3 enthusiasts facebook group: ======= UPDATE: OBD Agent WiFi issues with iOS 13 - confirmed fixed with the LATEST iOS 13.2, but we found a way to get it done on the device as it seemed unlikely Apple would ever address this at this point. If you have an issue connecting over WiFi to your OBD Agent here are the steps to fix it: 1) Update your iOS to the latest version available, currently iOS 13.2 version. 2) Download the latest agent firmware from the Dropbox link below (pushed a few minutes ago), and re-flash your SD card: https://bootmod3.atlassian.net/wiki/...irmware+Update -------- Background story on the issue, boring, if you care: As many of you know Apple's release of iOS 13 has seen a number of issues all over which they've quickly patched over the past few weeks with a number of releases. One of them however hasn't been fixed and it had to do with changes to how wifi hotspot-ing worked. They seemed to have changed the internal key that the wifi network on iOS gives out. We redid the entire image from scratch and set it up again fresh and everything just started to work again as before. ========
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com Last edited by proTUNING Freaks; 11-01-2019 at 02:48 PM.. |
11-22-2019, 03:00 PM | #14 |
Rep 1,303
Drives: 2021 C8 Corvette 1LT
So just to verify, v0.10.083 of the BM3 app on iOS supports using lightning to Ethernet adapter, connected to an ENET cable, to flash my 2020 z4 M40i with the B58 motor?
If this is true, can we use a Bluetooth wireless OBD adapter as well (theoretically)?
Project Car: DF Goblin
-Built LSJ-T 2021 C8 Corvette 1LT 2021 Model Y Performance |
03-30-2020, 04:20 AM | #15 | |
Rep 40
Hi! Is the pin16 a permanent +12 that will slowly drain the battery, or will it power off at some point ? Thanks Last edited by luke79; 03-30-2020 at 04:28 AM.. |
06-14-2022, 02:40 PM | #16 |
Rep 38
Reviving an old thread because I can't get a direct answer, even from BM3. Can you connect directly from the OBD port to an Android device's (my installed Avin head unit) USB port without a "hardware agent" in between? About to drop $900 on an app & doesn't make sense top spend $200-300 more & then have more hardware to hide to simply make a USB connection. Not at all interested in the wifi device, mainly because I don't want another box taking up space & that also needs power run to it.
2006 530xi - Sapphire Black (sold)
2013 X5 xDrive50i M Sport - Carbon Black Metallic (totaled) 2019 R nineT Scrambler - Brushed Aluminum 2016 X5M - Long Beach Blue Metallic |
bm3, bootmod3, usb, wifi |
