06-19-2019, 06:06 PM | #1 |
Rep 1,207
BM3 - Exhaust Burble Settings (OEM, OTS, Original) ?
Q1. Does anyone know the inbuilt values for the 'exhaust burble settings' for OEM, OTS, Original for Stage 0+ (M4 CS) map?
Q2. What is the difference between OEM and Original? I think a compilation of a table like this may be useful... for each BM3 free map. proTUNING Freaks Do you already have this published somewhere? It helps users to understand what the differences are between OEM, Original and OTS settings? Example of a table...
06-19-2019, 07:45 PM | #2 |
Rep 1,201
All Off
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration 1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder |
06-20-2019, 02:23 AM | #3 |
Rep 1,207
Apologies, Did not understand your post.
Do you mean everything is default set to 0 in OEM, OTS and Original settings ... or did you mean that your ‘custom’ settings for burbles is all OFF - i.e. no burbles.
06-20-2019, 02:47 AM | #4 |
Rep 1,201
Custom Settings for burbles is all OFF - i.e. no burbles...the way the car should sound.
10-14-2019, 11:48 AM | #8 |
Rep 191,135
Why?
08-09-2020, 07:18 PM | #12 |
I Drag Race My Track Car
200
Rep 226
Soft 2400 rpm .4 seconds. Literally just a pop or two. Sounds semi natural. The way some of these kids of them set up on some of these cars... my god.
ProSpoolFreaks Tuning E85
CBC Squad |
08-09-2020, 07:48 PM | #13 |
Rep 711
Set everything to max. Get a flame tune. Blow your turbos. Post a thread stating you don’t know why turbos blew. Blame SCH prior to diagnosis. #forumlife
horsepower_and_hounds1837.00 |
08-09-2020, 08:04 PM | #14 |
Rep 5,178
OP is NOT asking our opinion on burbles on/off or settings. He's asking about the settings, not the sliders.
Here's the details from the Bootmod3 manual (p48): https://bootmod3.atlassian.net/wiki/...n=1&api=v2 1) OEM – will set the map to the vehicle's OEM burble settings. 2) OTS – will set this map up with the latest released OTS Exhaust Burble setting. 3) Original – uses this map's original values. If it's a custom map, it will use the settings from inside the map which the custom tuner configured. If it's an OTS map, it will use the maps original OTS values. If the map is Stock tune, it will use the stock tune values, equivalent to using OEM setting. 4) OFF (Disable) 5) Custom – allows the user to customize this map's exhaust burble settings. —Default Settings: — (I think this is Stage1 since the manual says "this map" and previously they show the Stg1 93 no-AGG) Duration = 1 second Duration (sport) = 1.5 seconds Aggression = 5 Min. RPM = 1200 Max. RPM = 5600 Min. Speed = 0km/h Max. Speed = 100km/h
gspannu199.50 |
08-09-2020, 08:23 PM | #15 |
Rep 291
When i choose custom i think some bugs apear, after starting the car it take a lot of time to activate burbles, somehow i can’t put car in launch control all times and if traction control is fully off burbles not working. With burbles on original it works imediatly aftery starting the car, launch control enter very easy after warmup and burbles not stop when TC is fully off.
08-13-2020, 01:11 AM | #17 | |
Rep 64
Drives: 98.5' E36/M3 15' F80/M3/6SPD
So, i have the same issue, i have a custom setup for burbles, and after first start i dont get an burbles, but after 1 min or less the burbles come into affect. i like it, i did a minimal burble, sounds natural so i'm happy with it. I hope you find what you need.
08-13-2020, 04:28 AM | #18 | |
Rep 291
08-13-2020, 05:25 AM | #19 |
Rep 389
Drives: 18 BMW M2LPower
13 BMW 335ix Full Weight 10.64 @129mph N55 WR SOLD
15 BMW M4 Full Weight 10.69@133mph stock turbos SOLD 18 BMW M2LPower 9.69@147.4mph 1.66 60ft michelin 4s tires instagram @luchocampusano YouTube Lucho Campusano |
Commanderwiggin2051.50 |
08-19-2020, 10:39 PM | #20 |
Rep 64
Its not supposed have any affect by traction or not. Did you save the custom settings when you modify the burble.. Sorry for the late reply, my bimmerpost isnt working well.
bm3, bootmod3, burbles, exhaust, map, oem, ots, tune |
