12-14-2021, 07:44 PM | #1 |
Rep 844
Can you claybar PPF & Ceramic coat?
Wondering if this will ruin my ceramic coating?
if so what products do you reccomend, Im guessing soft clay and some quick detail spray? Cheers
60-130 mph 6.72 secs
1/2 mile trap speed 158 mph ecutek - bend calibration pro tune - flex fuel - mpe - stock turbos - oem+ |
12-15-2021, 03:04 PM | #2 |
1318
Rep 1,996
Is your Ceramic coating ontop or below the PPF? PPF can be clayed.
12-15-2021, 04:54 PM | #3 |
Rep 149
Try chemical decontamination first, something like Iron-X which won't risk marring the PPF or removing the ceramic coating. If the chemical decontamination doesn't work on stubborn contaminants, use fine grade clay and lots of ceramic detailing spray as lubricant, working in small areas using light pressure.
12-16-2021, 01:40 AM | #4 |
Rep 88
12-16-2021, 10:43 AM | #5 |
1318
Rep 1,996
Some people apply ceramic under PPF as PPF has its own top coat.
12-16-2021, 10:54 AM | #6 |
Rep 1,247
Drives: 2022 Taycan GTS, 2018 M4, 2016
You can ceramic coat your ppf. This is what I used on my ppf
https://www.esotericcarcare.com/kami...ace-film-coat/ Use gyeno prep before apply coating To OP You can clay it, it won't remove your ceramic coating. But don't let the claybar sticks on ppf. Very hard to remove |
12-19-2021, 12:43 AM | #7 |
Rep 844
my car has PPF on impact areas, and carbon roof and the entire car is ceramic coated wheels and calipers.
I will try iron decontamination. Where do I buy that?
12-20-2021, 10:47 PM | #8 | |
Rep 356
https://www.detailgarage.com/ca_chula_vista.html? They sell chemical guy products |
papasmurf_m3454.50 |
12-22-2021, 08:18 PM | #9 | |
Rep 844
They are nearby. I also need to ceramic coat my 513Ms like my 666m's so hopefully they have something I can do myself.
12-23-2021, 11:52 AM | #10 | ||
Rep 356
06-25-2023, 04:10 PM | #11 |
Rep 844
Thanks again! I went there to the BMW meet they had a few weekends ago.
Picked up some stuff and it boosted the ceramic right up :happyanim
07-01-2023, 12:13 AM | #12 |
Rep 832
As far as I know clay bar is actually just used before applying PPF to clean the application surface. You don’t want to claybar ceramic coating directly, but I think if there isn’t ceramic coating on top of the PPF, you can use as others have said a light clay on the PPF… just be careful around the edges of the PPF.
07-01-2023, 07:22 AM | #13 |
Rep 1,899
I've never heard of this. As someone else mentioned, PPF will not adhere.
Retired: 2018 BMW M3 CS, 2018 BMW M3 ZCP, 2016 BMW M3
papasmurf_m3454.50 DocL1954.00 |
07-14-2023, 10:42 PM | #14 |
Rep 844
Thanks guys. I tried it on the hood and it was fine. Just a light synthetic claybar.
03-06-2024, 07:37 AM | #15 |
Rep 25
Drives: 2016 M3 6mt
03-06-2024, 08:00 AM | #16 |
Rep 881
I've never heard of ceramic under PPF.
2018 F80 M3. YMB/BLK. ZCP. Three Pedals.
"Education will never be as expensive as ignorance." |
