12-01-2017, 06:32 PM | #1 |
Rep 12,654
New Exhaust System for the F8x - Active Autowerke Signature Exhaust!
Just wanted to share this with you guys, Newly Released for the M3/M4! Active Autowerke F8X Signature Exhaust System Product features include: · Full 304 Stainless 3.5” mandrel bent piping from the downpipes back · 4” 100 cell high flow catalytic converter strategically placed. The cat has been positioned further towards the rear of the vehicle where exhaust velocity is lower which prevents it from being restrictive to exhaust flow. The converter helps dial out any raw fuel smell and also helps smoothen out exhaust pulses for a deeper exhaust note. · The driver side OEM exhaust valve is retained. When the valve is closed all exhaust flow is routed to a straight through muffler. When the valve is opened the exhaust flow is allows to pass straight through to the tips. · The Y-Pipe at the rear muffler is a true 3.5” to 3.5” Y, so there is no diameter drop regardless of whether or not the valve is open, this is especially important for those cars running high boost levels or upgraded turbos. · Designed and manufactured here in Miami, FL. · Brushed Stainless or Matte Black tips standard. A carbon tip option will be released in Spring of 2018 as an upgraded option ($350). · 15whp peak gain over a stock exhaust. As much as 70ft/lb and 30whp gains at lower RPMs. Gains will be amplified with higher boost levels. Last edited by AutoTalent; 12-01-2017 at 07:59 PM.. |
12-02-2017, 08:45 AM | #8 |
Rep 5,524
12-02-2017, 04:28 PM | #10 | |
Rep 2,108
2015 BMW F80 M3: Tractive EDC Suspension / Dinan Anti-Roll Bars / GC Camber Plates / KMP Dual Diff Mount / Girodisc Rotors / GT4 Brake Cooling Kit / PTF Flash Tune / Eisenmann Downpipes / CSF Heat Exchanger / BMS Charge Pipes
2007 BMW E92 335i (SOLD): BMS JB4 / Quaife LSD / Riss Racing DPs / Helix Intercooler / BMS Intake / STETT Charge Pipe / Forge DVs |
12-02-2017, 04:31 PM | #11 |
SLUSHIE
78
Rep 162
Drives: f80 M3 YMB
Woooh... phat
IG: slushie.m3
12-02-2017, 05:34 PM | #13 | |
Rep 3,157
See our Mid pipe Data below http://f80.bimmerpost.com/forums/sho...86&postcount=1 |
12-05-2017, 08:01 PM | #20 |
Rep 12,654
12-06-2017, 11:06 AM | #21 |
Rep 3,157
12-06-2017, 12:32 PM | #22 |
Rep 12,654
active autowerke, auto talent, cat-back, exhaust, upgrade |
