View Poll Results: Which PSS size for the OEM 19" wheel | |||
255/35R19 - 275/35R19 (F8X specific) | 75 | 17.05% | |
255/35R19 - 275/35R19 (Generic) | 26 | 5.91% | |
265/35R19 - 285/35R19 | 108 | 24.55% | |
275/30R19 - 295/30R19 | 62 | 14.09% | |
275/35R19 - 295/35R19 (F8X-F1X specific) | 169 | 38.41% | |
Voters: 440. You may not vote on this poll |
02-09-2015, 08:25 PM | #1 |
Rep 20,741
What Size PSS for OEM 19" Wheels?
I have been pondering on which Michelin Pilot Sport sizes to go with. I find that the F8X in stock form lacks grip and I would like to increase the contact patch width. I also would like to stick with the PSS since I like the tire a lot for DD and have had an excellent experience with it on my E92. It strikes the right balance from me between performance, durability, wet grip and comfort.
See the table below for the summary of my findings. (F c.p. and R c.p. for Front and Rear contact patch width according to Tire Rack) (R % dia and R % dia Front and Rear rolling diameter change in % according to Tire Rack) (TR$ Price for the set before shipping and taxes according to Tire Rack) Simply keeping the stock sizes but going with the standard XL tire instead of the F8X specific tire provides the best bang for the buck. It is the cheapest option, yet provides a 0.7" wider contact patch front and rear. This is the combo I had on my E92 and really loved it. Further, the rear generic 275 has thinner longitudinal grooves in the thread compared to the F8X specific 275, which translates to more rubber in contact with the road. The 275/295 /30R19 combo provides the greatest increase in contact patch width (+1.7" front and +2.0" rear) for a reasonable increase in cost (+$120). The disadvantage is the quite smaller rolling radius (-1.5%/-2.3%). I am also concerned that the 275/30R19 is a rear specific tire with thin grooves and would not be the best in the rain for front tires. The last option consist of moving the rear tires to the front wheels and fitting M5 rear tires in the rear. This option is the most costly when all 4 tires need to be replaced (+$308). However, it can be a relatively cheap upgrade when only replacing the rears. The rolling radius is also quite larger than stock (+2.3%/+1.9%). What is interesting with this setup is that the 295/35 rear is specifically designed to run on the 10" wide wheel of the M5. I added another option to the table: 265-295/35R19. After having driven the 275-295/35R19 combo for a full season, I find the 295/35R19 M5 rear tire to be a perfect fit for the car with improved traction. However, I find the 275/35R19 rear not to be the best fit for the the front. The fact that it is designed as rear tire to be fitted on a 10" wide wheel makes not the best suited in the front on a 9" wide wheel. It is more prone to aquaplaning and tram-lining and loses a bit in sharpness. The bite is strong, but the response is a bit more sluggish where there is a noticeable delay before it takes a set. For those reasons, I will be likely going with a 265/35R19 M0 spec from the AMG GT-S. Since the M0 spec is designed as front tire to be mounted on a 9" wide wheel, it should be a very good fit on the front 437M wheels. With this setup, I will have PSS tires designed optimally for those front and rear positions and wheel widths. I am eager to try it out. What would you guys and gal do? EDIT May 2015 275(*)-295(*)/35R19 REVIEW: OK, so I decided to go with the fifth option and finally made the switch to the 275-295/35 setup last week. I wanted to wait a little before posting a review because I wanted to ensure that the tires were broken in to share proper perspective. I could not be happier . The car seems much more planted with the wider tires. There is much less wiggle from the rear under hard acceleration. Taking on-ramps at high speed (very high speed ), the car feels more stable with seemingly more grip to be had. The car is still very well balanced even with high slip angles and is very easy to position with the throttle. In low speed corners, the wider front tires bite with assertiveness yielding a sharp turn-in. Steering feel and feedback is much improved and the steering has become much more alive, better communicating the pavement surface changes. The drawback is little more tramlining on the highway where trucks left big grooves in the asphalt. Another drawback is that there is a perceptible longer delay before the car takes a set, probably due to the sidewalls of the wider tires ballooning more on the same wheel width. The tires also improved the looks of the car too. I run a stock EDC suspension without spacers (I don't believe in changing the stock offset). The bigger and wider tires fill the wheel wells well. Overall, it seems to me that this 275-295/35R19 setup on the OEM wheels is very well suited to the car . Update June 2015: Just found out about a non-negligible drawback to the 275-295/35R19 setup: aquaplaning . I just drove back home from work in a heavy downpour, and the car aquaplaned much more than it used to on the stock 255-275/35R19 setup. I expected a little more floating, but not that much. The car now gets skittish running through very mild puddles. Update March 2016: I just discovered another drawback of the 275-295/35R19 combo: uneven wear on the front tire inner shoulder. I pulled my summer wheels out of storage today and discovered that the inner shoulder of the 275/35R19 (OE rear tire) installed in the front was significantly worn down. I guess it will cord quite soon. Note that I am running a completely stock suspension with stock alignment. I can only assume this comes from the shape of the contact patch, extra width of the tread and/or stiffer sidewall. EDIT May 2016 265(M0)-295(*)/35R19 REVIEW: I just came back from 2 track days at LCMT in semi-dry semi-wet (including snow ) conditions. So I mostly lapped with the PSS on the car. This exhausted whatever life was remaining on my front 275/35R19 PSS (the original rears). Interestingly, they corded on the inside first. I had already observed the inner shoulder wearing faster. Maybe this comes from the fact that these are intended as rear tires and have a squarer contact patch. So I have decided to install new 265/35R19 M0 spec PSS in the front. After a fair bit of research, I concluded that the 265/35R19(M0) is probably the best option to pair with the 295/35R19(*). I liked the M5's 295/35R19 tire because it was specifically designed as a rear tire to be mounted on a 10" wide wheel, so a perfect fit for the F8X. I really liked the additional grip and stability it provided. So I went on a quest to find the best PSS to mount on the front 9" wheels that would keep the front-to-rear diameter stagger as close to stock as possible when combine with the 295/35R19. There were no 275 PSS that fit that bill, so I looked at the 265. Of the 5 different PSS offerings in the 265/35R19 size, the AMG GT-S' (M0) was the only one designed as front tire for a 9" wide wheel, hence why I stopped my choice on it. First observation from the 265 is the the longitudinal channels in the tread are much wider than the 275/35R19 BMW star spec I had up front. This should reduce the increased aquaplaning sensitivity I had with the 275. The tire is also quite meaty, filling the fenders well. First impression from the short drive from the shop to my house is that there is less feedback coming through the steering wheel compared to the 275, I however cannot recall how it felt with the OE 255 though. There is also much less tram-lining going on, which is a good thing. Update September 2016: Having run the 265(M0)-295(*)/35R19 PSS for the summer, I can attest it is the best combo I have tried thus far. The sensitivity to aqua-planning that experienced with the OE 275 in front is completely gone and there is much less tram-lining. The 265(M0) provide ample grip up front and the car remains quite neutral with only a slight hint of understeer at the limit (which is perfectly fine for a street setup). Due to the rounder contact patches of the 265(M0), there is a bit less steering feel than with the squarer OE 275, but having recently driven an 2016 M4 mounted on the stock tires, the steering on my car with the 265(M0) is a bit more alive. For those wanting to stick with the PSS, the 265(M0)-295(*)/35R19 is definitely the one I would recommend. PICTURES: 275(*)-295(*)/35R19 without spacers 275(*)-295(*)/35R19 with 5mm rear spacers 265(M0)-295(*)/35R19 on Eibach springs without spacers
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 06-09-2017 at 07:15 AM.. |
12
tmspec30.50 IbizaSandro17.00 jninja514.50 aboulfad1592.50 CSBM52721.00 SeatownF8047.00 seattle00993.00 JRV-F82-M4193.00 |
02-10-2015, 05:34 AM | #3 |
Rep 20,741
No, same rim width were used most of the time when comparing same tire width. My guess is that the different contact patch width have to do with different tire construction.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 03-25-2015 at 09:37 AM.. |
02-10-2015, 06:50 AM | #4 |
Rep 5,678
I voted but another option would be 255/35 front and 285/35 rear. I like the idea of staying OEM size in the front as I never found the car lacking in grip there. Yes, it changes the stagger a bit but not enough to matter and probably retains slightly better steering response. I would go that route before the choices above.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
02-10-2015, 07:56 AM | #5 | |
Rep 20,741
Maybe going with the generic 255/35R19 XL instead of the F8X specific one in combination with the 285 rear could be another alternative.
02-10-2015, 09:09 AM | #6 | |
Enjoying driving
388
Rep 1,169
Another point I made in other posts that I'll repeat here is the 2-3% difference you are calculating in rolling diameter from original maybe misleading. The cars' stability electronics work not per wheel or axle, but based on rolling differences between front and rear. So if you select tires that have -1.5% difference in the front, for example, and +2% difference in the rear, your overall impact may actually be 3.5%, which may or may not negatively impact the electronics. I say this because with Porsche the difference between front and rear tire diameters had to be between 0.3"-0.6" per spec, it was not based on % or per axle, they pointed out to me 8 specific dangerous accidents (at the track) in their records that were caused because that tolerance was exceeded. |
02-10-2015, 09:44 AM | #7 | ||
Rep 20,741
See the chart below taken from Tire Rack. For three different 275/35R19 PSS, with three different contact patch widths. I corroborated the missing data with the Michelin.ca website and can confirm that all 3 tires have the same 10.9" section width and 26.6" diameter as measured on 9.5" rims. However, the rim width for the F8X specific tire is not specified. If we assume it was also measured on a 10" rim (OEM size), why would it make the contact patch smaller? This also corroborates my experience. Looking at them side by side, the 275/35R19 on my E92 sat much squarer on the road with more rubber on the road compared to the 275/35R19 on my F82 Quote:
I can attest that when running a sqaure setup on my E92, the DSC became much more intrusive. Further, BMW does recommend a square setup for winter driving. So, IMO, the electronics should be able to "safely" support the difference between stock stagger and no stagger. All proposed combos essentially reduce the front to rear stagger bringing them closer to square.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 03-26-2016 at 01:31 PM.. |
02-10-2015, 09:48 AM | #8 |
Rep 5,678
That's what I would likely try... or should I say that is what I will try when the time comes.
coldfish75.50 |
02-10-2015, 09:53 AM | #9 |
Rep 20,741
The time will come faster than later for me since I corded my fronts at the track last fall
02-10-2015, 10:01 AM | #10 |
Rep 841
IMO
Do what I did, I'm prep a full report before and after H&R springs, 'till now my M4 improves a lot in handling and looks and I had to buy just a pair of OEM rear tires for it.
02-10-2015, 10:04 AM | #11 | |
Rep 20,741
However, my car is also my 4 season DD. I am concerned that the H&R will lower the car too much for winter driving. I am waiting to see what comes out of Eibach.
02-10-2015, 07:31 PM | #12 | |
Enjoying driving
388
Rep 1,169
I do not think, but do not know for sure, a tire company will change the carcass construction for any specific car, that is too expensive to do. When a car company says the tires were specifically developed for their model, I believe what they really mean is the car company has some not-so-specific targets in terms of tires' hysteresis and modulus, and the tire company probably only changes the vulcanization time and/or temp, or possibly modify accelerants or softener levels on one or few layers to come up with something close to that target. Then again, you may be right, who knows. |
02-13-2015, 07:50 AM | #13 | |
Rep 20,741
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 02-14-2015 at 10:09 PM.. |
02-13-2015, 07:56 AM | #14 | |
Rep 5,678
02-14-2015, 10:14 PM | #15 | |
Rep 1,190
02-14-2015, 10:23 PM | #16 | |
Enjoying driving
388
Rep 1,169
Are you saying that Michelin (or other) would actually change the carcass construction for a specific model car within a specific model tire? What I am asking specifically is do you find it feasible for a tire manufacturer to change the compound, Carbon Black levels, number of fiber strands and angles, within the PSS model line for different model cars? If you seriously think that, I'd believe you, but please state some background on this so I can understand it better. TIA. |
02-14-2015, 10:32 PM | #17 | |
Rep 20,741
The shape of the thread cross section as it is molded (straight or angled inward) can have a drastic impact on the width of the thread in contact with the road (contact patch width).
03-05-2015, 04:18 PM | #19 |
Rep 20,741
In an attempt to get more voters
03-07-2015, 10:43 AM | #20 |
///M Uber Alles
332
Rep 1,601
Thank you for your work on this CAM3! For the stupid like me, are you saying that simply switching to the regular PSS tires should improve dry forward grip?
die Welt ist meine Auster 2015 M4, MW, Black Full Merino, DCT, CCB, Adaptive M Suspension, Premium, Executive. Technology, ConnectedDrive, CF Trim, Convenience Telephony, European Delivery |
03-07-2015, 11:51 AM | #21 |
Rep 20,741
I am pretty sure it would.
03-07-2015, 02:19 PM | #22 | |
Rep 1,190
Automakers make a big deal about "specifically developed" tires because the public doesn't know any better. Just like "low pressure Nitrogen filled gas shocks" . . . EVERY shock made today is filled with Nitrogen. It's just fancy words for marketing. |
