06-24-2020, 11:11 AM | #1 |
Rep 1,164
Proper way to wire Wifi Antenna (Carplay)?
Just received my OEM WIFI antenna in the mail. Previously i had taken out the HU to confirm that the wifi antenna is indeed missing, and perhaps the culprit of my spotty carplay connection (which added via coding).
For those who added a wifi antenna, what is the proper way to run the coaxial cable? I saw most people just left it bunched up behind the HU, but is it supposed to be ran to the driver or passenger side? The antenna came with some clips, so i imagine theres more than just bunching it up and tucking it away. TIA! |
06-24-2020, 11:14 AM | #2 | |
Rep 3,070
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
9M711235.00 |
06-24-2020, 03:39 PM | #3 |
Rep 1,164
Thanks Kubax. Plugged it in and what a world of difference, carplay is wicked fast now, no lag (previously it would lag when running waze + spotify simultaneously).
Only issue is now trying to get full screen carplay. Can you PM me a quote to code this functionality? |
06-26-2020, 09:17 AM | #4 |
Rep 760
If you want oem placement then the antenna actually routes down to the passenger side under the carpet on the styrofoam. The styrofoam actually has a channel in it for the cable to sit.
14 Audi S4 (sold)
16 BMW M3 (sold) 16 VW Golf GTI (sold) 20 Tesla Model 3 23 Audi R8 (on order, never came ) |
9M711235.00 Trevorstein150.00 |
06-26-2020, 10:38 AM | #5 |
Rep 1,164
Thanks! Even though its working perfectly, i may just route it to the passenger side for the most OEM placement. Have nothing but time nowadays
01-18-2021, 04:40 PM | #6 | |
Rep 118
01-27-2021, 05:13 PM | #8 |
Rep 200
Nitrile19.00 timothyddc2.00 |
12-27-2021, 07:54 PM | #9 |
Rep 36
Can you run apple car play by plugging your phone into USB or do you absolutely need a Wi-Fi antenna? For reference I have a 2018 M3 that did not come with apple car play. Bought CarPlay from BimmerTech - could not connect via usb after installing the software. Either way I did order the antenna which is currently on the way, but was curious
03-07-2022, 07:07 PM | #10 |
Rep 5
03-08-2022, 12:31 PM | #11 | |
Rep 3,070
Only wireless.
05-26-2022, 12:00 PM | #12 |
Rep 442
Drives: 01' E46 325i / 16' F80 M3
I just did this last night. This is the factory location to mount the factory wifi cable. Under the front passenger floor. I unbolted the seat and lifted the carpet. Fished the cable from the back of the head unit area down the inside of the center console under the carpet to the passenger floor.
mr.paulo.dias
9M711235.00 |
05-25-2023, 07:54 AM | #13 |
Rep 3
05-30-2023, 02:42 AM | #14 |
Rep 538
Just having a bit of a laugh with the antenna location. Personally I’ve put mine behind the idrive unit and stuck it to the back of the hvac. Not sure about the health advantages of having the antenna sitting a foot away from ones “Crown Jewels”
Work guidelines is that we don’t mount wifi access points closer than 2.5 feet to where people sit for extended periods of time. Wifi should be good for 300 feet or even 100 feet with a low gain aerial and transmit power. BTW those part numbers above do include cable / antenna |
