03-11-2017, 02:25 AM | #1 |
Rep 1,969
How to delete secondary cats with MPE
Hi guys
Been running the mpe on my zcp for a couple months now The zcp burbles are definitely more pronounced, but only go off below 4k rpm, so pottering around town the exhaust is full of theatre, great But when im in hills stringing some corners together, and downshifting dropping revs above 4k, the theatre just isn't there. There is the blurt noise when getting off loaded throttle, but it gets drowned out over the wind/engine/road noise Im now looking at removing the secondary cats to increase the volume Is there any other way to do this other than spending 1700 on the fabpseed pipes? I impulse bought the milltek pipes locally for 500 after a long drive last night, but looking at pics i'm going to most likely have to modify them to meet up with the mpe So before i hack these pipes up, is there any easier way to do this pnp? |
03-13-2017, 04:03 PM | #9 |
Rep 4,203
03-13-2017, 04:18 PM | #10 | |
Rep 1,319
Will not fit with factory MPE. Shame that, as although the Fabspeed looks great quality, its just too expensive. We need a cheaper/less costly, alternative. |
03-13-2017, 04:26 PM | #11 |
Rep 4,203
Shit man....I am sorry I missed that. They said in the chat I had there was extra pip and I could gut to fit......here is the mark they sent me. I am sure the custom pipes being made is prolly cheaper this seemed quicker
03-14-2017, 12:13 PM | #14 |
Rep 629
I gutted my secondary cats when I had the exhaust apart installing the MPE. Where it's cut makes it pretty easy to knock them out with a prybar and a hammer or whatever you have laying around. A pipe may work also, but a prybar was nice because the bend allows you to get every bit of the cat pretty easily. Wear a breathing apparatus also. You don't want to breathe that crap in.
03-14-2017, 12:33 PM | #15 |
Rep 1,056
Fabspeed X pipe deletes the secondary cats for less rasp and nice burble. No CEL's tripped on the dash either as sensors are in the primary cats. This X pipe is directly bolt onto MPE assembly. No cutting at all. Remove exhaust can and midpipe. Swap in Fabspeed X pipe directly and clamp it all back together. That's it
2008 SGM Dinan 335i vert
2015 White Diamond GMC Yukon Denali XL |
03-14-2017, 02:27 PM | #16 |
Rep 2,825
dont waste your money on a midpipe.. just delete your secondary cats at a muffler shop for like $100-200
plus, you get to keep your resonator. works out well and cheaply |
03-14-2017, 06:58 PM | #17 |
Rep 1,969
thanks guys, i want this to be fully reversible, hence why i was after a pnp solution'
i have since received the milltek, and lining it up with my old stock exhaust, looks like this will work fine with some minor cutting off excess pipe on mpe side |
03-14-2017, 08:22 PM | #18 | |
Rep 3,659
Drives: 981 Cayman GTS
03-14-2017, 09:11 PM | #21 |
What goes here?
450
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
Anyone know if there is a Milltek distributor here in the states?
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
03-14-2017, 09:13 PM | #22 |
What goes here?
450
Rep 1,356
Why would you cut off excess pipe on MPE side and not the Milltek?
2019 G30 M550i
