06-30-2021, 09:17 AM | #1 |
Rep 191,448
Active Autowerke F8x BMW M2C / M3 / M4 Downpipes w GESI G-Sport Cats
For over 30 years, Active Autowerke has been the one to turn to for high quality BMW performance products. Committed to enhancing the performance of BMWs through the highest quality products is what Active Autowerke is all about. The newest addition to our BMW F87 M2C, F80 M3 and F82 M4 Collection, these F8X catted downpipes are a true testament to our outlook on creating innovative products with performance in mind. Developed for precise fitment on the F87 M2C, F80 M3 and F82 BMW M4, the difference in performance will be noticeable the moment you leave your driveway! This variant includes a pair of 4" ultra high flow GESI catalytic converters (Gen 2 Advanced) that will NOT produce a CEL! The GESI G-Sport Ultra High Output Catalytic Converter features full 304 stainless steel construction, including the substrate. GESI UHO-Series Catalytic Converters are EPA registered and compliant in 49 states and fully OBD2 compliant, perfect for use on 1996 and newer vehicles. GESI proprietary precious metal loading technology ensures greatly reduced emissions, eliminating most "Check Engine Lights". These ultra high flow catalytic converters outperform stock converters and provide a reliable solution to the most common catalytic converter problems. The GESI UHO-Series Catalytic Converters are rated for engines putting out between 500 and 850 horsepower while maintaining a high flow capacity. The reduced back-pressure from this ultra high flow catalytic converter will allow you to maximize your engines horsepower without the harmful emissions. Say goodbye to Check Engine Lights and failed emissions tests! Please Note: These catalytic converters are not legal for use on vehicles registered in the state of California as a result of California Vehicle Code Section 27156 and 38391. NOTE: Federal law prohibits the tampering of an emissions control device. u00a0Mobile Source Enforcement Memorandum 1A, allows for aftermarket parts to be used in the repair or replacement of emissions control systems, provided the emissions are not adversely affected. There is no mention or reference to cell density or converter volume dimension. The GESI catalytic converter will produce emissions that will meet the standards set by the EPA, not CARB. Features: NO CEL when using this downpipe Quicker turbo spool and response Less restrictive, more free flowing Improved low end and mid range performance as well as higher boost levels GESI EPA registered high flow and fully OBD2 compliant Casted upper stainless steel V-Band for precise fitment Withstands up to 1500F Can reach operational efficiency within 9 seconds of startup Easily bolts-on with no cutting or welding required Accepts OEM O2 sensor heat shield Durable construction from TIG welded 304 stainless steel Precise fitment Ultra high flow 400 cell per square inch catalyst EPA compliant for use on OBD2 vehicles (1996 and newer) except in California 304 stainless steel substrate is furnace braised to the mantle for outstanding durability GESI proprietary precious metal loading technology ensures greatly reduced emissions Ideal for Forced Induction Applications with no loss of HP Both passengers and drivers are safe from harmful emissions and noise Covered by 5 Year / 50,000 Mile Warranty (on catalytic converter) Made in Miami, Florida
06-30-2021, 10:00 PM | #2 |
Rep 571
So these should pass emissions right? I bought the single midpipe from you, it might be too early but any sound clips? Please DM me with pricing.
Edit: never mind. I'm sure it's a quality product but that's a bit much for a DP for me
"If you have everything under control, you're not moving fast enough"
rborane241.00 |
07-01-2021, 08:40 AM | #3 |
Rep 191,448
Im not allowed to answer emission questions as the answer varies from one state to the other. the cats are EPA approved and the downpipes do not throw a check engine light even on non-tuned cars
07-02-2021, 12:54 AM | #4 |
Rep 3,730
Someone dyno these bad boys
I wonder how they will hold up to full E85 boost levels. Would be nice to have a catted option to minimize rasp and smell.
07-02-2021, 08:34 AM | #5 | |
Rep 191,448
These cats flow just as much as the 200 CEL cats used in other catted downpipes
hellokitty2899.50 HermanL60.00 |
07-02-2021, 11:41 AM | #6 | ||
Mike: Everyone's Pal
2046
Rep 2,972
I wonder what the gains are these vs stock
[CENTER]
2021 6.2L Trail Boss, 6" BDS lift, Chevy Performance intake, 35" Nitto Grapplers, 20" Fuel wheels |
07-02-2021, 01:03 PM | #7 | |
Rep 191,448
i had the Evolution Racewerks catted downpipe. GESI cats flow just as much as the generic 200 CEL cats from all the dynos i have seen.
07-09-2021, 08:33 AM | #9 |
Rep 191,448
Its higher flow than stock, sounds a lot better and more aggressive + no CEL
07-20-2021, 01:15 AM | #10 |
Rep 3,730
I wish AA would make a video of how these sound compared to stock.
WarMachineM356.50 |
07-23-2021, 08:46 AM | #11 |
Rep 469
07-23-2021, 09:38 AM | #12 |
Rep 191,448
Hi,
these are built to order, takes on average 1 week to ship Edit: 3 weeks
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 07-26-2021 at 12:22 PM.. |
07-23-2021, 09:57 AM | #13 |
Rep 469
07-26-2021, 09:41 AM | #14 |
Rep 191,448
They are built to order
07-26-2021, 09:46 AM | #15 |
Rep 1,044
Drives: 2018 M4 Competition
The price point on these warrant a BTO type of inventory. They initially had a few sets (of course) but they should update their verbiage.
Instagram: Slaughter.Mode
07-26-2021, 11:17 AM | #16 |
Rep 469
07-26-2021, 12:22 PM | #17 | |
Rep 191,448
I see you cant add it to your cart on their website, which is another reason to get it from us instead
07-26-2021, 12:53 PM | #18 | ||
Rep 469
07-26-2021, 02:16 PM | #19 |
Rep 191,448
08-16-2021, 11:59 AM | #21 |
Rep 3,157
Now in stock expected shipping date is next week.
TractionControlDelete4602.50 TideMD291.50 |
08-16-2021, 02:00 PM | #22 |
Rep 191,448
