      07-31-2016, 03:07 PM   #1
CARTYPE
Drives: 2015 BMW m4
Emissions test with JB4
I bought an M4 that has the JB4 S55 system on it and wonder if there is anything I need to do when I take it for emissions testing (in Illinois).
The seller told me to…
"Change to map 0 and then unplug OBD connection. This will bypass the JB4 and go back to factory tuning. Plug it back in when done and return to map 2."
Just want to be sure this correct and that it won’t un-do anything.
It also has this exhaust…
http://tagmotorsports.com/akrapovic-...-f80-m3-f82-m4
he mentioned that…
"I’m not sure how the downpipes will effect the test. You could reinstall the factory ones temporarily. If you do, you will have to run map 1 while the factory downpipes are on. Map 2 requires the aftermarket downpipes."
Naturally, I am hopeful that I won’t have to do that and am wondering if anyone has a few minutes to clear this up for me and let me know your views. This is all foreign to me.
      07-31-2016, 04:50 PM   #2
tuan409
Drives: bmw m4
You need to put the original downpipe back in before smog test. And right now ur not getting check engine light because jb4 is set to auto delete code. Once you put the original downpipe in you have to drive it around for like 30miles or so before going in for a test. The akrapovic downpipe u got on is catless and stock has cat. Jb4 map 0 and unplug obd plug.
All u need to know about jb4
http://www.n54tech.com/forums/showthread.php?t=25401
      07-31-2016, 06:56 PM   #3
mercedesc63
mercedesc63's Avatar
Drives: 02 BMW Z3M Coupe S54 Slicktop
he mentioned that…
Here in CA I think they don't require smog checks for new cars (upto 6 years old).
Gone but not forgotten:
2007 E63 M6 SMG, 1999 996 Carrera Cab AT, 2007 & 2008 E90 335xi AT, 2011 E93 M3 DCT, 2X 2002 E46 M3 SMG & 6MT, 2016 F80 M3 DCT
      07-31-2016, 08:01 PM   #4
EALm4
EALm4's Avatar
Drives: SO 16' M4
Talk to a shop and get an emissions waiver.
      07-31-2016, 08:06 PM   #5
clutchdj
Drives: a few cars
bottom line is you have to reinstall factory downpipes or weld in HiFlow cats into your catless downpipes in order to pass emissions (in map 0 or with the jb4 unplugged) in most states. This is a fact.
After welding in HFC's, they would also have to be at least 400 cel cats along w/ 02 sensor spacer(s) (probably post cat) in order to trick the exhaust stream readings by the ECU. again the emission test would have to be in map 0 or totally disabled.
JB4 combos that run catless will never be in a factory ready state because they are constantly running loop code that will not allow the readiness codes to complete their cycle. that is why you have no cel with downpipes. Essentially the car will never be in a factory "ready state". Even w/o JB4 if you are catless, you will most likely not pass in many states. check you local emission testing laws.
      07-31-2016, 08:45 PM   #6
BMW M4 PWR
BMW M4 PWR's Avatar
491
Drives: Austin Yellow 6-spd manual M4
You're welcome...
https://www.amazon.com/simulator-***.../dp/B01A9NC26W
      07-31-2016, 09:34 PM   #7
EALm4
EALm4's Avatar
Drives: SO 16' M4
Originally Posted by BMW M4 PWR View Post
man no way that works. How the hell does it even install? Spliced into the 02 sensor?
      07-31-2016, 09:49 PM   #8
BMW M4 PWR
BMW M4 PWR's Avatar
491
It's already proven to work on the N54's AND N55's. And the company claims it will/and has worked on the S55 as well. Yes I believe they are spliced in. A real game-changer for those not wanting to worry about emission testing again with their cat-less DP's...
      07-31-2016, 09:53 PM   #9
EALm4
EALm4's Avatar
Drives: SO 16' M4
It's already proven to work on the N54's AND N55's. And the company claims it will/and has worked on the S55 as well. Yes I believe they are spliced in. A real game-changer for those not wanting to work about emission testing again with their cat-less DP's...
Shit I'm applying for an emissions waiver when time comes.
      07-31-2016, 10:04 PM   #10
BMW M4 PWR
BMW M4 PWR's Avatar
491
Thats not a bad route either in MD if you got a connect. But this solution will eliminate that problem indefinitely without anymore hassles as it keeps your ECU reading a correct "steady state" feedback to pass the OBDII test... no need setting your CEL delete on either as you won't legitamentally get one.
      07-31-2016, 10:59 PM   #11
psedog
psedog's Avatar
483
Drives: '16 AB 6MT F80
Nice. Hadn't heard of this before. Considering my last smog with my las car they only hooked up to the ODBII port this might pass smog
2016 Azurite Black F80 6MT
      08-01-2016, 08:15 AM   #12
stevenc
Coming Soon
Drives: 2015 BMW M4 Alphine White MT
When you have downpipes, the car will throw a code. The JB4 is setup to delete the codes right away so you never see the code. When you disable to JB4 to go for emissions, the code will return and you will not pass.
You need the BMW computer to think you have stock downpipes. You either reinstall the stock downpipes or you try the mini cat / O2 simulators which try to trick the BMW computer into thinking you have stock downpipes.
Bottom line is you will have to do something in order to pass any type of emissions test.
      08-01-2016, 07:09 PM   #13
CARTYPE
Drives: 2015 BMW m4
Originally Posted by Railgun View Post
http://epa.illinois.gov/topics/air-q...-testing/index
What year is your vehicle? You don't need to test it until 4 it's four years old.
Only folks from Illinois should really chime in here since each state is different as mentioned. California should definitely not comment.
Its a 2015 M4
      08-01-2016, 07:12 PM   #14
CARTYPE
Drives: 2015 BMW m4
I wasn't aware that this was even possible. Any shop can do this? Any requirements?
      08-01-2016, 07:21 PM   #15
EALm4
EALm4's Avatar
Drives: SO 16' M4
I'll send you a PM
      04-14-2018, 12:08 AM   #16
LukeM15
LukeM15's Avatar
Drives: M3 G80 Comp Xdrive
I'll send you a PM
I need info on this too. Thanks
akrapovic, emissions, jb4
