      02-24-2019, 04:29 PM   #1
tyler_smith616
Drives: 2015 Mineral Grey M4 Coupe
M4 engine squeal/noise
Hey everyone, longtime reader of the forums. My 2015 m4 recently started to make a noise at idle, it only happens when it is warmed up, and the car is at idle (both in gear coasting and neutral). Once you rev it above 1800 it goes away. It is also not there when the engine is cold. Please help!
Miles 58k, video link :
      02-24-2019, 04:30 PM   #2
tyler_smith616
Forgot to add: it is not engine or speed dependent. The noise stays the same.
      02-24-2019, 05:27 PM   #3
uniqueMR
uniqueMR's Avatar
1883
Drives: ...
Sound like something is loose.
Have it checked at any BMW center.
Currently: '24 Mercedes G63 | '24 Porsche GT3 RS | '24 Volkswagen GTI
Previous BMWs: 340i, 740i, 745Li, M3, M4
Previous Others: Audi, Ducati, Honda, Infiniti, Land Rover, Mercedes-Benz, MINI, Mitsubishi, Porsche, Toyota, Volkswagen
      02-25-2019, 05:50 AM   #4
HomoPirate
HomoPirate's Avatar
Drives: Always BMW
Tow it to a shop, better safe than a new engine.
Considering @58k, you're out of warranty.
Past: E82 135i Crimson Red | MPE | MHD Stage1+ | Dinan Camber Plate | LCI Blackline | Bavsound stage 1 | KW Coilover V2 |
Past: E93 M3 Vert Alpine White | Remus Sport Exhaust |
Past: F82 Yas Marina Blue Civic M4| MPE V2 | DP | BM3 | Apex FL-5 | MP Part(s) |
Current: F87 M2 Competition Long Beach Blue | Completely Stock |
      02-25-2019, 09:01 AM   #5
Poiseuille
Poiseuille's Avatar
Drives: 2016 M4 DCT Tanzanite/Amaro
  [0.00]
  [10.00]
belt pulley(s)?
      02-25-2019, 12:29 PM   #6
wdskukm3
wdskukm3's Avatar
Drives: 2015 F80 M3 and Model P3D
Could be a belt tensioner or a pulley. Or even water pump. Something is not balanced.
M Forever!!!!
      03-09-2019, 08:06 PM   #7
GearRex
GearRex's Avatar
Drives: G80 M3, E46 ZHP, 991.2 Cabrio
Was this ever resolved?
      04-16-2019, 11:44 AM   #8
Jimmyjamesphan
Jimmyjamesphan's Avatar
Drives: M3CS
I have the same problem. Did you ever figure it out?
      04-21-2019, 10:33 PM   #9
drgmt
Australia
985
Was this worked out?
Would really like the info
      06-26-2019, 09:21 PM   #10
Already5am
Already5am's Avatar
68
same thing just happened to me at about the exact same mileage!!!
      06-27-2019, 02:36 AM   #11
MPOOR
MPOOR's Avatar
Drives: F80 M3 / WHITE
sounds like a vacuum leak. I could be wrong. I am not a mechanic.
What shall i buy for my next track toy
      06-27-2019, 01:43 PM   #12
bedboy
Drives: 330i
Try to open oil cap. If it helps then PCV VALVE
rocc0.00
      06-27-2019, 02:34 PM   #13
yayaya
Drives: BMW 335xi E92 N55
Had this noise on my N55 engine it was valve cover gasket.
      07-26-2019, 06:13 PM   #14
Patricio Garrido
I had this noise too, you resolved ?
      07-28-2019, 02:46 AM   #15
Patricio Garrido
Hello, my M4 2014 starting make same engine noise. Anybody with same trouble and resolved ?
      07-29-2019, 04:41 PM   #16
rocc
Drives: BMW Z4 E89 35i
Thank you!! Had the same noise after a few miles with a new PCV valve in my E89 35i.
      08-15-2019, 07:39 PM   #17
ocbeemer
Drives: 2015 BMW M3
S55 PCV system problem
Same thing happened to my 2015 M3! Here is mine sound and explanation to the fix..
This is a video of the loud squeal I was getting from my S55 engine. After taking it to a local performance shop, I was able to find out that it was the PCV system instead of a pulley like I originally thought. The sound got better at higher RPM and was repetitive based on engine RPM so that pulley was my original assumption.
After getting it looked it at, turns out it was the PCV system which seems to be an issue on a lot of different BMW engines. In my case, the valve cover houses a PCV valve that ended up tearing which usually causes either vacuum or overpressure. Mine ended up causes an overpressure in the system which found relief by blowing out the rear main seal on the engine.
Needless to say, quite costly repair as needed a new valve cover and rear main seal. Not the most expensive parts, but the labor is fairly extensive so ended up costing me over $2K.
I hope this video helps you get the answers your looking for to fix your squeal!
      10-25-2019, 11:17 PM   #18
red_guapo
Drives: Black M4 DCT
just had this issue on mine @ 55k. PCV valve, which means new valve cover.
      12-26-2019, 06:12 PM   #19
Michell
How long you run the car ?
How you know the rear main seal was damage ?
      04-24-2020, 09:01 AM   #20
Andrew30azs
Drives: BMW m4
Did you resolve the problem ?
      06-26-2020, 06:09 PM   #21
ac419
ac419's Avatar
Taiwan
19
Drives: 2015 BMW M3
2015 BMW M3  [0.00]
mine just started having this sound too. mine isn't as bad, but i'll take it to the dealership just in case
      08-04-2020, 10:24 AM   #22
Magic M4
Magic M4's Avatar
48
Drives: F82
I’ve got the same issue what’s the fix
