      05-12-2017, 08:15 PM   #1
Caliboy951
Caliboy951's Avatar
Drives: 2016 M4
Stoptech versus the others
I have the opportunity to pick up a set of Stoptech BBK for $2700 for the front and rear with pads but everything I read is always Brembo should I go with it? I'm setting up a track car with some street driving so I need something that's going to work.
I had a meeting with Boris Said and feedback was tires, brakes and suspension. I have the rims and tires but I'm unsure about the brakes and I'm going with JRZ next month.
      05-12-2017, 10:57 PM   #2
F3IGHTY
F3IGHTY's Avatar
210
Don't get them, and send me the info instead
ccondo160.50
      05-12-2017, 11:23 PM   #3
ashmostro
Drives: 2020 M4cs | 2022 M550i
Any bbk of good name will work perfectly fine for track days. I run stoptech myself but brembo, ap, Sparta will all do the job well if designed for the application.
Also, that's a good deal if the kit is in good shape. Check the seals, hardware, etc for completeness and condition before buying.
      05-13-2017, 10:46 PM   #4
Mike991M4
Drives: 2017 M4
stoptech's are awesome. I have a track only 370z and the stoptech trophy brakes (which are slightly lighter and anodized instead of painted), and they perform flawlessly.
      05-13-2017, 11:23 PM   #5
ccondo
ccondo's Avatar
161
Drives: 2017 BMW M4 - Ferrari Red
I had stoptechs on my e92 m3 and loved them.
      05-15-2017, 11:30 PM   #6
HP Autosport
Supreme Allied Commander
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
You will have no issues with them. You will also have more pad selections at lower prices. Replacement rotor rings are also one of the least expensive in the industry.
      04-02-2018, 07:51 PM   #7
ANILE8
ANILE8's Avatar
Drives: Z4 M Coupé - Carbon Black
What the hell
That is a crazy good price, was that used?
Any pics of the Stoptech's installed?
Nitron NTR R3 | StopTech Trophy Sport STR-60 380x32mm / StopTech Trophy Sport STR-40 355x32mm | Bridgestone RE-71RS | ADV.1 | CDV Delete | TMS Rear Camber Arms | RE Diablo's | 4.10 Gears | Euro Headers | RTD REVO1 Short Shifter
      04-04-2018, 12:16 PM   #8
MasterP
Drives: All the M's
ST is a good choice, especially at that price.
You'll have lots of pad choices. You can run the ST60 pad or the AP19 Pad if you want a WA pad vs. the NA pad. Most track pads for BBK's are 18.5mm thick, but you can run up to 21mm thick pads for ST on F8X.
Upkeep cost is lower than most as well.
      04-04-2018, 01:47 PM   #9
NickyC
NickyC's Avatar
17480
Stoptech is fantastic. I've run three of their BBKs on my various cars in the past, and never had a single issue.
      04-04-2018, 02:17 PM   #10
espressoo
Drives: '18 M3 Comp|'23 X5 45e|'24 X7
If I recall, brakes are no longer covered under standard maintenance. For those of you who have an aftermarket BBK, have you ran into issues of servicing your vehicle or getting non-brake warranty issues resolved?
      04-04-2018, 04:35 PM   #11
IK6SPEED
Drives: BMW M3 / AH3
Why would any non-brake warranty issues be an issue with a BBK installed?
About the only thing that could come into question would be the master cylinder and I doubt they would question that.
      04-04-2018, 05:34 PM   #12
Caliboy951
Caliboy951's Avatar
Drives: 2016 M4
Here's the StopTech I picked up and I've been extremely impressed. I make up a lot of time at the track under braking and they have done their job.
I'd like to add that they have the best customer service (it's a long story) but even after I screwed up and mismatched some rotors and pads (100% my fault) they had me drive to their shop and replaced everything at no charge!!! True they may not have the prestige of some of the big names but at the end of the day when I dive into turn 3 at Autoclub coming down from 138mph they stop!
      04-04-2018, 05:35 PM   #13
Caliboy951
Caliboy951's Avatar
Drives: 2016 M4
Originally Posted by ANILE8 View Post
What the hell
I put a couple up.
bmw m4, racing, stoptech, track car
