Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > Regional Forums > USA - California
      09-28-2016, 01:25 PM   #1
SSR Performance
SSR Performance's Avatar
Drives: S55 -F80 / N54 -135i / N55-535
Smile *Downpipe+Intake+Chargepipe Combo* Introducing our M3 / M4 Power Packs
CHECKOUT WHAT WE'RE UP TO TODAY: instagram.com/SSRPerformance
A FEW BULLET POINTS...
• Forget the so called "BMW Tax", we will never overcharge for our work. A fair price is our promise to our customers..
• Brand new facility in the heart of Orange County (located just a minute away from Crevier BMW)
• Our knowledgeable and caring staff will make sure your car is handled with the highest quality and care in the industry (just ask any of our previous customers!)
• Our 5 Star rating across the board speaks for itself...
[center]
SUSPENSION
Emmanuele Design eMMOTION Lowering Spring Kit (M3 / M4)
MSRP $350
Install $250
Total: $600
Our special price $450 (includes springs and installation)
KW Height Adjustable Spring (HAS) (M3 / M4 / M2)
MSRP $870
Install $450
Total: $1320
Our special price $1100 (includes springs and installation)
BOOTMOD3 TUNE
Here at SSR Performance we offer only the best when it comes to tuning and ECU calibration for your S55 engine. Bootmod3 is the most highly developed flash tuning software for your F series BMW. SSR Performance was the first shop in the US to be running a full flash on both the S55 and S63TU engines. With extensive experience and expert support, you can rest assured that SSR Performance should be your first choice when it comes to Bootmod3 for your vehicle!
S55 Engine (pump gas):
Stage 1 Tune - estimated gains of 55whp / 65wtq (stock vehicle)
Stage 2 Tune - estimated gains of 90whp / 95wtq (most popular - requires SSR Performance competition downpipes)
- Mobile app (iOS and Android) and Web (http://www.bootmod3.net)
- One OTS map/tune included with the purchase
- Datalogging over 200 diagnostic channels, up to 40 channels concurrently
- Datalog sharing and charting without a need to upload to 3rd party websites or apps using the mobile app or web browser
- Cloud based storage for map data and datalogs
- Reverting back to stock performance map
- Live Dash - realtime vehicle parameter monitoring via in-app guages
- Diagnostics
- Read and clear trouble codes in all vehicle modules
- Reset learned adaptations (octane, knock, Valvetronic, etc)
- ECU power reset
- (Optional) Off the shelf (OTS) tunes for 91/93/Race gas/E85 octane
- (Optional) Custom tuning for non-standard vehicle hardware and alternative fuels such as E85 and race gas
- Customization of an existing OTS map
Just a few of the map features provided:
- Top speed limiter removal
- GTS Exhaust "Burble"
- Higher rev limiter
- Cold start cat heat cycle and cat efficiency check removed (for off-road use)
- Maps for upgraded turbos
- E85/blend, race gas and meth injection tuning
- Custom Throttle mapping
- Backend Flash maps for use with piggybacks
Install only takes us 30 minutes. Walk-ins are welcome. Call us at (800) 438-2808 to get your car flashed today!
SSR PERFORMANCE POWER PACK
3" COMPETITION SERIES DOWNPIPES
5 Reasons to buy SSR Performance downpipes:
- Every single set of downpipes is fitted to the same EXACT, proven, jig to guarantee, direct bolt-on, perfect fitment every time
- SSR downpipes are crafted using ONLY certified 304 Stainless Steel and are TIG welded by our Certified Professional TIG Welder right here in Orange County, CA
- Completely precision CNC machined mono-block lipless / stepless V-band flange design
- Developed and flow tested by our engineers directly on our shop M3 and M4 to provide optimal flow and horsepower gains on the Dyno and on the Track
- No Hassle LIFETIME warranty
> CLICK HERE TO ORDER NOW <
DUAL CONE HIGH FLOW INTAKE FOR BMW M3 / M4
5 Reasons to buy SSR Performance Dual Cone Intakes
- Our contained design keeps the intake filters inside the engine bay where they are safe from unfavorable external elements like dust and water
- Our custom made stainless steel micro-mesh filters paired with an aluminum body design create a very noticeably unique sound that cannot be achieved with traditional style intakes
- Gains of 12+ horsepower after the initial adaptation period
- Engineered, tested, and built in Orange County, CA
- Our precision CNC machined MAF housing is scaled to ensure a smooth idle
UPGRADED DUAL ALUMINUM CHARGEPIPES
5 Reasons to buy SSR Performance Chargepipes
- Our reinforced aluminum designed chargepipes replace the weak stock plastic ones. Whereas the stock chargepipes tend to crack at the thin walled flange to chargepipe transition, our new version is guaranteed not to fail.
- Our custom CNC machined flange has been tested to ensure an air-tight fit even under high boost conditions. Our chargepipes will never leak!
- All of our chargepipes come with optional use ⅛” NPT methanol bungs for use with most M3 / M4 methanol kits on the market
- All hardware, silicone couplers and clamps necessary for install are included
We keep all SSR Performance Powerpack items stocked at our facility in Orange County! Contact us today to schedule your appointment to come in and have our premium parts fitted to your vehicle! (Parts + Installation combo pricing available upon request). Call (800) 438-2808 or email info@SSR-Performance.com now!
CRANK HUB UPGRADE
What is a crank hub and why is it necessary to replace? Checkout this great write up by Litchfield Motors!
"In traditional engines (read: pretty much any other engine made in the last 100 years) the crankshaft attached to the pistons turns the camshaft(s) attached to the valves, via a belt or chain. The gears are locked in place on the crankshaft and camshafts with a keyway, so that the relationship between the pistons and valves is always the same i.e. there is no chance of the valves opening at the wrong time and hitting the pistons. This is known as the ‘timing’ of the engine.
Unfortunately BMW in their wisdom have thrown out the past 100 years of development on the internal combustion engine and instead decided to lock the crank gear to the crankshaft with nothing more than a diamond sintered washer, which offers high friction, and a load of torque from the crank bolt to hold the timing in place. In certain circumstances, a high shock load from changing gear, or harmonics over time loosening the crank bolt, the bolt moves and no longer holds the timing accurately. This may happen over time, or all at once, it seems that every engine is different as everyone’s driving style is different. When the timing goes out by a set amount, it triggers a “Drivetrain Failure” on the dashboard which results in rough running, rough idle and reduced engine performance. When the timing goes out by a further amount the ECU will actually prevent the engine from starting, because of risk of damage. We are not aware of any complete engine failures with OEM components from the crank hub slipping yet, as the ECU does seem to do a good job of shutting the engine down. However once it has slipped, the only course of action is replacement of the affected parts, as they are ‘one use’ only from BMW."
Instead of replacing your crank hub with an OEM crank hub and still leaving your engine susceptible to the same issue happening over again, we offer a full in house service on the Maximum PSI Crank Hub fix! This is a keyed crank hub kit that has been tested run after run after run on 800+ hp S55 engines. SSR Performance has installed more Maximum PSI crank hubs than any other local SoCal facility! We are Maximum PSI's largest installer / distributor. We have put together a complete kit (using the Maximum PSI Keyed Crank Hub) that comes with every vital component that SHOULD be replace when performing this service. Our kit includes the following:
Valve Cover Gasket Set
Front Crank Seal - Crankshaft Seal
Bolt for Timing Chain Sprocket - Intake/Exhaust Camshaft
Cover Seal for Brake Booster Vacuum Pump
Oil Pan Gasket
Engine Oil Pan Bolt Kit (Aluminum)
Coolant / Antifreeze (Blue) (1 Gallon)
Engine Oil - BMW 5W-30 Synthetic (7 Liters)
BMW Oil Filter Kit
[font="Proxima Nova Regular", "Helvetica Neue", Helvetica, Arial, sans-serif][/font]
Checkout our S55 Keyed CrankHub Fix Full Installation Walkthrough Thread!
CHECKOUT OUR CRANK HUB CUSTOMER'S REVIEWS:
"Without having to ask, i was given the whole list of parts that would be replaced, and how they would proceed with the diagnostics, repair, and installation of the Maximum PSI crank hub with all necessary gaskets and hardware..."
Read the full review here: https://f80.bimmerpost.com/forums/sh....php?t=1602929
"Great communication from them, always answering my texts and calls right away even during after hours..."
Read the full review here: https://f80.bimmerpost.com/forums/sh....php?t=1612539
Contact us today to schedule your appointment! Get that peace of mind knowing your engine is safe every time you step on it! Call us or email us today - (800) 438-2808 - info@SSR-Performance.com
UPGRADED PURE TURBOS
Here at SSR Performance we install / sell more Pure turbos than any other facility in the Southern California region! What does that mean? When your BMW is here at SSR Performance it will be done right and it will be done right the first time! We know and use all proper torque specs along with proper installation kits which are necessary when installing turbos. With that said, all o-rings, gaskets, and fluids necessary are replaced at the time of installation. We offer the same 1 year 10,000 mile warranty on all Pure turbo upgrades as we do with all other jobs here at SSR Performance. If you are looking to make some serious power out of your S55 engine then Pure Stage 2 turbos is the next upgrade for you!
[/left]
SERVICE AND MAINTENANCE
If you are looking for reputable and trustworthy maintenance work then look no further! From oil changes to brakes we have you covered! You can expect HIGHER than dealership level maintenance and repair work. We have the best customer service in the area for a reason, because WE CARE. We will always be here to answer your questions, we will stick to our deadlines and always ensure that your car leaves 100% better when it leaves our facility than when it comes in. We offer 100% free of charge full complimentary diagnosis on all vehicles! We would love to take care of your vehicle for you! The following is a list of the items that we can take care of for you:
-Walnut blast - Intake valve service
-Oil Change
-Rod Bearing service / replacement
-Coolant flush
-Transmission flush
-Differential flush
-Spark Plug replacement
-Fuel Injectors
-Valve cover gasket
-Oil filter housing gaskets
-Waterpump + thermostat
-Cabin filter
-Brakes/rotors
-Clutch/flywheel
-Battery
-Turbos
And much much more...
ABOUT US
Started in Southern California by Shah and Zayn, SSR Performance began as an aftermarket BMW parts manufacturer. With the Mechanical and Aerospace engineering backgrounds of both co-founders, designing parts was second nature. Along with the sale of parts came the undeniable need for a location to be able to install these parts. With over 10 years of combined automotive expertise between the founders, the decision was made to open SSR Performance's first location in beautiful Orange County, CA. Today SSR Performance is a thriving business that takes care of any and all aftermarket modifications, repairs, and upgrades on new model BMWs.
At SSR Performance you never have to worry about the "BMW tax". All of our services and installs are VERY reasonably priced with our customers in mind. We have some of the highest ratings on Yelp!, Google, and Facebook, for three reasons. We promise and deliver high quality, honesty, and uncanny customer support! When you bring us your vehicle we will make sure to take care of it as our own.
ABOUT OUR FACILITY
SSR Performance is a BMW full service and install facility with a 7,000 sq ft footprint! We are located in the heart of Orange County in Southern California. Our brand new facility includes a customer lounge with free WiFi, Xbox One (games and Netflix galore!), and free drinks / snacks. We are more than happy to have you hangout at the shop while we get your ride situated! We have a very open shop environment. You can rest assured that you will be able to watch and ask questions throughout your visit
WHAT WE OFFER
Service - From regular oil changes to brakes we can take care of all of your M3 and M4 servicing needs!
Repairs - We can handle all minor and major repairs (including the infamous F8X crank hub failure)
Tuning - When it comes to horsepower increasing tunes, we offer only the best in the business, Bootmod3! We were the 1st Bootmod3 Certified Unlock shop in the United States! When it comes to your DME experience counts! So when you're ready to take your F8X to the next level bring it by and let us handle the rest!
Parts / Installs - We can purchase your new exhausts, wheels, intakes, etc. AND have them installed for the best prices around! We know how much you love to mod your car. We're here to help!
Vehicle Wraps - We offer partial and full vehicle wraps! From chrome deletes to full color change wraps, we have it all!
WHERE WE ARE LOCATED
590 W Freedom Ave Orange, CA 92865
Contact Info: Please feel free to contact us for any questions that you may have!
Website: www.SSR-Performance.com
Email: info@SSR-Performance.com
Phone: (800) 438-2808
Instagram: @SSRperformance (follow us to stay updated!)
590 W Freedom Ave Orange, CA 92865 (open by appointment)
M4RAUDR248.00
      10-06-2016, 11:12 PM   #2
YangEnterprise
YangEnterprise's Avatar
Drives: 16 BMW M4 - JAVA GREEN
Thank you Shah and Zayn for everything! Full review up!
http://f80.bimmerpost.com/forums/sho...1#post20669871
      10-11-2016, 09:48 PM   #3
YangEnterprise
Count me in. Y'all already know what I'm bringing .
      10-12-2016, 04:47 AM   #4
G1n Mast3r
G1n Mast3r's Avatar
183
Drives: Individual F80 M3
Subscribed as I may or may not be able to make it down. But just maybe I can and might be able to bring a few of the guys from the Central Coast down.
IG: @gin_master
2018 M3 Atlantis Metallic | AWE | KW | ///M Performance| RKP | MRG Race Co. | BM3 | RW Carbon | KlassenID
2015 M3 Alpine White III | Gone
      10-12-2016, 11:13 AM   #5
SSR Performance
That's great to hear man it would be a pleasure to have you guys over, and it would be an awesome trip for you guys!
tooshay312.50
      10-12-2016, 11:15 AM   #6
SSR Performance
Yes sir!! Can't wait!
      10-12-2016, 01:24 PM   #7
Pj_213f82
Drives: BMW m4 F82
Cool
Ill see you guys there ...
      10-12-2016, 01:47 PM   #8
mrmoua2u
mrmoua2u's Avatar
Drives: 2018 MW F80 ZCP
Perfect timing. Coming down from Fresno to OC for Thanksgiving. Will come there before heading back home. Looking forward to it!
      10-12-2016, 03:49 PM   #9
blake9220
blake9220's Avatar
Drives: 2015 M3 6MT Matte Indigo Blue
2015 BMW M3  [7.00]
bmwtrix and I will be there!
2015 F80 Matte Indigo Blue/SS Int - 6MT
      10-12-2016, 05:37 PM   #10
SSR Performance
That's awesome! That's why we made it Sunday.. hoping that people who go out of town for the holiday can maybe be back in town for it in time, and those that are down here have a chance to stay a little longer and stop by Can't wait to see you there brotha!
      10-28-2016, 12:33 AM   #11
SSR Performance
Smile Paint Protection Galore at SSR|PERFORMANCE! (Wrap/Clear Bra/Ceramic Pro Specials!)
As many of you already know, we recently announced the Grand Opening of our brand new, reimagined, facility now located just a minute away from Crevier BMW in the heart of Orange County. As a company that always strives to become better and provide only the best for its customers, SSR Performance has also added some upgrades along the way.
We have now added the following to our arsenal:
• Full Vinyl Wraps
• Nano-Fusion / XPEL Clear Bra Installation
• Ceramic Pro Paint Protection
We are pleased to announce our new in-house Automotive Wrap / Paint Protection program. Managed by Jerry and run by his tightly knit and highly experienced crew, this team has been providing top-notch level quality custom auto wraps along with the best customer service for the past 5 years and running. Our new automotive wrap team holds 3M, Avery, Nano-Fusion, and Ceramic Pro Advanced level certifications for full vehicle protection under their belt. Our team is a highly reputable source for full custom wraps ranging from car show to commercial level work. So whether you’re looking to rock a gold chrome M4, or looking to get your company advertised in an innovative way, come down to our new facility and let’s get it started today!
A few bullet points...
Call us at (800) 438-2808 or email us at info@SSR-Performance.com to make your appointment today!
Special F80 Post Member Pricing:
3M or Avery Full Vehicle Wrap (gloss or matte): $2300
We proudly offer both 3M and Avery vinyl film for our full vehicle color change applications. Choose from gloss, satin, matte, or chrome (extra fees apply). Our team holds certifications from both industry leaders 3M and Avery to be able to provide you with the most diverse array of color choices possible. Full vehicle wraps take anywhere from 3-6 days. We never compromise when it comes to quality. Our goal is to have every vehicle leave looking show ready!
Avery Dennison Nano-Fusion Clear Bra (partial): $799
(call us for full vehicle pricing and XPEL Stealth pricing)
We offer primarily High gloss Nano-Fusion film as we work directly with them to offer the highest overall standard in clear bra installation. However, we do have access to XPEL for Stealth (satin) applications.
Partial Clear Bra includes:
• Full front bumper
• Partial front fenders
• Partial hood
• Side mirrors
Nano-Fusion Protection film is a patent pending film technology that makes existing topcoats obsolete. Our team is certified by Nano-Fusion to install the film, so it comes with an industry leading Lifetime Warranty.
Nano-Fusion vs XPEL (Gloss, All tested side by side):
• Harder top coat
• Better optical clarity,
• Slicker surface
• Better durability for stain resistance
• Less UV fading
There are only two films in the industry that all large auto manufacturers trust and Nano-Fusion is one of them. Nano-Fusion Technology infuses the urethane film with clear penetrating protection. Nano-Fusion PPF is more conformable, retains its gloss, and resists yellowing and cracking better than other films on the market.
The proof is provided by the best warranty in the business: Nano-Fusion Protection is backed by a lifetime warranty with a paid labor component if the product fails within the scope of the warranty.
Ceramic Pro Paint Protection Silver Package (full vehicle): Starting at $1250
(Call for Gold package details and pricing)
Our package offer a 5 year warranty through Ceramic Pro and includes an excellent premium durable protection on your entire vehicle. The nano ceramic glass coating will protect your car paint against:
• Scuffing & Swirl Marks
• Discoloring & Oxidation
• Corrosion & Staining
Self-Cleaning Properties:
Ceramic coating on the entire exterior of the vehicle makes removal of tar, brake dust and bug build-up a breeze!
Package Includes:
• 1 layer of 9H on paintwork & trim
• 1 layer of Light on paintwork & trim
• 1 layer of Wheel and Caliper on wheels
Most vehicles will benefit from a full paint correction prior to Ceramic Pro coating, prices vary.
(All above listed pricing subject to change according to vehicle condition / additional accents and / or special body pieces. Pricing is based on stock M3 / M4 applications only.)
Call to make your appointment today! Please feel free to call us for any questions anytime at (800) 438-2808. You can also email us anytime at info@SSR-Performance.com.
      10-28-2016, 12:47 AM   #12
allen3ybq
allen3ybq's Avatar
448
Drives: BMW M3
That's cool! I might just stop by and check you guys out next time around the area.
      10-28-2016, 12:49 AM   #13
SSR Performance
That would be awesome man! You're welcome anytime. Just go ahead and give us a quick ring to make sure we're not out of the office!
      11-23-2016, 06:00 PM   #14
SSR Performance
Hey guys! Keep an eye out on our Facebook event link and instagram for a HUGE list of free raffle giveaways that we are going to have for you guys! Go ahead and RSVP to the event for this Sunday!
https://www.facebook.com/events/1993...tive_tab=about
instagram.com/SSRperformance
      11-25-2016, 03:38 PM   #15
SSR Performance
Bump for updates on all our awesome F8X Fest giveaways! (original post updated with giveaways)
      11-25-2016, 06:06 PM   #16
YMB_F80
YMB_F80's Avatar
445
Drives: YMB F80 M3
2009 335i  [7.00]
2015 BMW M3  [10.00]
For those in the San Gabriel Valley and 626 areas stop by iDL Auto Spa for your car wash and detailing needs.
Express Washes start at $35!
841 Meridian St. Irwindale, CA 91010
Email: autospa@idldesignusa.com
https://www.yelp.com/biz/idl-design-usa-irwindale
2015 BMW M3 (Yas Marina Blue)| Toyo Tires | Moton Suspension |
Instagram: YMB_F80
      11-26-2016, 09:02 PM   #17
bmwtrix
bmwtrix's Avatar
162
Drives: 2016 SO M3 6MT
FYI.. Tomorrow's event now starts at 1PM due to weather!!
Soofy209.50
      11-26-2016, 09:48 PM   #18
Soofy
Carholics
Soofy's Avatar
Drives: Z4 GT3
Can't wait to see y'all !!
Z4 GT3 BodyKit | Pure Turbos | Fuel It | LiteSpeed Racing Wheels | GT250 APR Performance Wing | Studio RSR Rollbar | GTHAUS Meisterschaft turbo back | DinMann CF parts | RECARO CS Sportster | JB4 | CSF Cooling System | Full Custom interior | 2M AutoWerks | Viral vinyl werks | Toyo Tires | Ceramic Pro | Oneighty NYC | DOC Race | M3/M4 BBK | SSP Upgraded Clutches | Custom Coilovers with Hydraulift System By Status Gruppe |
      11-26-2016, 11:43 PM   #19
SSR Performance
Thanks man!! That's right. Sorry for the late announcement guys! We had no other choice but to shift the start time of our event from 10AM to 1PM. We want to do what's best for both our visitors and our vendors. To avoid a catastrophic turnout we will be holding our event during clear skies! The event will now start at 1PM and end at 4PM. See you all tomorrow at SSR Performance!
      11-27-2016, 02:44 AM   #20
bmwgirlf80
bmwgirlf80's Avatar
60
Drives: 2016 M3 Alpine White
Awesome! Looks like a great event! Going to try and make it!
2016 ///M3 / Alpine White
      11-27-2016, 09:03 AM   #21
mav
mav's Avatar
Drives: 2017 F82 M4 ZCP
Looking forward to meeting some new people and seeing other M3/M4's!
2017 BMW M4 Coupé F82 ZCP | Photo Journal
      11-27-2016, 01:40 PM   #22
Oreganoflow
Drives: f80
rain or shine?
bmw, ceramic pro, clear bra, event, f8x, fest, install, m3m4, meet, paint protection, shop, socal, wrap
