11-01-2023, 04:49 PM | #1 |
Rep 2,049
Drives: 2017 F80 M3 ZCP BSM 2012 E82 1
Anyone done this mod to convert to the B58 coils?
Kits and coils going for $500 ish. Supposedly 2.3x the spark as the S55 coils, can anyone attest to a difference in performance?
2017 F80 ZCP BSM - Klein Innovation. ActiveAutowerkes. AR Design. BootMod3 Paul Johnson. EvRw. Project Gamma. RW Carbon. UCP. UUC. Hawk. Dinan. NGK. Macht Schnell. TMS. VR. aFe.
RIP - E82 135i - 7/7/2021 |
11-01-2023, 06:21 PM | #4 |
Rep 2,049
I would adjust it it doesn't make sense not to why wouldn't you?
11-01-2023, 07:08 PM | #5 | |
ECUTek Master Tuner
10442
Rep 1,729
Drives: F80 M3 YMB
Yes, I did it and its worth it. Less ignition timing corrections overall.
11-02-2023, 03:16 PM | #8 |
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
[QUOTE=NORAGRETS;30617995]Anyone done this mod to convert to the B58 coils that are on the G80's? Kits and coils go for $500 ish. Supposedly 2.3x the spark as the S55 coils, can anyone attest to a difference in performance?
Wouldn't that be S58 coils?
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
NORAGRETS444.00 |
11-02-2023, 05:16 PM | #9 |
Rep 2,049
[QUOTE=RoundelM3;30620693]Not G80 idk why I said that.
11-02-2023, 06:21 PM | #10 | |
ECUTek Master Tuner
10442
Rep 1,729
Drives: F80 M3 YMB
Correct, you dont need to retune for the new coils. The B58 ignition coil dwell time is very close to the same as the S55.
11-02-2023, 06:58 PM | #11 | |
Rep 696
I'm wondering if different coils have different amount of spark latency (time between being told to fire and actually firing), so potentially impacting your actual spark timing, despite running the same timing map? It would make sense with different windings you get different inductance values, and therefore different latency? I've researched it a bit and found some clues suggesting this, but haven't found anything definitive. |
11-02-2023, 07:18 PM | #12 | |||
ECUTek Master Tuner
10442
Rep 1,729
Drives: F80 M3 YMB
n8dgr84173.50 |
11-02-2023, 08:27 PM | #13 |
572whp Stock Turbos/DP E60 Tune by Tier1Tuning
174
Rep 294
11-03-2023, 09:32 AM | #14 | |
Rep 696
but the focus is ignition of the combustible mixture based on spark energy, so directly analogous. They're basically saying that with higher spark energy, the bigger spark kernel reduces the ignition delay, and increases the initial flame propagation speed during ignition. So it's improving flame propagation and combustion stability by "kick starting" (my own words) the flame propagation out from the ignition point (the spark kernal) through the mixture in the cylinder - this I can get my head around. https://www.sciencedirect.com/scienc...60544221024920 |
11-03-2023, 10:43 AM | #16 |
174
Rep 294
Based on my logs, I don't think upgrading ignition helps significantly until you upgrade turbos. It adds weight, so you have to consider that, as well, if you're a road racer and care about handling.
NORAGRETS444.00 |
11-03-2023, 11:04 AM | #17 |
Rep 2,049
What is it; 2lbs?
ck_M363.00 |
11-03-2023, 05:46 PM | #19 |
Rep 696
03-26-2024, 10:55 PM | #20 | |
174
Rep 294
https://f87.bimmerpost.com/forums/sh....php?t=2092743 |
03-27-2024, 09:02 AM | #22 | |
Rep 2,049
Coils? Sparks? What’s year is your car? I’m beginning to wonder if production date has anything to do with the ability to run the coil swap without issues….
