      03-17-2024, 02:40 PM   #1
canbelto
Drives: M2, M4CS
Carplay ...again! Problem...
Hi all!
New member here. Just picked up a 2020 M4CS and having trouble the wireless Apple Carplay
Here are some points:
- there is a factory option to connect to carplay
- I have done the hard reset (holding the power button down for 70+ seconds and the screen reboots twice
- everytime I try and connect, it goes through the usual motions where the unit asks to be paired with the iphone, and vice versa, so I click yes, etc etc
but it goes reaches the "establishing connection" bit and goes for a while and then says failed to connect. Everytime
Anyone have any tips?
      03-17-2024, 03:08 PM   #2
MFNATIK
Blocked from G80/G82 for having an opinion
MFNATIK's Avatar
Drives: Trek Domane
reboot your phone? Running latest OS updates? Its a 50/50 operation between the phone and the car
      03-17-2024, 03:51 PM   #3
canbelto
Drives: M2, M4CS
Yes. Definitely all up to date on the phone side. Rebooted everything. Quite a mystery
I had a similar issue with my G87 M2 but a hard rest of the head unit fixed that right away. No such luck with the M4CS
      03-17-2024, 03:59 PM   #4
N1rve's Avatar
2019 BMW M4  [9.63]
Ask your friend to try to pair. If it still fails then you know for sure it’s the car. There is an update you can do to get the full screen CarPlay which might also fix your issue.
      03-17-2024, 04:06 PM   #5
canbelto
Drives: M2, M4CS
Oh cool... is this done online of needs to be done instore?
      03-17-2024, 04:08 PM   #6
N1rve's Avatar
2019 BMW M4  [9.63]
There’s a guy on here kubax86 who can sell you the Apple CarPlay full screen. There is an update needed to get fullscreen to work. But like I mentioned before, have a friend pair it first and see if it’s really the car or the phone.
Or if you want full screen Apple CarPlay just to ask Kubax haha.
      03-17-2024, 04:38 PM   #7
WhiteFox
WhiteFox's Avatar
Drives: BMW M4 F83
Full screen Applecar play can be done on NBT EVO via Bimmercode if you have one of the latest updates to NBT EVO
      03-18-2024, 12:10 AM   #8
dbudh001
Drives: m4cs 2020
I just connected mine to Bluetooth. A few days later it prompted me to start using CarPlay
      03-18-2024, 02:24 AM   #9
dezzracer
Drives: 2018 M3 CS
My 2018 M3 CS will not connect to car play anymore. Tried everything. Worked great for four years. 🤬
      03-18-2024, 04:20 AM   #10
kubax86
kubax86's Avatar
Drives: M2
Good instruction when it doesn't work
"Do it the following way:
Make sure WiFi, Siri, Bluetooth are ON and Hotspot is disabled.
Go to MEDiA -> MANAGE MOBILE DEVICES -> ADD NEW DEVICE -> APPLE CARPLAY
On your phone go to Bluetooth and delete the car, then go back and again to Bluetooth and wait until your iPhone finds the car.
Go through the pairing procedure and once you get pop up „Use CarPlay” on your iPhone, click „Use CarPlay” and after that immediately go to WiFi settings on your iPhone and choose CarPlay network (it will have CarPlay in the name). That’s it. Pairing done. You’re ready to use Apple CarPlay and enjoy
HotRodM4687.00
      03-19-2024, 02:20 AM   #11
dezzracer
Drives: 2018 M3 CS
Ok, thank you. I’ll give it a try.
      03-23-2024, 04:20 AM   #12
HotRodM4
HotRodM4's Avatar
Drives: 2018 M4
  [10.00]
Exactly this. My M4 will randomly give issue connecting to CarPlay every couple months but deleting the car from Bluetooth and then reconnecting fixes it.
?18 M4 Comp
      03-23-2024, 11:43 AM   #13
Yuille36
Yuille36's Avatar
Drives: BMW X5M, BMW M3, MB E63 AMG
2015 BMW X5M  [0.00]
I've used Bimmer Remote Coding to not only restore full screen Apple Car Play but also to update my navigation system to a 2023/2024 map update. I couldn't be happier with the results. Also, Bimmer Remote Coding is a cheaper solution than Bimmer Tech.
