R44 Performance
      09-14-2015, 09:40 PM   #1
Myaddiction
Drives: X6M
2015 BMW M4  [0.00]
E85 Mix (E30) tune and downpipes
A few weeks ago I dyno'd my car with just a JB4 on map 7 running on E30 and made 529 rwhp/531rwtq. It is the red line in the dyno graph below.
Data Log here:
If you look at the Dyno you will see the blue line dyno makes more torque but power is about the same. That is my map 6 that has a more aggressive boost curve (534rwhp/550RWtq). It comes up to 26 psi and holds it to redline. Map 7 hits 25 psi and tapers a bit towards redline. As you can see even though it is running more boost, it makes the same amount of power once you cross @ 5300 rpm. At this point there is so much back pressure in the turbine that no matter what amount of boost you run it will make the same or even less power due to the turbo being so far out of its efficient operating area.
I had a set of Dp's at the house and was curious if they would make any power at this level. Based on the dyno results and logs from the JB4 it looked like the turbines were the real restriction due to their small size, not the downpipes. My educated guess was there wasn't any more real hp to be found without changing the turbos or running higher octane fuel/meth that would allow higher timing to get the last bit of power out of these turbos.
I installed the DP's (Shifteck's) and went back to the dyno. I would have loved to do this on the same day but the real world and having a life prevented that. The conditions were the same, mid 90's temps on the same dyno with the same correction and same smoothing value. I made sure I was still running E30 and even checked the tire pressures to control the conditions as much as possible.
Here is the Map 7 dyno over laying the previous Map 7 dyno. As you can see there no gain in horsepower with a bump in torque before the magic 5300 rpm where the small turbines kill the power.
Here is the datalog:
I was curious to see if the downpipes would help if I really pushed the turbos and used map 6 to run 27 psi to determine if the downpipes allowed more power up top. As you can see in the dyno, below 5300 the extra boost provided about 10 more horsepower and more torque but actually less power up top, even with the extra boost.
And datalog:
So, in conclusion it looks like on a E30 tune the downpipes don't provide any real power gains. There is a bump in mid range torque but nothing up top where we really need it. On the other hand with a pump gas tune (91/93 octane) the downpipes add power as we have seen in other dynos.
Appreciate 5
bloke7957.00
      09-14-2015, 10:58 PM   #2
///bproden
///bproden's Avatar
286
Interesting to know. Thanks for sharing! Don't know if i'll run e85 much, but just installed stage 1 jb4 and hoping to get dps installed this weekend to run stage 2. At stage 1 the car seriously came alive. I couldn't imagine your set-up... PureTurbos in your future?
2015 ///M4 - Alpine White - My ED
Executive Package / Lighting Package / Black 19's / Adaptive Suspension / Harmon Kardon / DCT
      09-14-2015, 11:49 PM   #3
YMB_M3
YMB_M3's Avatar
Drives: 2018 BSM M3 6MT
Are you running an e30 mix with 91 octane or 93?
      09-15-2015, 12:51 AM   #4
FC4
Drives: Yes
Very nice data. The turbos are certainly tapped at these levels on E30. Even on 100+ octane unleaded and/or meth, there isn't much upside.
People often fixate on boosting low-end torque when it's actually the top-end which needs to be addressed and will have a greater effect on the acceleration of the car.
      09-15-2015, 01:13 AM   #5
achi 3.0
Drives: BMW M4 F83, Catless Dps, JB4
GREAT NUMBERS
You run E85 and Map7 without downpipes?
Could you send us please your map6 setup...
      09-15-2015, 07:44 AM   #6
bmwm3redblack
bmwm3redblack's Avatar
59
Drives: BMW ///M3 E46, BMW E92 335Xi
nice write up, probably your next mod is pure turbos
Bmw 335xi/FBO/ black on black/ 6sp manual/Cobb AP/BMS DCI/AA BOV KIT/VRSF DP'S/VRSF 7'FMIC /FULLY CATLESS/H&R sport springs/ 19' ac schnitzer wheels.
      09-15-2015, 08:46 AM   #7
Mike@N54Tuning.com
Joint Chiefs of Staff
Drives: 2007 335i, 2015 M3
Thats were the real fun / power starts..
OP, post this in the E85 thread as well if you could
http://f80.bimmerpost.com/forums/sho....php?t=1163913
Mike
      09-15-2015, 04:09 PM   #8
Myaddiction
Drives: X6M
2015 BMW M4  [0.00]
No Problem, wish more people would post up information. I know its out there but we never get to see it.
Crap So Cal 91 octane.
Agreed, These cars have a ton of TQ. We need a solution to the highend power that doesn't cost an arm and a leg.
Originally Posted by achi 3.0 View Post
GREAT NUMBERS
Yep! The downpipes on this car are not a large restriction. I have a JB4 connect so I'm always datalogging and wouldn't recommend it unless there are plenty of datalogs to make sure the car doesn't have a problem with it. I could run higher ethanol content without the downpipes, up to 40%. With the downpipes it seems to like E30.
I can PM you Map 6 but don't recommend it unless you are datalogging a lot and wouldn't run it daily. Only on occasion.
I'm going to wait a bit on the turbos. Pure makes a great product but we need some software to address the DCT. On my GTR with ECUTEK you can just increase the clamping pressure for the clutches. Would love to see something like that and some advances on the fueling limits we have.
Mike
Done.
downpipes, e85, jb4, s55
