ARMA SPEED
      02-22-2024, 10:52 PM   #1
CrazyFlame
CrazyFlame's Avatar
Drives: 2020 BMW M4
2020 F82 M4 Steering Wheel Oscillation/Shaking
Hey everyone,
I see there are already similar threads, but instead of trying to bump multiple old threads I'd like to start a new one. If it's poor forum etiquette please let me know.
Short version:
As the title states, I am experiencing mild steering wheel shaking while cruising at certain speeds (40-45 mph and 70-75 mph). The issue is most prominent if I remove my hands from the wheel at those speeds and look at the seams at 10 and 2. The steering wheel shakes back and forth half a centimeter or less only at those speeds. The dealership is adamant that this is normal but I am not convinced.
Sequence of events:
- Normally functioning 2020 M4 which I've solely leased (and now own) since brand new
- Had dealership replace Michelin PSS tires with PS4S due to normal wear @17k miles
- Noticed mild steering wheel shake as described above, brought car back in for service
- Dealership stated that 3 out of 4 tires were improperly balanced, rebalanced all tires
- Noticed issue was still present but slightly better
- Had tires road force balanced
- Noticed no improvement
- Had tires road force balanced by shop manager and ride-along with shop manager - he says it is normal behavior
I am starting to get concerned as the dealership is not acknowledging a clear issue and I've spent quite a bit of time trying to sort this out. Please let me know if you have any info that can help me figure out what's going on - I appreciate it in advance.
First car: 2002 BMW 330i (grey-green)
Second car: 2012 BMW 328i cabrio (space grey)
      02-23-2024, 10:47 AM   #2
Drifter2090
Drifter2090's Avatar
Drives: E90 M3 | E92 335i | E90 335d
Are you running spacers? or have you tried cleaning the hub surfaces if rusty?
MGM F82 M4 DCT / MPerformance / Swift / CSF / IND / Turner / BimmerWorld
BSM F87 M2 6MT / Fabspeed / MPerformance / Turner / AutoID - SOLD
JB-NB E92 M3 6MT / IND / RTD / Alpine / KW / ActiveAutowerke / 360Carbon - SOLD
SS2-FR E90 M3 6MT / IND / AFE / ActiveAutowerke - SOLD
AW-FR E90 M3 DCT / ACM / IND / AutoTecknic / K&N / H&R / Bilstein - SOLD
      02-23-2024, 10:50 AM   #3
Pauldunlop13
Drives: M4 Convertible
I would take it to a tire shop and have them balance all 4 wheels
the symptom and the exact speeds you mention are 100% in the 'unbalanced tires' range
prob worth doing a front end alignment as well
but no -the dealer saying it is Normal, is total BS
2019 YMB ZCP convertible with Dinan Exhaust
2011 Ducati Diavel Carbon Edition
2015 BSM M4 Convertible - 2018-2019
2016 228Xi - 2017-2018
2003 Acura RSX Type S 2003-2017
      02-23-2024, 11:58 AM   #4
CrazyFlame
CrazyFlame's Avatar
Drives: 2020 BMW M4
I'm not running spacers; the car is stock. The hubs are rusty and have been like that for a while. I was not planning on cleaning them and honestly did not consider the rust as a possible cause until now.
I will probably bring the car to another place and have them balance the tires. Just to re-iterate that I've balanced them three times and had an alignment done once recently, all at the BMW dealership. Interestingly, the shop manager admitted that one of their balancing machines has been poorly calibrated (!) so I could have been unlucky in that regard.
      02-23-2024, 12:39 PM   #5
N1rve's Avatar
2019 BMW M4  [9.63]
Probably a dumb question but is the road smooth? LOL. Does it happen on all roads?
What is your cold tire pressure? This car loves to tramline more than other cars.
When the vibration happens, are you accelerating or just rolling? Too much toe in can lead to some scrubbing feeling.
      02-23-2024, 12:52 PM   #6
AlmondJayRoM3
Drives: 2016 M3
Not normal at all. Ask them to drive with you in another car and prove that it is normal. Or just go to a different place.
As for the fix, you need to check not only balance and alignment but also wheels or tires being out of round. At the same time check for any loose suspension parts. This can be done with the wheels off the ground and trying to shake the wheel at different angles. Plenty of YouTube videos on this.
Last thing to cause a steering wheel shake would be a busted steering angle sensor or an issue with electric power steering. This is not likely because the shaking would be more pronounced than just a vibration.
      02-23-2024, 02:58 PM   #7
CrazyFlame
CrazyFlame's Avatar
Drives: 2020 BMW M4
It's a good question. The roads vary widely because of construction and paving happening in the area, but I have driven on beautiful, newly paved roads and still experienced the issue.
The cold pressure is about 30 PSI for all four tires. The door jam label indicates that the cold tire pressure should be 32 PSI and I have identified the need to add a bit more air. I'm not sure if there's a different PSI suggestion for PS4S tires.
Normally I notice this when I'm cruising at a constant speed with low throttle input, especially 45mph.
I agree that I need to check for the things mentioned in your second paragraph. It's very suspicious to me that the issue started when the tires were changed, so I'm leaning towards the tires being out of round or some suspension component was damaged when they were changing the tires. I know they changed the tires hastily because they left a ton of mounting lubricant all over my wheels! It was tough to clean off.
I'm planning to having someone else look at the car on Wednesday and I will mention all these things. Thanks everyone for the suggestions so far.
      02-23-2024, 03:40 PM   #8
M3SQRD
M3SQRD's Avatar
2161
Yeah, a +/- 1 cm oscillating steering wheel is quite far from normal! If you had no issues with the PSS then it definitely points to the PS4S being the cause/problem.
One thing you could try is have the tires dismounted, rotated 180 deg and then remounted or even remounted on the wheel on the opposite side of the car. Tire being out of round and/or a bent rim will cause a vibration even if they’re balanced properly. If you had a second set of wheels you could quickly find out if the wheels/tires are the problem or if it’s from something else on the car. Definitely take your car to a non-BMW shop because the ones you’ve been going to clearly don’t care about addressing your issue.
      02-24-2024, 07:42 AM   #9
RoundelM3
RoundelM3's Avatar
Drives: 15 F80 M3, 22 G01 X3 30i
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
You may want to check whether you have a bent wheel or wheels - even a slight bend from running over something can affect balance. I had a similar problem after running over an asphalt bump that slightly bent both right-side wheels. Fortunately, there was a Rimguard shop nearby and they were able to straighten both wheels and eliminate the vibration.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey
      02-24-2024, 10:03 AM   #10
CrazyFlame
CrazyFlame's Avatar
Drives: 2020 BMW M4
It's definitely closer to a few millimeters but still noticeable. I agree with everything you said and will try to troubleshoot. I like the idea of using an entirely new set of wheels+tires, but I don't have a new set. I use the same set year round, but maybe this is an excuse to get an additional set
Thanks, I'll check for a bent wheel. Do you think the wheels could have been damaged when they were changing the tires? As stated above, the dealership performed the tire change hastily and I wouldn't be surprised if something got messed up during the process.
      02-24-2024, 04:08 PM   #11
NSX2M4
NSX2M4's Avatar
1378
I would take the recommendation to look into the vibration device attached to the steering wheel. My 2019 had one go bad about 2 years ago and it drove me nuts. I compared the old one to the new and could not tell any difference or notice any play in the shaft but the new part fixed it. It was the slightest bump in the road or imperfection that would make it shake.
      03-01-2024, 01:59 PM   #12
Dré-stylè
Drives: BMW M3 F80
Originally Posted by CrazyFlame View Post
Hey everyone,
Short version:
Sequence of events:
Only thing i read
Car was fine
New wheels
Car not fine
Search for a well known tire shop , let em check first if there is a imbalance and RESET the tires on the rims if not , then check again
i had this with my M3 after i noticed a slab of led on my rims ,, tire was not correctly seated
2020, f82, steering, suspension
