      03-07-2013, 12:39 AM   #1
BigMacSmallFries
Drives: '19 M5C 911 Turbo F430 GT3 RS
Bi-turbo confirmed instead of triple-turbo?
In the Car Magazine article that was published last month, they've stated that the new powertrain would include a bi-turbo instead of a triple-turbo (point #4):
http://www.carmagazine.co.uk/Secret-...t-you-to-know/
Does this mean all bets for a triple turbo are off? I was seriously hoping for a triple turbo engine (two tiny turbos, combined with a large turbo just like the M diesel offerings in Europe). How amazing would it be having near maximum torque just off idle with a set up like this?
Could we get scott26 to confirm this? Also, since this is a next generation motor, and unrelated to the M5/M6 v8, is it possible for the redline to be substantially higher than 7200RPM as found in those?
      03-07-2013, 05:11 AM   #2
AlpWhite11
Drives: 335i
Car Magazine has also tried to pass renders of the M3 and M5 off as real images so they have little credibility IMO.
They may end up being right in the end either from luck or actual knowledge since anyone has a 50% chance when guessing either 2 or 3 turbos. But I'd take their info with a huge block of salt anyway.
      03-07-2013, 05:30 AM   #3
amdmaxx
My gift Registry: M2
amdmaxx's Avatar
Drives: Future Mowner of Monster
No way for higher redline in a turbo engine.
      03-07-2013, 02:09 PM   #4
BigMacSmallFries
The mclaren mp4 spins up to 8500rpm with a twin turbo. I think if this engine was able to hit 8000rpm, a lot of current m3 owners would be pleased.
      03-07-2013, 02:11 PM   #5
BigMacSmallFries
Yea, they present the article as fact, but I hear you. I'd love a triple turbo straight six that can spin to 8000rpm.
      03-07-2013, 05:23 PM   #6
Holset
Sweden
274
Drives: F90 M5 Comp LCI
My bet is 2 turbos in sequential one smaller twinscroll for lower rpm and one larger singlescroll for higher rpm.
      03-15-2013, 01:09 AM   #7
BigMacSmallFries
Yea, so automobile mag is betting on the triple turbo. I think I am too, I find the term "multi" turbo was thrown around by decent sources on bimmerpost on a couple occasions. I feel there would be no reason to use the word "multi" if it was a twin turbo.
http://rumors.automobilemag.com/spie...#axzz2NaNnIxML
      03-15-2013, 03:18 AM   #8
Uli_HH
Uli_HH's Avatar
Drives: AW M3 E90)/ 523i Touring
It is almost impossible, that an I6 based on the N55 can attain an redline of 8.000rpm ... the only BMW turbo engine which would be able to do this, is an S63Tü based V6 - because of his square cylinder design.
This engine, an 3.2ltr.V6 BiTurbo has run into an endurance test on the engine test bench with this 8.000rpm ... which has probably led to the rumors of a redline of 8.000rpm for the new M3/M4 engine
But the probably next M3/M4 engine, an 3.0ltr.I6 TriTurbo will almost certainly have a redline of ~ 7.000rpm.
Greets Uli_HH
      03-15-2013, 08:32 AM   #9
BMW269
M3 E9X: 8.400 rpm
GT3 997: 8.400 rpm
M3 F8X: 7.000 rpm
GT3 991: 9.000 rpm
      03-15-2013, 09:13 AM   #10
DiavelM3
4 Star General -Twilight Zone
DiavelM3's Avatar
Drives: '11 E92 M3 ZCP
Originally Posted by Levi View Post
M3 E9X: 8.400 rpm
GT3 997: 8.400 rpm
M3 F8X: 7.000 rpm
GT3 991: 9.000 rpm
Isn't the 991 GT3 a naturally aspirated engine? Not turbo
'12 Ducati Diavel
'06 E46 M3 (sold) | '97 325is - Dinan (sold)
'02 Z3 3.0 coupe (sold)
Past - '84 Ferrari 308 GTSI | '88 Ferrari 328 GTS | '05 Dodge Viper Copperhead Edition #180/300 | Audi S4
      03-15-2013, 12:07 PM   #11
3M TAPE
3M TAPE's Avatar
M3 E9X: 8.400 rpm
GT3 997: 8.400 rpm
M3 F8X: 7.000 rpm
GT3 991: 9.000 rpm
Why compare a turbo engine to an NA engine?
      03-15-2013, 12:20 PM   #12
Transfer
Transfer's Avatar
5254
Drives: Bronco Wildtrak, Tesla MYP
I'm sure they'll call it a tri-turbo but it will likely be a twinscroll plus single scroll. ///Marketing will be all over this.
      03-15-2013, 01:25 PM   #13
richb811
richb811's Avatar
455
Drives: 2020 G20 330i M Sport
Agreed. Car magazine's credibility is not the best right now.
But
Even a blind chicken can find food once in a while.
      03-15-2013, 04:45 PM   #14
BigMacSmallFries
Greets Uli_HH
How come were assuming that more than just the engine block from the S55 will be used and bored out? the 991 GT3 engine is extremely different than that of the Carrera S even though the same block is used initially. Is there a source that indicated they would be very similar?
Assuming the M5 revs to 7200rpm, I think it would be impossible for the M3 to rev lower than that. I think realistically we should expect 7200 or 7300 as the minimum. 7200-7600 would be expected, 7600-8000 would be a nice surprise.
      03-15-2013, 05:05 PM   #15
Uli_HH
Uli_HH's Avatar
If you use the N55 block to develop the M3/M4 engine, its clear that the stroke was greater than the bore, an layout that make it almost impossible to combine high rpm and high pressure turbos, simply because the resulting forces are going too high ... only with an square cylinder layout it was possible to combine high pressure turbos with 8.000rpm.
      03-15-2013, 05:26 PM   #16
BigMacSmallFries
Ohhhh, thats what you mean by square cylinder. I just call those short stroke, big bore engines aka 'racing engines'. lol I see, so what you're saying is only the stroke length can be increased but not the bore due to thickness limitations inbetween the cylinders. But what if the distance between the cylinder walls on the updated S55 are much thicker allowing for a bore out? I wouldn't assume it would be the same as the N55.
      03-18-2013, 10:02 AM   #17
seanwillnotreturn
Drives: m3
Where does this thoery come from? I am not sure what's the M diesel offering in Europe. But 3 traditional turbo wont work for 6 cylinders, it's basic mechanism. The tri-turbo in rumor is a electric turbo (more like a motor) working at low end to keep traditional turbos alive and disconnected where exhaust start to take over the job.
If the gen to come is to utilize bigger turbos pursuing high end at cost of low end reponsiveness that N54/55 is good at, which is most likely the case, it's not worth the wait at all.
Nobody is going to be fine with a lighter and less powerful M5.
      03-18-2013, 10:47 AM   #18
InspireSiR
Drives: 2013 BMW M3 E92
Theory comes from this:
http://www.topgear.com/uk/car-news/b...50d-2012-01-26
      04-03-2013, 01:32 AM   #19
Thurman Murch
Seychelles
62
Take N55 updates and apply it to the N54 setup... Call it the S55 and have three sources of intake charge air
1. Scooped from kidneys (air cooled ic)
2. Driver lower louvre intake (water cooled)
3. Either passenger lower louvre or from hood
The current M3 provides 3 sources of intake air and so will the new one
It may have a third electric turbo but I'm thinking either N54 set up or dual twin scrolls
      04-03-2013, 02:32 AM   #20
BMRLVR
Grease Monkey
BMRLVR's Avatar
Drives: 2011 E90 M3,1994 Euro E36 M3/4
Greets Uli_HH
Considering that the S54 was undersquare and spun to 8000RPM there is no reason that the "S55" couldn't...... The reason it won't spin that high is because it won't have to since the turbos will allow peak power at a lower RPM than traditional NA M engines.
2011 E90 M3 ZCP - Individual Moonstone/Individual Amarone Extended/Individual Piano Black With Inlay:LINK!!!
1994 Euro E36 M3 Sedan - Daytona Violet/Mulberry:LINK!!!
      04-03-2013, 10:32 PM   #21
mkoesel
Moderator
Drives: No BMW for now
Probably not. We aren't likely to get such engine details until BMW is ready to release them, which will probably happen sometime later this year.
It is possible, sure, but not likely. Generally, higher RPM means less efficiency (its not necessily that simple of course, but typically that's how it works), and they are trying to maximize efficiency with their turbocharged engines.
The shape of the cylinder is not really important for max RPM. Rather, it is stroke length. The N55 and N63 have nearly identical stroke: 89.6mm and 89mm respectively. The 8000 RPM S54 has a similar stroke and Audi's V8 and V10 are actually 93mm and rev as high as 8500 RPM in some applications. Of course, those are all NA engines. The turbocharged McLaren engine has a very short stroke by comparison.
That would mean a brand new engine architecture with high costs. The whole point of working with an existing engine as a basis is to use existing tooling and maintain compatibility with some existing parts such as timing assembly, accessories, mounts, etc.
      04-28-2013, 08:33 AM   #22
Boss330
Boss330's Avatar
It's not "theory" that a straight six can have three turbos...
