12-28-2022, 12:39 PM | #1 |
Rep 83
Drives: BMW M4CS
San Marino Blue M4CS - track build
Hello all,
I am coming from the Subaru world haha please don't hate too much. I had an 04 STI that was transformed into a track car, before I bought that car I was looking at the E46 M3's. So the only logical next car was to be a BMW coupe, I was looking between the M4 and M2, but I found a beautiful M4CS. Goals with the car are to enjoy it on track and some weekend drives. It was something I was missing while owning a strictly track car. I do not plan on going full crazy and caging this car. Mod list Wheels/brakes 763M Matte Black Volk TE37 Saga SL 18x10.5 Volk TE37 ZE40 M-Spec 19x10.5 AP Racing Front Brake kit - CP9665-2 378mm AP Racing Rear Brake kit - CP9449 380mm Endless MS35 25mm Front Pads Endless MS35 Rear Pads GT4 Brake Cooling Backing Plates Suspension Tractive Track and Road Fall-Line Motorsports Rear Lower Tension Arm Set Fall-Line Motorsports Rear sway bar end links Fall-Line Motorsports Lower Coil Over Camber Arm + Shim Set SPL Race Rear Adjustable Toe Arms SPL Race Front Tie Rod Ends SPL Race Front Lower Wishbones SPL Race Rear Adjustable upper arms Engine/Transmission PWR / C&R DCT Cooler PWR / C&R Oil Cooler PWR / C&R Heat Exchanger PWR / C&R Top Mount Charge Air Cooler PWR / C&R Radiator PWR / C&R Aux coolers R&L sides KMP Differential Bushing & Bracket Set ECS Poly Trans mounts Evolution Racewerks Racing Catless Downpipe Ceramic Black Evolution Racewerks Racing J-Pipe intake Akrapovic Evolution Link pipe set Akrapovic slip on exhaust Carbon fiber tips Fall-Line Motorsports Billet DCT Pan Interior Recaro RMS 2700g BimmerWorld billet floor mounts KMP Gen 2 10 button wheel AIM Solo2 DL AIM Smarty Cam Aero Bimmerworld GTMore swan neck wing Bimmerworld GTMore splitter Extra's Slon CF Upper tie Bar Slon CF bummer support Schirmer Carbon Doors Fall-Line Motorsports Tow Strap Front & Rear IND Tow Hook Cover Front & Rear paint matched Fluids Motul 300V Comp- 10W40 Redline - DCTF Redline - 75W140 Motul RBF 660 I will take some pictures when the car is out in the summer. in the mean time, here are some of the subaru before it was parted out. Thank you Last edited by funk323; 12-10-2023 at 01:30 PM.. |
NickyC17484.50 M3AN_F8IGHTY1140.50 D_SheerDrivingPleasure1092.50 ntg442888.50 ClubsportJunkie311.50 _bm274.50 sly1types431.50 chrisjguzman95.50 bholler5341.00 GreenGoblin51.50 5thscaleracer70.00 imperfectluck426.50 krm347.00 JobanM73.50 Drifter2090909.50 cfm56d7b5886.00 |
01-04-2023, 09:10 PM | #3 |
Rep 247
Congrats. Fellow M4cs owner here and can confirm that they are phenomenal cars on the street and even more so on track. That is a lot of cooling you have planned/installed. These cars do come with additional cooling reservoirs (above base/comp) and hold up really well on track. However, sounds like you have more serious intent than your average HPDE looking at the Subaru pics. FYI, love the '04 and still look at/price '13 Sti hatchbacks as DD.
GL and look forward to your build and progress on this platform. |
01-04-2023, 09:24 PM | #4 | |
Rep 1,287
BTW, CSF is sht. Have a blast!
Dry sump flat six
01-05-2023, 08:37 AM | #5 | |
Rep 920
The GT more aero is super aggressive for weekend drives. Be careful with that thing. |
ntg442888.50 |
02-09-2023, 02:18 PM | #7 | |||
Rep 83
Drives: BMW M4CS
Hello all again,
sorry I didn't reply sooner, I thought I would receive an email saying people were posting. guess I need to check the settings. Quote:
all the CSF bits aren't good? Quote:
Here are the Tractive Track and touring coilover package. |
D_SheerDrivingPleasure1092.50 Wanted_M759.00 |
04-16-2023, 09:52 AM | #8 |
Rep 83
Drives: BMW M4CS
chrisjguzman95.50 |
05-11-2023, 08:20 PM | #11 |
Rep 492
Drives: M4 GTS
Quick jack ramps?
05-16-2023, 01:51 PM | #14 |
Rep 83
Drives: BMW M4CS
front end is pretty much complete suspension wise. Started on the rear left, this went smoother than the front did.
and I had to test fit the TE's are I saw someone mention their TE's wouldn't work. Luckily mine work with this setup, I do have a 15mm spacer up front, but may come down to 10mm or 7.5mm, I will have to play with it after getting the car back on the ground. GTMore splitter has arrived, once the suspension is all installed, I will work on the splitter, waiting on the wing to arrive. |
05-21-2023, 04:01 PM | #15 |
Rep 83
Drives: BMW M4CS
05-23-2023, 05:46 AM | #17 |
Rep 83
Drives: BMW M4CS
05-28-2023, 10:19 AM | #19 |
Rep 83
Drives: BMW M4CS
The Splitter is 90% installed, just need some fine tuning on the bumper fitment. Not as straight forward as I thought but none the less it is on and after its all mounted, it all made sense and will be easy to take off and on when needed.
New side mounts for the Aux rads I have not installed the brake ducting yet, I need the other side (knuckle) to connect it all up properly I can't do much driving at the moment as all the suspension items have been installed and the alignment is completely a mess. |
gabriel.psd493.00 JobanM73.50 |
06-12-2023, 05:22 PM | #20 |
Rep 83
Drives: BMW M4CS
Everything I have so far has been installed and alignment completed. first track evening will be Monday, just a shake down to confirm everything is working as it should.
went out for a car meet with a buddy and his C7 Vette. Both cars are rocking AP brakes front and rear, Tractive R/T coilovers. Once I have downpipes and a proper tune, I should be able to match power. |
bholler5341.00 D_SheerDrivingPleasure1092.50 GreenGoblin51.50 heitzke1152.50 Paco1M101.50 JobanM73.50 Stronie313.50 M_Torx328.00 |
06-12-2023, 09:02 PM | #21 |
Rep 370
Drives: 2017 Ferrari Red F80
Savage! Love it!
You can even get groceries with that whip. Amazing.
https://www.instagram.com/ferrariredm3/
2017 ///M3 Individual Ferrari Red / Full Black Leather/ ZCP / DCT |
06-13-2023, 06:58 PM | #22 |
Rep 83
Drives: BMW M4CS
Thanks! Loving it so far.
