03-14-2022, 10:08 AM | #1 |
Rep 22
Best additional mods to go with a Stage 1 tune & M Performance Exhaust
So I am in the process of getting everything set up to have my 2018 m4 tuned in April.
My car is entirely stock at the moment except for a m performance exhaust. I am doing the eurocharged stage 1 tune and I want to make sure I am doing everything right so my car can properly handle the power. So far I have purchased CTS charge pipes and J pipe but that's it. Should I be adding anything else? Like a BMC air filter, or bigger tires on the rear (currently 275s on the car). Looking for other areas to improve the car in order to handle the additional power of the tune the best. |
03-14-2022, 11:39 AM | #2 |
Rep 167
Is eurocharged doing a custom tune for you or is it just an OTS? Any particular reason why your going with eyrocharged? And why stage 1?
These tunes are difference makers for sure but honestly a stage 1 or even 2 is not such a big difference you need to compensate in other areas. Stage 1 will get boring real quick. I got my '18 m4 comp in august. It had a stage 1 already on it. I drove it for 3 days and bought the stage 2 from bm3. The stage 2 wasn't a kick in the seat difference compared to stage 1 but it definitely felt stronger all around. Then after 2 weeks I got the stage 2 e30 tune and dynod the car. In Houston heat at 78 degrees it did 490/520. The car is completely stock besides the tune and fuel. So if I was on stage 1 all 93 Oct it would have put down about 465/490.. these stage 1 and 2 OTS tunes are very overblown when it comes to actual numbers. People think, oh I'll get a stage 1 and I'll get 480+ bevsuse Thsts what the website says or Thsts what people on the forums claim. And stage 2 with a downpipes I'll get minimum 520. The truth is A. You don't need any exhaust modifications for either 3 of the above mentioned tunes. B. Lower your expectations of how fast your car will be C. Don't buy into the hype of a simple OTS tune being this amazing and crazy thing on your csr Thst is going to need other car components to run right and safely. I'm not at all trying to be negative lol I'm sorry if it's coming off like that. I'm simply saying what most others don't. Yes, you will love the car (my m4 is by far my favorite and fastest car I've ever had) and yes the tune is a must. But the car won't really be "fast" until you get into E85. I'm speaking from personal experience. I recently got the bm3 flex fuel kit and have been trying to get it dialed in over the past 2 weeks. I just did a couple days ago and can say this stage 2 bm3 flex fuel tune w the flex sensor / kit compared to my stage 1 or even 2 tune is miles ahead! No comparison. I'm running e40-e45. Car is still otherwise stock (besides charge pipes) this cost me $200 for the tune (bought the license used) $600 for the kit . So for $800 total I've gained at least 100 hp and I honestly don't even know how much tq from stock. Thsts insane. If eurocharged is promising you certain numbers make sure they clarify if that's at the wheels or crank. Also have them dyno the car before and after (this is crucial!!) on a stage 1 you should expect around 50hp stage 2 60-70 max over stock and that's being generous. My recommendation is skip the nonsense and go custom. With your tires just put on 285 next time you need to change them. Otherwise besides charge pipes your set. This is why a lot of people buy this car. Literally a tune is all you need.
2010 e92 M3
03-14-2022, 11:42 AM | #3 |
Rep 642
Nothing needs to be done engine wise. I run stage 2 but the difference is very small but i run 20% torque reduction which makes the car much more easier to control and puts down power better. Gives a more linear powerband too. taste is different but i like it this way together with michelin PS4S for streetuse and öhlins coilovers with revised springrates.
03-14-2022, 06:59 PM | #4 |
Rep 5,158
Bootmod3 with Stage 2 map…$350USD.
Add BMC drop ins and you're done.
03-14-2022, 09:22 PM | #5 | |
Rep 22
The custom tune is said to do 575hp at the crank, I'll definitely be getting the car dyno tested before and after the tune. Appreciate all your insight and recommendations |
03-14-2022, 09:25 PM | #7 |
Rep 22
With the BMC drop ins did you do any special for setup with them? I was reading earlier about them and a lot of people were saying they actually hurt performance and were making the car slower at lower end speed
03-14-2022, 10:57 PM | #8 | |
Rookie
54
Rep 213
2018 M3CS SMB
03-15-2022, 12:42 AM | #9 | |
Rep 3,727
Crank hub BM3 ethanol sensor Max effort custom tune on full E85 AA Catted downpipes AA Midpipe Pretty handy when those pesky muscle cars come around and want to play bully hehe
03-15-2022, 08:46 AM | #10 | ||
Rep 167
Good luck man!
2010 e92 M3
03-15-2022, 09:17 AM | #11 |
Rep 190,952
03-16-2022, 10:06 AM | #12 |
Rep 22
I thought it sounded strange but I noticed a few people on the thread mention it... likely just didn't know what they were doing or saying
03-16-2022, 10:07 AM | #13 |
Rep 22
Thanks for the advice! Once my budget increases a bit would likely want to try a few of these
03-16-2022, 10:10 AM | #14 | |
Rep 22
03-16-2022, 10:11 AM | #15 |
Rep 22
What would be the biggest benefit of going with a new intake? I've looked into this a bit but wasn't sure of all the benefits over the BMC filter or even just stock.
03-16-2022, 10:19 AM | #16 |
Rep 190,952
both improve the airflow, an intake will also improve the sound
04-15-2022, 10:38 AM | #17 |
Rep 22
So finally got my car tuned by euro charged Canada with their stage one tune.
They installed the CTS charge pipe, j pipe and intake first, everything else on the car is stock except for the m performance exhaust. Once that was installed we did the first pull on the dyno and the car produced 430hp and 422 torque After the car was tuned it produced 504hp and 518 torque. We used dynojet for the dyno. So far the car has ran great, haven't been able to do much driving though because of the crap weather in canada right now but will update after a few more drives. |
TopJimmy5474.00 |
04-16-2022, 01:51 PM | #18 | |
Rep 22
04-27-2022, 08:34 AM | #19 | ||
Rep 167
Also you picked up an average of 100 hp/tq throughout the powerband which is amazing! And it looks like they eased your power and torque curve so that it hits a little higher in the rpms which allows you to give it more gas down low, reducing wheel spin. I hit full torque at like 3.4 rpm but yours is like 4.4. That's a good thing, you can accelerate harder than I without spinning as much. Great numbers!
2010 e92 M3
04-27-2022, 06:07 PM | #20 |
Rep 4,959
Throw a single midpipe on there it wont throw any check engine lights. Other than that maybe an intake.
Intake https://mad-us.com/mad-bmw-s55-m3-m4...ow-air-intake/ Midpipe https://mad-us.com/mad-bmw-f8x-m3-m4...race-included/
bmw m4, mods, power gains, stage 1, stage 1 tune, tune |
