R44 Performance
      11-25-2013, 05:52 PM   #1
Paul-Bracq-BMW
Moderator
Paul-Bracq-BMW's Avatar
Australia
4092
Drives: 1981 323i, sports M5, LSD
M3-M4 Article from Engine Technology International, January 2014
Enjoy the read!!
1981 323i, 143 Kashmir-Metallic, 0094 Pergament, Sports M5, LSD.
      11-25-2013, 06:32 PM   #2
nonagon
nonagon's Avatar
Drives: Porsche Cayenne GTS
Good stuff! It seems like the new engine will be lag-free and they concentrated on cooling. All good news.
There was some weird info about the engine in 1M coupe, (which is an M tuned N54), saying it shared the S55 designation. Is that accurate? Might be but it sounds wrong to me.
      11-25-2013, 06:36 PM   #3
gee-m-w
gee-m-w's Avatar
74
Drives: S4
So the engine weighs 452 pounds and is 22 pounds lighter than the V8. Interesting facts.
WTB: 2016 M3 sedan, Black Sapphire, Extended Sakhir Lether, Ceramic Brakes, 19" black wheels, Lighting Package, HK sound, USB/Bluetooth
Sold: 2006 e90 325i 6MT, ground control coilovers, Remus exhaust
      11-25-2013, 06:38 PM   #4
RMB
RMB's Avatar
Drives: 2018 Audi TTRS
Awesome read. Thanks for posting.
      11-25-2013, 06:47 PM   #5
gblansten
gblansten's Avatar
1967
Drives: 23 Tesla S Plaid
Great post. This engine is really looking like it might be tremendously fun.
      11-25-2013, 06:56 PM   #6
CanAutM3
CanAutM3's Avatar
Thanks for sharing
I am curious to what "impulse charging" refers to to. I have seen it quoted more than once, but have not figured out what it implies from a technical perspective.
I am still eager to find out what is the trick technology (if any) ///M has used to reduce lag.
      11-25-2013, 07:15 PM   #7
I wish they would have asked if this technology means that the S55 is significantly more responsive than the S63TU which isn't bad but not nearly good enough for the more track oriented M3 IMO. No to say that the M3 is a track car but it's usually more track friendly than the M5.
      11-25-2013, 08:33 PM   #8
Paul-Bracq-BMW
Moderator
Australia
4092
Originally Posted by CanAutM3 View Post
Thanks for sharing
From what I understand, it's a system that keeps the turbocharger spinning at a certain set high speed under low load so when power is fed, the turbo lag is minimised...
      11-25-2013, 08:38 PM   #9
JTO24
never could compete with Lloyd Braun
JTO24's Avatar
Drives: 2022 G80 M3 6MT
Good read.. Even tho power will fall off before hand, I like that it'll rev up to 7800 rpm still.
      11-25-2013, 09:17 PM   #10
mkoesel
Moderator
Drives: No BMW for now
"80mm bore and 89.6mm stroke"
That's doesn't even add up to 3L. I wonder if we'll ever know the real bore dimensions?
Nice read though - thanks for posting. However, after reading it thoroughly, wow, there are a number of glaring errors like "...even though it shares the same S55 designation as the 1M Coupe's..."
      11-25-2013, 09:27 PM   #11
JoeFromPA
Drives: '15 AW M3 6MT Stripper
7800 rpms is a wonderful redline/fuel cutoff; I believe that's about what the reprogrammed s54 hit after the initial 8000rpm redline kerfuffle.
What really stuck out to me is that the s55 has 70% more torque at 2000 rpms and 40% more torque at 7500 rpms than the s65. That is:
1. A boatload more torque in daily driving. Combined with a lighter weight this thing should SCOOT at 2000rpms when you wood it.
2. Indicates a really nice kick in the pants when shifting up to the next gear, if you are getting that much additional torque between 5000-6000 rpms compared to where the s65 would be.
As many others have said, it's all about area under the curve. And what I'm reading is that there is ALOT more power throughout + several hundred pounds less to power around.
Really good stuff all around.
      11-25-2013, 09:37 PM   #12
Keto
Keto's Avatar
2015 BMW M3  [10.00]
I'm excited about the low-end oomph.
2015 SO/SO MT M3 :: Exec : Lighting : Adaptive : HK : CF trim : Full leather : DAP : Black 19's : sunshade
Crystalline tint 40%/70% on windshield : M performance mirrors, spoiler, splitters : Status Gruppe CF lip : RKP diffuser : Fully dechromed
Bavsound Stage 1 : V1 Savvy hardwired : Self-coded
      11-25-2013, 09:53 PM   #13
CanAutM3
CanAutM3's Avatar
Obviously...
The question is how this is achieved ?
      11-25-2013, 10:16 PM   #14
aus
Drives: Odysse
Shouldn't a 3L I6 weight more than just 20 kg less than a 4L V8???
Looks like most people here are ok with the lack of linear power delivery up top.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
      11-25-2013, 10:29 PM   #15
Remove all turbo junk and bore the thick block and you will have a much lighter NA 3l I6. FI comes with extra weight.
      11-25-2013, 10:45 PM   #16
bimmerjph
bimmerjph's Avatar
Drives: 2005 Z4 3.0
Not with the turbos and intercoolers it won't.
      11-26-2013, 01:39 AM   #17
Chill72
Chill72's Avatar
Drives: 10 E92 M3 (RIP)
Besides the actual quotes from Siegl and Biermann this article is worthless. They show figures that are not confirmed and nothing that we haven't heard before. However, it was still a good read since it;s about the new beast.
      11-26-2013, 01:49 AM   #18
Boss330
Boss330's Avatar
Not to mention that in the "Fact box" it says Bore: 80mm, Stroke 84,6mm...
      11-26-2013, 02:21 AM   #19
BMW M3 CRT
BMW M3 CRT's Avatar
177
Really interesting fact ... seem like the inside source from the german m-forum was right as he tells me, that the new S55 (205kg!) would be a little bit heavier than the ongoing S65 (202kg!).
Seem logical ... if you compare the engine netto weights, an 3.0ltr.I6 is probably lighter than an 4.0ltr.V8, but in gross weight an BiTurbo with racetrack proof cooling need many heavy cooling parts ánd its never less an great weight saving effort to make him in nearly the same weight class als an proven lightweight V8.
Greetings BMW M3 CRT
      11-26-2013, 08:18 AM   #20
jsublime
Drives: G20 M340i
2015 BMW X3 28i  [0.00]
2011 BMW 135i  [0.00]
2016 BMW M3  [0.00]
Whether it's 84 or 89, both of these statements contradict earlier info about the engine being oversquare.
      11-26-2013, 08:47 AM   #21
Gearhead999s
Gearhead999s's Avatar
814
Drives: RR Velar R=Dynamic M2C R1200GS
Obviously...
I read somewhere that they are keeping the throttles open under deceleration to reduce pumping losses to help keep the turbos spooled up but only when its in the sport or sport plus drive modes.I cannot remember where I read this though
      11-26-2013, 08:59 AM   #22
Kuwen
I thought it has been previously stated the turbos were Mitsubishi?
2014 bmw m3, 2014 bmw m3 horsepower, 2014 bmw m3 specs, 2014 bmw m4 horsepower, 2014 bmw m4 specs, 2014 m3, 2014 m3 engine, 2014 m3 forum, 2014 m3 horsepower, 2014 m3 hp, 2014 m3 specs, 2014 m3 weight, 2014 m4 engine, 2014 m4 horsepower, 2014 m4 hp, 2014 m4 specs, 2014 m4 weight, 2015 bmw m3, 2015 bmw m4, 2015 m3, 2015 m3 engine, 2015 m3 specs, 2015 m4, 2015 m4 engine, 2015 m4 hp, 2015 m4 weight, bmw f80, bmw f80 forum, bmw f80 forums, bmw f80 m3, bmw f80 m3 s55, bmw f80 m3 sedan, bmw f82, bmw f82 forum, bmw f82 forums, bmw f82 m3, bmw f82 m3 coupe, bmw f82 m3 forum, bmw f82 m4, bmw f82 m4 coupe, bmw f82 m4 s55, bmw f82 m4 video, bmw f83, bmw f83 m3, bmw f83 m4, bmw m forum, bmw m forums, bmw m3 carbon fiber roof, bmw m3 forum, bmw m3 forums, bmw m3 s55, bmw m3 s55 engine, bmw m3 yas marina blue, bmw m4, bmw m4 concept, bmw m4 concept coupe, bmw m4 coupe, bmw m4 coupe concept, bmw m4 curb weight, bmw m4 weight, f80 m3 specs, f80 m3 weight, f82 m4 specs, f82 m4 weight, m4 weight
