      05-23-2018, 10:59 PM   #1
DanMpower
DanMpower's Avatar
Drives: BMW M3s and a Red VW
Just finished upgrading my M3 to touchscreen.
Easiest RETROFIT ever. Hardware side, all you need is a new 2018+ touchscreen and that's it. Everything works, including your original display cable. Probably took me 10 minutes for the swap.
Easy steps.
1: Pop off vent trim
2: Unscrew two T20 screws holding the screen in
3: Unplug the original screen
4: Reverse the install
Then have it coded and you're all set! This only applies to 2017 and up cars since you need NBT2 EVO to run ID6 for touch. This mod makes using Apple CarPlay so much better, navigating the menu is awesome and feels great with touch.
What you'll need.
Here is mine in action.
      05-24-2018, 11:55 AM   #2
outatime e46
Drives: 2017 F80
Biggest question(s) for me: where did you find the 2018 touchscreen and how much was it?
      05-24-2018, 12:07 PM   #3
alex2364
alex2364's Avatar
2857
2020 BMW M4  [10.00]
2023 BMW X3 M40i  [10.00]
Even bigger question: Why would you want finger prints on your screen?
Appreciate 8
Encanto1164.00
Aaaaaaaaa7559.00
MadZarBMR712.00
stormlv930.50
PhatLyfe985.00
      05-24-2018, 12:21 PM   #4
materialdistractions
Philippines
136
http://f80.bimmerpost.com/forums/sho....php?t=1499221
      05-24-2018, 03:40 PM   #5
DanMpower
DanMpower's Avatar
While navigating through the menus I can see it isn’t really necessary but if you use Apple CarPlay a lot there’s no going back after using it with touch. I keep a microfiber cloth for a quick wipe down, works out great!
      05-24-2018, 03:43 PM   #6
DanMpower
DanMpower's Avatar
You can find them on eBay for between $600-700 from sellers overseas, dealer wants like $2500+
      05-24-2018, 04:04 PM   #7
Aaaaaaaaa
Drives: The other M3
My car has a touchscreen. Who knew?
      05-24-2018, 07:04 PM   #8
13307
Drives: 18 F82 M4 ZCP Black/Black
Must be sn m3 thing, my dec build '18 m4 does not have a touch screen?
      05-24-2018, 07:20 PM   #9
Ian1973
Drives: 15 M3
Cool but can't stand fingerprints.
      05-24-2018, 08:45 PM   #10
qmp
Drives: 15F80
Custom cut anti-glare/fingerprint screen protector
      05-25-2018, 06:29 AM   #11
Nonopr01
Drives: 2017 BMW M3
What coding was involve to make it work?
      05-25-2018, 09:11 AM   #12
moonluv810
moonluv810's Avatar
Drives: 2017 BMW X3, 2018 BMW M3, 2022
Fingerprints? Easy to clean...
You're welcome!
https://www.amazon.com/gp/aw/d/B0744...RRRN8NWD&psc=1
      05-25-2018, 09:21 AM   #13
BigDog
Drives: YMB F80
How easy is it to update to idrive 6
      05-30-2018, 10:18 AM   #14
f80er
Drives: An M3
Stupidest thing BMW ever did was make that a touch screen. I could understand if it was lower/closer to the driver. But with my seat back its a pain to reach for it.
      05-30-2018, 10:38 AM   #15
jmciver
///M SubDriver
jmciver's Avatar
Drives: 2017 M3, 2020 X7 40i
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
2009 BMW 128i  [0.00]
Aww c'mon Drew, your arms are not that short .
I actually just ordered an OEM touchscreen for a retrofit. It is part of a project I have been waiting to do for a while but was waiting for a viable touchscreen option to become available (and for the right price).
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior
X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic
X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's)
      05-30-2018, 12:04 PM   #16
G35POPPEDMYCHERRY
G35POPPEDMYCHERRY's Avatar
Drives: F80
You're welcome!
cant believe this is actually a product
      05-30-2018, 02:21 PM   #17
f80er
Drives: An M3
Haha, but my seat is waaaaaay back. Here's a pic:
Curious if you end up using the touch feature after the retrofit.
      05-31-2018, 04:39 PM   #18
jmciver
///M SubDriver
jmciver's Avatar
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
So I just completed this retrofit and I will second just how easy it is to swap the monitors. You just don't want to go too fast because it would really suck if you dropped one of the screws into the dash or accidentally scratched your trim pieces during removal or installation.
The coding is very simple and I was able to do it myself using the BimmerCode app in Expert Mode. The parameters that require changing are in the NBT_EVO ECU. You can use the search function in BimmerCode to easily find these parameters as there are a lot of them in this ECU. The following parameters require changing:
1) HMI_ID_VERSION: id6_light
2) CID_TOUCH: aktiv (Active)
3) CID_HMI_TOUCH: aktiv (Active)
For those of you that have ID6 Lite coded (as I did) you should already have the first parameter set. The next two parameters will need to be changed. After you code everything and the headunit reboots, you will know the touch screen is recognized when you see the little "3 square" symbol in the upper left corner of the screen (see the video from the OP above).
How do I like it so far? So far so good, but it is still a bit early I guess as I have only played around with it for a bit in my garage after the install and coding. I do see how the distance of the screen makes using it more cumbersome while driving as I do have to lean forward a bit to use it - but maybe that is not a bad thing from a driving safety perspective . I think the ID6 GUI definitely lends itself to touch and there is some functionality that I discovered that is unique to the touchscreen. However, most iDrive functionality is the same between the touchscreen and the iDrive controller. But I like having different options to control the headhunt, which will be a mix of voice (with Siri and BMW), the controller and now the touchscreen.
Where I think the touchscreen really shines the most is with using CarPlay. In it's current form CarPlay is a bit of a disappointment to me (as many others have posted about on the forums) due to the lack of supported apps. However, the touchscreen makes using it much easier IMHO as CarPlay essentially mirrors the iPhone - which of course is based on a touch interface. Next step for me is to jailbreak my iPhone, which can unlock ALL of the apps for use with CarPlay with a special app. This is what I am really after (using different iPhone apps) and without a touchscreen, using iPhone apps not originally designed for CarPlay may not work well (or at all) with the iDrive controller.
So I am glad I did it, and the ability to use all iPhone apps (with a jailbroken iPhone) is better than any other aftermarket touchscreen solution on the market right now IMHO. Of course, I would not have done this if it were not for the great price on the screen (thanks LloydChristmas ). As much as I like the new functionality, I would not have paid $2k+ for a new OEM screen from the dealer ...!!!
Oh yeah, and the finger prints/smudges do really suck. So the screen protector is the next mod on the list....
      05-31-2018, 11:05 PM   #19
IK6SPEED
Drives: BMW M3 / AH3
A loaner I had last month had CarPlay and touchscreen.
I used it exactly once over 3 weeks as it was so awkward to reach.
Between my 10.2” non-touch screen and a much smaller touchscreen, I’ll take the 10.2” screen any day of the week.
      06-01-2018, 02:39 AM   #20
DanMpower
DanMpower's Avatar
Hey JMCIVER, glad you got it working easily. I ordered the glass screen protector moonluv810 linked on Amazon, got it and installed it yesterday. Works fantastic at rejecting fingerprints, I hardly get any now unless my fingers are really greasy and even then it's hardly noticeable. It also wipes clean much easier as well, definitely order it.
Went on a small road trip the other day and the wife was playing with the touchscreen the whole time, switching tracks, scrolling through Pandora, selecting songs ect. She really enjoyed using the touch interface over the iDrive controller. So much more easier in CarPlay. I'm really liking your idea about jailbreaking the iPhone and allowing other apps in CarPlay. I'll have to look into it.
      06-01-2018, 06:18 AM   #21
jmciver
///M SubDriver
jmciver's Avatar
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
Between my 10.2" non-touch screen and a much smaller touchscreen, I'll take the 10.2" screen any day of the week.
Had a similar, but slightly opposite experience a few weeks ago as well when my wife had a new 5-series loaner with 10.2" touchscreen... I was skeptical of the touchscreen integration after a lot of negative press on the forums, but the gadget guy in me really liked it . And this is just using the BMW side since I did not link to CarPlay in the loaner.
However, what was a bit of a let down to me was the size increase - first time I had seen a 10.2" monitor in the flesh. To me, the size increase was nice, but still not as "impressive" as I thought it would be - definitely not worth the effort to physically modify it (i.e. cut/trim it or the dash) to get it to fit properly IMHO. I don't think my OCD could take it. Different strokes I guess....
Regardless of monitor selection, I think OEM is definitely the way to go - especially if you can get a good price that is competitive with aftermarket units. All of the aftermarket units I have seen seem to have very "buggy" software and I question the hardware reliability after several months of sun/heat sitting on the dash.
      06-01-2018, 06:22 AM   #22
jmciver
///M SubDriver
jmciver's Avatar
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
Glad to hear that screen protector worked out as I know not all screen protectors are created equal based on my iPhone experience. And I was not finding too many vendors that offered a screen protector for the 8.8" CID.
