      04-25-2021, 04:05 AM   #287
f80fan
Drives: F80
Originally Posted by fpvsportsguy View Post
I'm just about to pull all of my hair out as I just can't locate this mystery rattle. I've chased down just about all other noises in the car, but this one is becoming my white whale. It happens when I go over bumps and it rattles and reverberates for a bit after the bump, sounds like a loose screw as the reverberation is high in frequency, about 3-5hz by my rough estimation. It's somewhere around the front passenger area, I just can't locate where. Any help would really be appreciated!
Have you tried removing the passenger sun visor? have just identified the source of the rattle from the passenger side in my F80. It was coming from the sliding piece of plastic that covers the mirror. I temporarily put a small piece of tissue between the mirror and the plastic cover to exert some pressure on the cover then closed it and the rattle stopped Just need to work on a proper fix now.
18BMWX5M578.50
      09-21-2021, 03:36 AM   #288
justan77
Drives: '17 M4 (F82)
This was extremely helpful, thanks!
      01-21-2022, 05:18 PM   #289
M4_Junkie
Drives: BMW M4 Comp (F82)
Great thread and especially the one about the HUD rattle... My car suffers from a similar HUD rattle but only when the sun shines on the windscreen. If I press down on the edge of the HUD (plastic bezel) it goes... Guess its time to get some felt tape and apply it to the inside of the bezel.
      01-21-2022, 05:20 PM   #290
M4_Junkie
By the way, what sort of plastic trim removal tools do you guys recommend?
      07-08-2022, 08:45 PM   #291
asomaember
Drives: BMW F30
Hi! I have a rattle nois on 1500 -1600 rpm. After its warm up the noise is 90% disappear. Louder on the driver side. Outside i cant hear it or just very very hard. Any idea what can do this noise? I check the motor cover and other plate what i can.
N47D20 F30 xdrive
      10-17-2022, 12:45 PM   #292
MattyIce
MattyIce's Avatar
154
What vibrates for me is my plastic steering wheel column cover! If I push it down it, temporarily stops the issue. Anyone else have the issue?
      11-19-2022, 10:56 PM   #293
Kilabyte
I'm Batman!
Poland
4113
Drives: Mineral White M3 6MT
Rear dash starts buzzing at 4k RPM but only with the seats folded down. It's not the child seat anchor covers. Any pointers before I start ripping it apart tomorrow?
S55, 2JZ, M48.00, N55
      05-15-2023, 03:05 AM   #294
bimmerfan99
Drives: F80
registered here just to say thanks all for the input on this.
My F80 had this squeaking noise and I realised if I roll down my windows slighly the squeaking noise disappears.
Followed the guide in the OP and used Gummi Fledge to grease up the inside of the window rubber seals. Its gone now.
Again, for those experiencing a similar issue, for me, it wasn't the door seals but rather the seals within the frame of the window so you will have to get right up in there with the Gummi for it to do its thing. Once lubricated and dried, the sound has 100% disappeared.
      09-25-2023, 03:59 PM   #295
Joguri
Joguri's Avatar
Drives: 2018 BMW M4 Comp
If you have a rattle come from what sounds like the backseats/where the speakers are but find that its not your speakers, it could be this clip in the trunk. Mine got loose and rattled a lot!
      01-02-2025, 04:50 AM   #296
MetzgerMeister
MetzgerMeister's Avatar
139
Drives: F82 M4
Front A/C Trim - I had this rattle since I got my F82. I applied Tessa tape around the 2 button connectors at the back of the trim and applied Gummi Pflege to a lot of the spots. Rattle is now gone!
Current: 2016 F82 M4
Previous: F30 330d / E92 335i / E46 318i
      01-07-2026, 10:45 AM   #297
Lord09
Drives: NA
Any chance you figured out this buzzing? I have something very similar.
      03-12-2026, 05:38 PM   #298
SpoiledBrat
Drives: 2016 m3 ZCP
any idea what this rattle is? I think it's coming from the dash somewhere. In the video it almost sounds like static, but it's a "fast" or high pitched rattle, almost sounds like metal on plastic but not sure.
2016 Mineral Grey M3 ZCP
2004 AW 330Ci zhp (sold/died)
      03-13-2026, 07:43 AM   #299
lllRazorlll
lllRazorlll's Avatar
219
Drives: 2018 440xi
Has anyone had issues with creaks coming from the metal door panel clips or the seat belt covers?
