11-20-2014, 09:18 AM | #1 |
Rep 79
Anyone found a good console mount for iPhone?
I have been using a ProClips console mount (part # 833597) on my 335i for several years, and it is exactly what I like.
Unfortunately, ProClips does not have a custom mount for the M4 coupe yet, or for the 435i for that matter. My two choices if I stay with ProClips are either a vent mount (that partially covers one of the air vents), or a universal adjustable center console mount (not sure it would fit properly). Has anyone used either of these mounts, and are you, or were you, pleased with them? Does anyone have an other mount suggestions, perhaps from a different company? |
11-26-2014, 05:43 AM | #3 |
Rep 355
Drives: a disturbed shark!!!
Garage List 2023 iX xDrive50 [0.00]
2020 X3 M Competiti ... [0.00] 2017 i3 REx (Sold) [0.00] 2015 X5 xDrive35d ( ... [0.00] 2015 M3 (Sold) [0.00] 2012 X5 xDrive35d ( ... [0.00] 2011 1M (Sold) [10.00] 2006 330xi (Sold) [0.00] 2002 X5 3.0i (Sold) [0.00] 1998 318ti (Sold) [0.00] |
I did the KUDA mount with a ProClip device holder for iPhone 6 (for small to medium cases) and plugged the lightning cable into the port under the armrest. It works great and the holder will adjust to my different cases except the lifeproof (too bulky). FYI: it was definitely expensive for both parts.
http://www.kudausa.com/bmw-4-+-m4-f3...ack-a1880.html http://www.proclipusa.com/phone-hold...666-19733.cmsv I apologize for the photos, I was tired and too lazy to get my real camera to snap pictures with the iPhone in the cradle. |
11-26-2014, 05:49 PM | #6 |
Rep 79
11-26-2014, 05:52 PM | #7 | |
Rep 79
11-26-2014, 06:08 PM | #8 | |
Rep 52
11-26-2014, 07:32 PM | #9 |
Rep 355
I've also been using ProClip adjustable mounts for a long time now and they are excellent!!! Never had an issue other than having to replace them when I buy a new iPhone which is obviously not their fault.
I did use ProClip vehicle specific mounts and they were ok but don't even begin to compare to KUDA mounts. The KUDA fits perfectly and is covered in real leather that matches the vehicles interior well and although not exactly the same material it complements it well. They are on a whole different level!!! Pictures truly don't do it justice but I will try to get some better ones on the weekend. Just my 0.02 |
11-28-2014, 05:09 PM | #10 |
Rep 79
I looked at the installation instructions for the KUDA mount. Unfortunately, the instructions are not detailed enough for me to understand exactly how the mount is secured to the dash. Can you describe the process for us, please?
An I believe you said that once the KUDA is in place that you used your ProClips holder in conjunction with the KUDA. Can you describe how that works as well? BTW, I just realized that my Escort Smart Cord has a USB charging port on it. The Smart Cort is plugged into the front cigarette lighter plug, so this sounds like a perfect way to get charging for the iPhone in the KUDA/ProClips combo. Sound right? |
11-30-2014, 08:55 AM | #11 | |||
Rep 355
First you carefully pull out the plastic trim piece with a nylon pry tool There is a metal tab on the bottom of the KUDA mount that lines up behind the trim piece. It takes some force to fit the mount into place but it is just pressure fit. You are supposed to bend the metal tab once installed but mine is snug enough that I didn't feel the need to. Then you just pop the plastic trim piece back in place. BTW sorry for the coffee stains, just realized they where there... Quote:
The KUDA mount is actually a hollow fiberglass/plastic shell covered in leather. Before you install the mount you need to attach the ProClip or whatever you decide to use. I marked the holes from the ProClip base onto the KUDA mount and drilled four small holes into it so I can screw the ProClip holder in place. Quote:
I bought the ProClip that comes with the cigarette plug/USB cable integrated and disconnected the 12v adapter. Then I just ran the wire between the seat and console and into the USB port under the armrest so I can get full USB connectivity to iDrive for apps, etc. |
11-30-2014, 09:31 AM | #12 |
Rep 2,989
Very good info. Thanks for posting.
I know that it's a camera thing, but those photos really bring out the variation in color of the BMW vinyl pieces. Some of the parts look blue-ish. Again, I know that in person it looks completely different, but wow does the camera pick up stuff that the human eye can't. |
11-30-2014, 09:46 AM | #13 |
Rep 1,864
Garage List 2016 Porsche GT4 [0.00]
1999 Porsche Spec B ... [0.00] 2014 Ram 1500 Laram ... [0.00] 2007 Porsche GT3 RS [10.00] 2013 Tesla Model S 85 [0.00] |
I have an Everdock ordered, but this is as low profile as I could find for now. It works well, I touch the screen with my hand resting on the shifter. Unobtrusive and quick to remove. iOttie 3 with cupholder base.
http://www.amazon.com/iOttie-Holder-...ie+phone+mount
F80 M3 / Mineral Grey-Silverstone / CCB
11-30-2014, 02:47 PM | #14 | ||
Rep 355
That being said I am very curious if the Everdock Go will fit sine the M3's cupholders are slightly wider than usual. |
JMon371.00 |
12-02-2014, 01:25 PM | #15 |
Rep 46
Here The Everdock go in my 328, sorry its a Bad iPad Photo :-) (temporary placed!)
In The dock is my iPhone 5s, its The max. Size to The Top i think. An iPhone 6 should be to high in my eyes.. I also dont know about The Layout in my m3 which i should get mid march. |
12-03-2014, 11:05 PM | #16 | |
Rep 1,864
The 3M tape base wouldn't have made for a solid mount in any case, the cupholder diameter is significantly larger than the cylinder of the Everdock.
12-06-2014, 03:42 PM | #18 | |
Rep 2,104
12-06-2014, 05:40 PM | #19 |
Rep 158
I use this thing:
http://www.amazon.com/Kenu-Airframe-...one+holder+car Best thing is that it keeps the phone high up and near the steering wheel, so its very visible. |
12-08-2014, 01:46 PM | #20 | |
Rep 79
12-08-2014, 08:35 PM | #21 | |
Rep 1,864
It clips to your AC vent. In TX every wisp of air conditioning is precious if not a life safety issue.
12-10-2014, 05:33 AM | #22 |
Rep 3,407
I'm a liking that leather trimmed mount... That's nice!
It's a good thing all you other Austin cats are getting M4s...
2019 Ruby GT350 - Gen 5 Whipple on corn making 855RWHP.
Sold: 2018 F80 Part Deux /DCT /YMB /Full SS /CF Trim /ZCP /ZEC w/Black 666M Sold: 2015 F80 /DCT /YMB /Full SS /CF Trim /ZEC /ZLP /HK /S&TVC- 18''///M |
