07-09-2018, 04:33 PM | #1 |
Rep 364
M3 F80 vibrating at 105-140kmh and whole car vibrates at 240+ kmh
I have an M3 F80 DCT from 2015, EU spec.
When driving 95-105km/h and around 140km/h on cruise control you have a vibration coming and going every 2 seconds. Doing a pull from 240km/h and up the whole car vibrates. Car is aligned, tyres new. We even put new wheels on just to eliminate it, same issue. Car is on warranty and going to BMW next week. Has anyone had this issue? I saw some issues with the rear diff. |
07-11-2018, 11:16 AM | #3 |
Rep 364
07-12-2018, 09:54 AM | #4 |
Rep 74
The vibration through the wheel is most likely tire/wheel/balance related. The one in the seat could be a lot of things but differential/drive shaft are certainly possibilities. Especially considering your comment that it happens on a "pull" That would indicate it is exacerbated by torque. Wheels/tires don't exhibit that. It is also interesting that you mention it has a resonance (coming and going). No unusual noise associated with it?
M3_160.00 |
07-12-2018, 10:01 AM | #5 | |
Rep 364
It's driveshaft/diff I guess. |
07-12-2018, 01:13 PM | #6 | |
Rep 2,108
Check out SI B26 02 14 that I've attached.
2015 BMW F80 M3: Tractive EDC Suspension / Dinan Anti-Roll Bars / GC Camber Plates / KMP Dual Diff Mount / Girodisc Rotors / GT4 Brake Cooling Kit / PTF Flash Tune / Eisenmann Downpipes / CSF Heat Exchanger / BMS Charge Pipes
2007 BMW E92 335i (SOLD): BMS JB4 / Quaife LSD / Riss Racing DPs / Helix Intercooler / BMS Intake / STETT Charge Pipe / Forge DVs |
07-12-2018, 02:14 PM | #7 | |
Rep 364
But yes i'm sure it's around that area, not engine or DCT related. Did 1 burnout and then I felt this 3 days later, maybe it was there right after but never paid attention. Man my M6 is so much a better car than this turd lol |
07-29-2018, 06:57 PM | #9 | |
Rep 364
Sounds more like what you mention to me. |
08-28-2018, 04:53 AM | #12 |
Rep 364
08-28-2018, 05:45 AM | #13 |
Rep 22
08-28-2018, 05:46 AM | #14 |
Rep 364
I had that too!! I got a new diff, fixed. Try this, put the car on a lift. Do a pull up to 7th gear 4500RPM and put in neutral asap. Then you will hear the complete rearend vibrate.
08-28-2018, 06:19 AM | #16 |
Rep 364
08-28-2018, 06:40 AM | #17 |
Rep 22
Long story short - it took me more than two years of fight (I have to call it fight) with BMW. They refused to take car back, jus gave me some "compensation". I had only two options - take some money or go to the court.
I think it is my driveshaft, but I don't know what to do with it. BMW claims it has replaced the shaft but I don't believe that at all... I checked eight sets of wheels - no difference. About your car - try with tension struts - or jus give the car back, if possible. BMW suks today. There are more similar cases in the forum with car shaking, low frequency drones, steering wheel vibrating... |
08-28-2018, 06:43 AM | #18 | |
Rep 364
Let's see what they say. |
08-28-2018, 09:22 AM | #19 |
Rep 3,157
I have had a similar issue since i purchased the car. I have a steering shake starting at around 70mph and it gets worse as speeds increase. Balanced multiple times change tires and alignment nothing has fixed it. Possibly a bent rim from the factory
stealth70mde375.50 |
08-28-2018, 09:32 AM | #20 | |
Rep 364
08-28-2018, 09:46 AM | #21 |
Rep 287
I have a weird shimmy feeling taking left turns when the suspension is loaded around ~120Km/h or so. Feels really weird... Haven't tried taking a left at 200+ though lol.
Upcoming: GT3 some day...
Current: AMG GTC, 2019 X5 40i Previous: Way too many M cars, a few P cars, and one VW Lambo spyder. |
