03-16-2024, 05:15 PM | #1 |
Rep 7
F80 crank hub
Hello.
I have a 2017 F80 comp and am considering doing the 4 pin one piece crank hub….since the main crank hub issue is the bolt getting loose, should I still install the catcher plate for the bolt? And which one is the correct one for our cars? The 6 or the 8 bolts? I know that probably there’s a ton of threads in here about it, but since I’m new to the forum, I need to post some stuff in order to PM other members…sorry. |
03-17-2024, 02:52 PM | #4 |
Rep 25
I would do more research. Lots of people have had issues with the bolt capture and many would say it's a waste of money and time. I (and many) don't believe the crank hub issue is with the bolt at all. I think the consensus would say that with just the bolt capture, you can still slip your crank hub - but with the 4-pin crank hub installed you'll never have a problem. IMHO, get the crank hub done, forget about the bolt capture.
MFNATIK3499.50 Drifter2090913.50 |
03-17-2024, 04:41 PM | #5 |
Rep 264
Agree no need for capture plate and over time those screws get loose and sheer off as seen several people on here have that happen.
4 Pin Crank Hub is the way to go. |
03-17-2024, 04:46 PM | #6 |
Rep 7
Thank you MaxOctane.
Definitely I’m doing the one peace 4 pin hub. I know that the hub issue envolves many factors, and specifically in cars like mine (70k miles) is more a friction disks problem then the bolt getting loose. I was just wondering, since I’m going to address the issue, what’s the best route. |
