05-13-2016, 12:43 PM | #1 |
Rep 499
Drives: California Packet
Location: Left edge of browser window beneath 'join date' obvi
ZCP DME flash Semi-Successful on Non-ZCP F8X
The last couple frames above show the "civic m4" seatback, in case there's any question as to authenticity. Also, not my car. 1) I updated my ECUs with E-SYS and the latest psdzdata (58.3). Still have some issues to work out now that I finally have ISTA-D (e.g. front indicators on LED headlights not working). 2) I edited my FA to include 7MA. 3) Ran swfl on the DME afterwards 4) Successfully obtained burble, BUT 5) Drivetrain malfunction: boost is practically gone, throttle command is significantly limited beyond initial acceleration from standstill. Trying to find the wrinkle that's needed for ironing; hopeful that ISTA-D will help, but hoping to get some help from those more knowledgeable than me. Lessons learned: - Burble tunes that cost money may be unnecessary. - ECU updates aren't that hurrd, don't be scurrd. (but do be if you don't have a power supply.) - ISTA-D is a prerequisite IMHO since "Transmitter" doesn't unlock the airbag (at least for me) as it should nor can it reprogram the LED headlights. Who else wants to take the risk (on someone else's car, of course) and flash their DME and help me track this down? (...or help me track it down via slack?) edit: godda*n U2B tag, why is it still here if it doesn't work? Last edited by packetpilot; 05-13-2016 at 12:48 PM.. |
05-13-2016, 12:46 PM | #2 |
LXO
191
Rep 166
Sounds different than ZCP (might be the recording). Is it a real "ZCP tune" or the forced burbles that other tuners have?
05-13-2016, 12:47 PM | #3 |
Rep 499
05-13-2016, 12:51 PM | #5 |
LXO
191
Rep 166
I read the post as well as the "Competition Package coding" thread earlier, but I just couldn't recognize the tone/sound of the burbles, that's why I asked
05-13-2016, 01:04 PM | #6 |
Rep 499
Got it. For clarity, it's strictly E-SYS and the latest psdzdata, so no non-BMW-sanctioned software is on the car, no aftermarket anything involved here (except my exhaust, which is an AA midpipe + Dinan rear).
05-13-2016, 01:05 PM | #7 | |
LXO
191
Rep 166
05-13-2016, 01:14 PM | #8 |
Rep 499
05-13-2016, 01:53 PM | #9 |
Rep 387
I can't help much until I get my PSU built, but I dug around in ISTA/D and found that if you're replacing an S55 DME, you need to perform a setting of the fuel injector flow.
I don't know if flashing the DME wipes that data out? Maybe ferrarif1 might know since it sounds like he flashed to CP and flashed back to stock. Injection quantity compensation: If the DME control unit has been replaced, it will also be necessary to carry out adjustment of the injectors! Injection quantity compensation is carried out with the aid of so-called adjustment values. The adjustment value is printed with three digits - depending on the version - on the injector body. The adjustment values must be stored in the new control unit! If injector quantity compensation is not carried out, the engine may run roughly or fail to start. Read off the adjustment values and enter according to the installation location (cylinder) of the injectors: - Connect BMW diagnosis system - Identify vehicle - Select ”Function selection” - Select ”Service functions” - Select ”Engine electronics” - Select ”Adjustment function” - Select ”Adjust injectors” - Select ”Test plan” - The adjustment value must be entered for each cylinder. Edit: Rheingold has conflicting information on another S55 page. Diagnosis instructions Note! The new solenoid-operated valve injectors no longer require injection quantity compensation. The DME learns the adjustment value automatically. An adjustment value is not printed on the solenoid valve injector. Last edited by terahertz; 05-13-2016 at 02:43 PM.. |
05-13-2016, 02:06 PM | #11 | |
Rep 1,061
I swapped a SWFL file with the ZCP one. This is the same change that thisisdave made. |
05-13-2016, 02:13 PM | #12 | |
Rep 499
Injector value recon is a good place to start. Still getting Rheingold set up and ready for first execution; perhaps I can read the values from that application, but I worry I'll need ISTA-P (as opposed to -D) to reprogram the values if necessary. Another thought is whether the TAL-Processing options of set ECU to coding mode and/or set ECU to programming mode will make a difference here... perhaps ensuring both are unchecked is the safe bet coming from a normal map to a ZCP map. |
05-13-2016, 02:20 PM | #13 |
Rep 1,061
After changing the VO to include 7FA and 7MN with a build date of 0316 then swapping the SWFL to ZCP and connecting ISTA/P, ISTA/P complains the wrong DME is in the car and wants to REMOVE it:
05-13-2016, 02:30 PM | #14 |
Rep 387
Interesting that it complains about the VO, when you already changed the VO. Wonder what's missing. Would Rheingold version matter? Maybe it doesn't know about the CP?
05-13-2016, 03:25 PM | #15 |
Rep 1,061
Using the latest ISTA/P 3.58 and PSDZDATA 58.3. SW definitely knows about CP as 7MA and 7MN are listed in the VO summary with the correct description on the summary page before you get this error.
05-13-2016, 03:41 PM | #16 |
Rep 499
Rheingold is in action, airbag and window initialization and headlights are back in order.
DME error for me is as follows: |
05-13-2016, 04:20 PM | #17 |
Rep 387
Fault description The diagnosis monitors enabling of a data status via SWT enabling code.
Malfunction monitoring conditions The fault is detected when a data status to be enabled has been programmed. Condition for fault identification Voltage precondition - None Temperature condition - None Time condition - None Other preconditions - Control unit in after-run Terminal status - Terminal 15 Condition for fault memory entry The fault is entered immediately. Action in service - Enabled DME data with enabling code - Reprogram DME enabling code - Program DME correct data without enabling requirement Fault effect and breakdown warning - Output limit through enabling not being provided Driver information Engine warning light Check Control message: None Service instruction - none What is SWT? Is that the same as an FSC code? |
05-13-2016, 04:22 PM | #18 |
Rep 387
Aww man. It looks like it might be FSC code enabled.
SWT = FSC code http://www.e90post.com/forums/attach...8&d=1275791839 |
05-13-2016, 04:47 PM | #19 | |
Rep 499
maybe I do need to figure out how to harness some HPC cores for brute-forcing after all... |
05-13-2016, 05:51 PM | #21 | ||
Rep 1,061
I can enable retrofits in ISTA/P with FSC codes but there is no "retrofit ZCP DME" choice. Sounds like one of my weekend projects is to learn about FSC |
05-13-2016, 07:23 PM | #22 | |
Rep 499
Yes. |
burble, dme, exhaust, zcp |
