11-01-2016, 05:10 PM | #1 |
Rep 5,623
► Tire Fiment (Non BMW Related)
wheel experts, what would be max comtorable tire size for the following rim setup on a macan:
OEM: - Front: 9 J x 21 RO 26 with 265/40/21 - Rear: 10 J x 21 RO 19 with 295/35/21 finding wider tires for this car is a major pita: Front: 285/45/21 Rear: 325/40/21 ^ would this work?
Cars: 07 335i ► 08 328i ► 11 328xi ► 13 M3 ► 17 M4 ► 14 M6
11-01-2016, 07:07 PM | #2 | |
Rep 1,481
Your 10inch wheel with a 325 would not be ideal, 295 is the most I'd go on a 10'' usually, but since your sidewall is thick, I'd say 305 to keep your ratios the same. in the front I wouldn't go more than a 275. If you want to keep it similar to OEM ratios for front / rear heights, then you should run a 275/40/21 front and 305/35/21 rear. Only issue is I doubt you can find those sizes like you said.. The tire size you listed is a gamble, the setup will be close to an inch taller front and back. You run the risk of rubbing if you are lowering or if the porsche has fender liners / shocks / springs that are close to the tire like how our Ms are. |
