05-28-2018, 01:23 AM | #1 |
Rep 153
Either I am the only person with 20/20 vision that is blind or my '18 M3 does not have an USB port. How is an $80k car missing this? I've searched these forums and there seems to be different placement options but mine is completely lacking - there is no audio connections or plugs of any kind in the shallow space called a center console, and the cubby in front of the cup holders is blank besides a cigarette lighter plug. How am I supposed to connect an iPod or device besides constantly steaming Bluetooth?
Speaking of that cigarette lighter plug, it doesn't work - my lighter-to-USB adaptor will not function when plugged in to that connection but works fine when I plug it into the backseat one. Thoughts? 2018 F80 w/ ZCP and Executive, for the record |
05-28-2018, 08:18 AM | #2 |
Seeking mental floss
482
Rep 806
Can't speak for why there is no USB in yur 2018. I will say, however, that I never use the one in my 2016 M4, because the BT connections works so well. As to the lighter port, I'm sure the dealer can solve that problem, which could be as simple as a blown fuse. Hope you get it fixed.
05-28-2018, 12:56 PM | #3 |
Rep 559
Drives: ///M3
This happened to me on ED. I was prepared to use the extra USB, but I brought a cheap cigarette USB plug as a backup. There was no extra USB (in glove box or under AC controls).
The cheap cig plug didn't work up front so I thought there was a problem. I checked the fuse and it was fine. The plug worked fine in the rear, however. I bought the OEM BMW USB cig/USB adapter and it works fine up front. Must be a slightly different size or shape that doesn't work with all USB adapters. Long story short, depending on the options you may not have any additional USB slots aside from the armrest. Depending on the cigarette/USB adapter it might not work up front. Buy the BMW adapter (which is actually pretty nice, althought overpriced) and you will probably be fine. Last edited by timhatimay; 05-28-2018 at 06:20 PM.. Reason: iPhone+wine = edit |
05-28-2018, 04:04 PM | #4 | |
Rep 1,984
05-28-2018, 04:24 PM | #5 | |
Rep 2,180
The standard USB port is under the armrest. The USB port under climate control is only available if you paid for Wireless Charging.
Post photo of what you got. Quote:
05-28-2018, 11:27 PM | #6 |
Rep 153
No full leather. I'm an idiot and the USB was hiding in the center console under a rubber cover thing that I don't think is even supposed to be there.
As for the cigarette lighter, the car is going into the dealer in a couple days for the 1200 mile break in service so I will see what the issue is. Thanks all. |
05-30-2018, 02:26 PM | #7 | |
///Multiple
2992
Rep 4,243
06-26-2018, 07:51 PM | #9 |
///Multiple
2992
Rep 4,243
Just for the record, there are three 12V ports in the passenger compartment on my 2016 M4:
There's also a USB port in the center console compartment. You can also add an additional USB port in the glove box which can be used for an additional music source. I run two iPods like this. There's a DIY in the F30 forum that's been referenced in the F80 forum as well.
01-29-2021, 10:09 AM | #10 | |
Rep 14
