      01-19-2020, 10:04 AM   #1
ALCOBENDAS
Drives: M3 F82
Real Differences M4 2015 vs 2016 facelift 1
Hello, I was sure that I was going to buy an m4 since 2016 since at the end of 2015 with the update of the M3 things were also improved in the M4 (chrome strips in aerators) and now it turns out that I have seen a good unit of 3/2015. .
My question is ... what real differences are there between 2015 and 2016 (none with led taillights) but if there was something in the ac control and navi .. can you tell me exactly if it deserves the purchase of 2015 or better I keep thinking about 2016 or newer
I have seen a post where he says the changes .. but not in depth .. as for example the navi pro says that it is faster but already this one .. I would like real use opinions not what bmw said in his day ..
thanks
      01-19-2020, 05:02 PM   #2
HyeM3
HyeM3's Avatar
Drives: BMW M3
I believe early 2016 production cars are the same as 2015's but with the new taillights. Late 2016 production cars have a newer version of idrive so you get CarPlay and some other apps. Navigation will probably be slightly updated too
      01-19-2020, 05:07 PM   #3
behindthen0thing
behindthen0thing's Avatar
840
There are minor differences. Some software changes and vehicle calibrations. The crank hub got an updated bedplate at some point. There are 5 bolt strut towers instead of 3 like on the 15.
The idrive system might be a newer version.
If you plan on modifying the vehicle the changes are mostly inconsequential.
      01-19-2020, 07:07 PM   #4
ALCOBENDAS
Drives: M3 F82
Thanks but the screen its the same resolution?
      01-19-2020, 07:15 PM   #5
ALCOBENDAS
Drives: M3 F82
vehicle calibrations I don't worry too much since the first one will go to bmw to update all the switchboards, later on I will update everything to gts bootmod and others .. Can you tell me more about the crank hub? I have already asked for the screw lock is something I will mount before increasing the power
I am interested in the real differences of the idrive .. if it has much more resolution or something really interesting I do not want to lose multimedia options the truth .. if it is only carplay I do not worry I'm from android
      01-19-2020, 07:29 PM   #6
HyeM3
HyeM3's Avatar
Drives: BMW M3
Yeah it'll be the same resolution. They switched to touch screens a year or two ago and that's probably when the resolution was increased, if at all
      01-20-2020, 02:02 AM   #7
behindthen0thing
840
I am interested in the real differences of the idrive .. if it has much more resolution or something really interesting I do not want to lose multimedia options the truth .. if it is only carplay I do not worry I'm from android [/QUOTE]
If you're going to program euro mdm, update calibrations, install a keyed crank hub,
Honestly just go whichever car has the best options you're looking for, like if you're hung up on the tail lights or the headlights, or the specific interior or options etc.
The engines and trans are all the same etc.
Performance wise as far as I know they are the same, with the exception of the cs being more than the zcp, and the zcp having slightly more performance than the base. In those cases it's mostly due to programming so if you're tuning and modding it doesn't matter unless you want the zcp seats, or the cs/GTS hood etc
      01-20-2020, 02:18 PM   #8
ALCOBENDAS
Drives: M3 F82
I only cared about the first restyling that was still without led headlights or touch screen hehe, thanks
      01-20-2020, 02:27 PM   #9
ALCOBENDAS
Drives: M3 F82
Performance wise as far as I know they are the same, with the exception of the cs being more than the zcp, and the zcp having slightly more performance than the base. In those cases it's mostly due to programming so if you're tuning and modding it doesn't matter unless you want the zcp seats, or the cs/GTS hood etc[/QUOTE]
First I will go to BMW to update all the switchboards but without doing anything special .. in the future if I will update everything to GTS or similar ..
I have the bolt capture of vtt what do you think of that?
I was only interested in some improvement or something important if everything is the same I think I will buy this unit that carries all the extras that could be dialed in 2015 .. but it has no wireless phone charge or something else that came out later .. yes the browser is much better in 2016 I preferred to wait for a 2016 .. that's why I asked
Thanks all
      01-20-2020, 03:27 PM   #10
SD ///M4
///Multiple
SD ///M4's Avatar
For the 2015 M3/M4, cars produced prior to September 2014 had a magnesium oil pan which used an aluminum Allen screw for the oil drain plug and the plug had to be replaced at every oil change.
After this date, BMW changed to either an aluminum or steel oil pan which uses the standard reusable 17mm steel drain plug and only the copper crush washer is replaced at every oil change.
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18
The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
      01-20-2020, 03:47 PM   #11
ALCOBENDAS
Drives: M3 F82
Im looking 03/2015 unit
      01-20-2020, 06:53 PM   #12
notnow
Bit by Modbug
258
Drives: F86
These are the only notable facelifts to look for, IMO:
2016 has ZCP, if you're looking at base then it it doesn't matter
2017 has newer iDrive
2018 has new headlights and tail lights (expensive to retrofit so if it matters to you a lot then you would want a 2018)
Current: F86 | F30
Past: Cayenne GTS | Abarth 500 | YMB M4 | X6 M50i | E92 M3 6MT | X3 M40i | E92 335i Stage 3 | G35 Coupe
