02-06-2016, 10:23 AM | #1 |
FAST
371
Rep 574
E-Sys can't connect. Target blank.. Help
I just can't seem to connect using e-Sys (With E-Sys Launcher)
I've tried 2 computers with the same result. V 3.27.1 Using Launcher with F080 Basically I am unable to select a target. Connect via VIN looks correct Connect button isn't highlighted. Any suggestions would be appreciated. |
02-07-2016, 04:15 AM | #3 |
Rep 812
Silly question, but have you tried uninstalling and reinstalling? Also, try closing it and reopening it. Select a lower memory and see if it works. When the Java environment runs out of room if can go crazy. Oh, also try restarting the machine. Java runtime can keep memory bottled up even after you've closed all the programs that use it.
2016 Azurite Black F80 6MT
02-07-2016, 05:19 PM | #4 |
Rep 499
Drives: California Packet
Location: Left edge of browser window beneath 'join date' obvi
What happens when you click "Read parameters from VCM" (the very last radio button)?
Edit: I see you're missing selections up top. Can you confirm you've dropped in the PSDZData into the proper place within C:\Data? |
02-07-2016, 06:17 PM | #5 |
Rep 40,771
Drives: 2018 Alpina B6 650ix GC
If the "Open Connection" window under "Target" is empty (no targets), verify the following:
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
02-08-2016, 01:36 PM | #6 |
FAST
371
Rep 574
Ok, I had installed the "sdzdata" folder incorrectly.. twice...
C:\Data\psdzdata Now I have to deal with the launcher stuck in F20 mode for a few more days. (I switched it when just trying to see if I could get the system working) If it starts in F20 mode, what are the downsides? Should I just wait my 2 days? Last edited by JMon; 02-08-2016 at 01:47 PM.. |
02-08-2016, 01:42 PM | #7 | |
Rep 40,771
* NOTE: E-Sys Launcher 2.x Car Series MUST be set to exactly match the car's chassis type you are coding (e.g. F01, F06, F07, F10, F12, F15, F25, F30, F82, F83, etc.). If after install it defaults to F999 and it cannot be changed, change PC Date ahead 4 days, then change E-Sys Launcher Car Series, then change PC Date back to current date. DO NOT create .EST Token and PIN with PC Date advanced 4 days as the Validity Start Date for the token will be 4 days in the future.
10-16-2016, 04:31 PM | #8 | |
Rep 1,094
Having trouble downloading PSdZData_Lite file....it keeps timing out on me. Now I have to wait a day because I've exceeded the download threshold. So frustrating. Does anybody have a file/link I can download from? I have everything else. |
10-16-2016, 04:33 PM | #9 |
Rep 40,771
There is no daily download limit for MEGA that I have ever seen.
10-16-2016, 04:40 PM | #10 | |
Rep 1,094
Thanks for the PM though, Shawn. |
10-17-2016, 02:18 AM | #11 |
Rep 8,364
If you use Mega Sync or clear your Mega cookies then you will be fine.
10-17-2016, 05:25 PM | #12 | |
Rep 3,945
Drives: 2015 M4 MG/SO
10-17-2016, 07:43 PM | #13 |
Rep 8,364
12-05-2016, 01:31 AM | #14 | |
Rep 47
Target still not showing
I put the psdzdate folder into the data folder. The default chassis folder was missing some files so I created them along with an empty dist folder for each. Here are my settings: What else am I doing wrong? The default chassis folders contains other folders and files but I only created an empty dist folder as instructed, could that be the problem? I appreciate any help I can get. Last edited by Eight3Two; 12-05-2016 at 01:41 AM.. |
12-05-2016, 06:01 AM | #15 |
Rep 3,945
The folder needs to be called psdzdata under C:\Data, check your screenshot... and please do read the PDF instructions that Shawn sent you, carefully and many times.
packetpilot265.50 |
12-05-2016, 06:02 AM | #16 |
Rep 40,771
12-05-2016, 09:29 AM | #17 |
Rep 47
12-05-2016, 09:36 AM | #18 |
Rep 40,771
What version of E-Sys are you using?
12-05-2016, 09:47 AM | #20 |
Rep 40,771
Delete PSdzData folder and replace with latest version. If you still have error, update E-Sys to latest 3.28.1. PM Sent.
Eight3Two47.00 |
12-05-2016, 04:08 PM | #21 |
Rep 47
12-05-2016, 04:11 PM | #22 |
Rep 40,771
