Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > Regional Forums > AUSTRALIA
      11-21-2019, 05:10 PM   #1
nash_86
Drives: 2016 BMW M4
MPE / Akra exhaust with catless DP's
I've already pulled the trigger on buying VRSF catless DP's.
Do I still need to get MPE / Akra to improve the mediocre stock exhaust sound or will the DP's suffice?
      11-21-2019, 05:15 PM   #2
aBMWfan
Drives: 08' M3/'15 M4/ '06 M3/ '09 M3/
Start with DP’s, then, resonator delete, then decide
      11-21-2019, 05:45 PM   #3
ArialBlack
ArialBlack's Avatar
Cote DIvoire
Whatever you do - keep at least 1 set of cats in your system or you're in for rasp city
      11-22-2019, 06:12 AM   #4
mmmmQuattro
mmmmQuattro's Avatar
Australia
259
Drives: f83 / E93 335 / E70 X5 40d
+1
don't fall for spending too much on a rear muffler box, there's a lot of sound difference in the centre section.
I would recommend replacing the centre resonator with two after-market resonators and a H-Pipe to balance the sound.
Have a look at this thread: https://f80.bimmerpost.com/forums/sh....php?t=1656403
      12-24-2019, 06:53 PM   #5
ATSE
Australia
Drives: 2017 M3 ZCP
I installed VRSF DP's a while back - and the volume increased significantly. I have a stock ZCP setup. Invest in a exhaust valve controller and keep the valves open - that should keep you happy.
