01-06-2020, 11:24 AM | #1 |
Rep 108
Replacing coils?
My car has about 54k on the clock and I will be changing the spark plugs over the winter. While I have everything torn apart I was wondering if it is worth changing the coils or if that is unnecessary since I am not having any issues with the current setup?
01-06-2020, 02:48 PM | #2 |
Rep 285
Drives: 2017 M3 Comp
If you're not having any issues / loss of power, I'd leave it.
01-06-2020, 03:04 PM | #3 |
Rep 108
01-06-2020, 07:45 PM | #4 |
Rep 763
I'm at the same mileage and about to change plugs, install charge pipe, intakes and charge cooler. I was thinking about changing the coil packs as well as i had 2 go out in old bmw at 80k. I think I will hold off on changing the coils, but I was thinking to order 2 and keep them in case I need to replace them.
01-07-2020, 11:11 AM | #5 |
Rep 6,723
But why? Why spend the money, hold on to the inventory, on the off chance one of the coil packs go south? It’s not like these are unicorn parts and have an extremely long lead time.
By that logic, you might as well buy a spare alternator, water pump, relays, and any other sort of item that used to go out on the older platform (I was going to say SMG relay lol). |
nioh_lbbm21716.50 |
01-07-2020, 11:40 AM | #6 | |
Rep 1,899
01-07-2020, 01:41 PM | #7 |
Rep 18,823
Stock or tuned? If tuned, it wouldn't be a bad idea to replace the coils at the same time.
01-08-2020, 08:34 AM | #8 |
Rep 108
01-08-2020, 12:19 PM | #9 |
Rep 18,823
Replace them now. Tunes running higher boost demand a bit more from the ignition system, it'll be one less thing to worry about when turning up the boost later on down the road.
01-08-2020, 01:20 PM | #10 |
Rep 6,723
How many people actually replace their coils when running a tune, let alone a conservative one?
I can see replacing plugs. I guess. |
01-08-2020, 01:31 PM | #11 | |
Rep 18,823
BMWs have always had weak coils, even in normally-aspirated form. By replacing them early, you're simply getting a head start on a maintenance item, instead of paying labor again to go back shortly thereafter.
TrauCon59.50 |
