04-10-2020, 08:52 PM | #1 |
Rep 1,030
295/35/19 vs 305/30/19 Michelin PS4S
Hey guys many of you like me are probably deciding between 295/35/19 tires and 305/30/19. It seems like it wouldn't make much difference or feel much different, but that can't be farther from the truth. The grip levels are increased, ride has gotten even more compliant and there is ZERO rub. I paid the additional and I think knowing what I know now, I would've gone 305/30/19 from the beginning! I hope this helps the community and shows you how millimeters can change the look of the car overall. Let me know if you have any questions.
The Wheels: Signature SV104 Gloss Black F: 19x9.5 et20 R: 19x11 et40 *This is 295/35/19 pictured above *These 3 pictures above are 305/30/19 above JD |
04-12-2020, 09:25 PM | #3 |
M4 748(a)
630
Rep 427
I ran into this same issue, and the dramatic difference between the two sizes is specific to the PS4S. The 295/35/19 is a Mercedes-spec tire with a tread width of only 9.8". Compare to the previous generation Pilot Super Sport, for example, whose 295/35/19 had a tread width of 10.4", or the 295/35/19, Continental SportContact 6, which with its 11.6" tread width is even wider than the 305/30/19 PS4S at 11.5"!
Nice looking car!
2018 Ferrarirot F82 |
04-12-2020, 10:50 PM | #4 | |
Rep 1,030
JD |
04-17-2020, 11:44 PM | #5 | ||
Rep 2,028
Drives: INDIVIDUAL F90 M5C LCI
Any suspension/spacers? Quote:
CURRENT: '21 M5| FSHNGRY | TARTUFO | CCB | MPE | KW | IND | EVENTURI | EISENMANN | DINAN | LOADED |
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG | IG: @FSHNGRY |
04-17-2020, 11:45 PM | #6 | ||
Rep 2,028
Do the 305's fit stock 19"? (Non comp) I am also running KW Has and 12mm x 4 .. This makes so much sense. I need this now
JDE92M3874.00 |
04-18-2020, 02:16 AM | #8 | |
Rep 1,030
JD |
FSHNGRY2331.50 |
04-18-2020, 04:04 AM | #9 | |
Rep 1,030
*PS don't mind the messy garage or the wildlife Panda... JD |
FSHNGRY2331.50 |
04-19-2020, 09:43 PM | #10 | |
Rep 2,028
JDE92M3874.00 |
04-21-2020, 02:50 AM | #11 | |
Rep 1,030
JD |
FSHNGRY2331.50 |
05-31-2020, 02:31 AM | #14 |
Rep 1,030
06-01-2020, 08:57 AM | #15 |
Rep 1,261
Drives: 2016 M4 GTS
Mannnn if people dont stop being scared to run a 305/30/19 tire. My rear is slightly tucked and I can still add a small spacer!
Wheel: BBS FI-R 19x10.5 +35 Tire: Michelin Pilot Sport Cup 2 305/35/19 Rear Alignment: -1.8 camber and .10 toe on each corner
2016 M4 GTS Alpine White
2021 X5M Competition Marina Bay Blue Instagram: @JustAnothaM4 |
06-02-2020, 09:04 AM | #17 |
Rep 1,261
Drives: 2016 M4 GTS
Excellent once they have some heat in them...These will be my tire of choice during the warm months.
JDE92M3874.00 |
06-03-2020, 09:37 AM | #18 | |
Rep 1,030
JD |
06-03-2020, 09:38 AM | #19 |
Rep 1,030
07-27-2022, 09:44 AM | #20 |
Rep 13
How did this setup age for you over time? Any rubbing? I'm about to run the same ps4s tire combo on a set of BBS LMs 19*9.5 et22 and 19*11 et37. I'll also be running Ohlins R&T coilovers. Currently the car is on swift spec R springs and OE ZHP tire/wheels but I've never been super happy with the ride.
08-20-2022, 09:30 PM | #21 | |
M4 748(a)
630
Rep 427
