02-01-2016, 04:21 PM | #1 |
Rep 92
Radiator fan running constantly and fix
I didn’t find much on the F8x forums about this problem and the fix, so I wanted to share my experience and fix.
About a week ago I noticed that my radiator fan started running at full blast all the time, even when cold starting in the morning. When stopped at a red light, I could also hear the fan vary a lot in speed, which was weird. I checked coolant reservoir and all was ok. Since my 10k miles service was already scheduled (for today), I just waited until I brought it in. At first they thought it was a water pump problem (I did read online that a constantly running radiator fan is a possible indicator of a soon-to-fail water pump), but they confirmed all was ok with the pump and no leaks in coolant system. Hmmm. Then they checked the A/C system. According to my SA, BMW sometimes over-charges the system from the factory?? Sure enough, my system was over charged. BMW spec is 550gr, and my system was at 649gr. They re-charged the A/C system to the correct factory spec of 550 gr. This appears to have fixed the always-on fan problem. I’ve only driven it about 20 miles since picking it up from service, but the fan is not running constantly anymore. I'll keep on eye on this to make sure the A/C over charge was the culprit, but just wanted to share with everyone. Has anyone else had this fan-always-on issue, and the fix was A/C over charged?
___________________
M4Apex... 2015 M4 | BSM on Black | M-DCT | Adaptive M | 437 M Black | Exec | LED | Drivers | HK | CF Roof | MS EVC | MS 15/12mm | iND black bits | M CF lip and side blades. Previous fun... '06 997 C2S, '11 Evo X MR, '07 335xi, '10 GTI, '08 Ducati 848, '04 S4, '01 S4, '01 TT 225, '96 CBR900, '92 CBR600 & more. |
02-01-2016, 04:40 PM | #2 |
Rep 18,798
Never heard of the issue you are describing. However, thanks for taking the time to explain the problem and following up with a solution.
fackamato66.50 |
02-04-2016, 09:35 AM | #3 |
Rep 92
well, I guess I spoke too soon. All was fine for a couple days. The radiator fan started running on high again a few seconds after starting the car this morning. And by the time I got to work (about 15 min drive), the radiator fan was varying a lot in speed from high to low, etc. I took a quick video at:
I'm dropping back off at the dealer this morning. I'll update when they figure it out.
___________________
02-04-2016, 12:42 PM | #4 |
Rep 6,587
That is annoying, let us know what they find.
02-05-2016, 09:19 AM | #5 |
Rep 92
yup... annoying!!
Quick update... a/c pressure sensor failed. Easy fix, but that caused over pressure condition in a/c system, which caused a/c compressor to fail. This apparently causes radiator fan to run on high with varying speeds, which is my symptom. Compressor is not in stock in US, so they are ordering from Germany, 2-3 weeks. At least its February and cold out! And bonus!!... they washed the M4, so saved me the time this weekend. I'll post an update after the new sensor and compressor are installed.
___________________
02-05-2016, 10:38 AM | #6 | |
Rep 41
Drives: M4 Alpine White 6 MT
_______________________________________________
2016 M4 - 6MT 1995 M3 -5MT (sold) 1984 323i -5MT (sold) 1980 323i -5MT |
02-06-2016, 03:30 PM | #7 |
Rep 92
Must be coming by boat!!
___________________
02-10-2016, 05:41 PM | #8 | |
Costco Member
42
Rep 75
I've got the same issue - taking it in to the dealer tomorrow. Amazing that this thing only 8K miles on it, and so far the side cameras have failed - condensation in the headlamps, and now this. Come on BMW - I know nothing is perfect, but really?
2015 Sakhir Orange M4/6MT/Adaptive Headlights & Suspension/Tech Package
02-12-2016, 08:39 PM | #9 |
Rep 10,509
Are you guys sure it is an "issue"? I always interpreted it to be a designed feature, namely the massive cooling capacity of the car that keeps oil temps in check even in 100F ambient temps at the track.
Another thing to keep in mind is that sport+ seems to turn the fan on more, because the oil temperature is kept lower than in sport or efficiency throttle mode. Good luck OP with your AC fix. That said I think if the car is not overheating and the AC is blasting cold air, call it normal and just enjoy the car. |
02-13-2016, 10:36 AM | #10 | |
Rep 92
But, I would never hear the fan immediately after cold start in the morning, esp during 10F-20F winter weather. And I have had the M4 for about 9 mths, and 10,000 miles of driving. So the sudden full high speed of the radiator fan upon cold start really stood out to me. And the constantly varying speed of the fan, from high to low, back to high, etc. It just started suddenly a few weeks ago. Dealer diagnosed as a failed a/c compressor. They installed the new compressor on Thursday, but then broke the tabs on re-installing one of the intakes when putting it all back together. I'm yet again waiting for a part from Germany. I should have the M4 back in a week or two. I'm anxious to see if the a/c compressor was really the culprit.
___________________
02-14-2016, 10:59 PM | #11 | |
Das it.
68
Rep 358
Actually worried now lol.
F82 M4. |
02-15-2016, 12:28 PM | #12 | |
Rep 6,587
Unfortunately for Chris, he is experiencing it but it will get solved. |
02-16-2016, 05:48 PM | #13 | |
Das it.
68
Rep 358
F82 M4. |
03-03-2016, 05:30 PM | #14 |
Rep 92
finally fixed!
I finally got my M4 back after 18 days at the dealer, waiting on parts from Germany. M4 seems back to normal, but I've only driven about 200 miles so far. The a/c condenser had a leak (caused by the failed pressure sensor) which was causing the radiator fan running on high/varied speeds all the time. They replaced the condenser and a/c pressure sensor, and all seems ok.
And in my earlier post, I mentioned it was the a/c compressor that failed. My bad. I simply misread the tech's notes, and probably didn't listen too closely to my SA. It was always the condenser. So, life returns to normal with my M4. I had an X4 28i loaner for the 18 days. It was nice and all, but WOW, did I miss my M4!!! Makes you truly appreciate the M4!!!
___________________
05-12-2017, 02:44 PM | #15 |
Rep 834
I'm having this exact issue. First AC died. Then noticed the engine fan starting and stopping even when cold. Dropping off car Monday. 2016 M4 F82
05-23-2017, 09:39 AM | #16 | |
Rep 1,336
Thanks for posting |
05-23-2017, 01:02 PM | #17 |
Rep 3,945
Drives: 2015 M4 MG/SO
Funny, mine is behaving different than before, but I use S+ all the time, and I think the fans are supposed to kick to keep the engine cooler. But I did notice a different behaviour when I started using the AC... will keep an eye. Thanks OP.
Can't believe your car was at the dealer for 18days!!! |
06-03-2017, 01:01 PM | #19 |
Rep 6
Drives: 2008 BMW X5 3.0
Lucky you
I had the exact same problem with my X5, NO coolant loss , No HI temperature NO warning, just a loud fan... Long story short took it to a the CROOKS at Momentum BMW Houston and they "said" (claimed) they changes the water pump the thermostat and couple more things. thousands of dollars and the actual fix was as simple as you said because the AC was overcharged... That's why i said lucky you, you got a conscientious dealer/service person.
02-16-2018, 03:44 PM | #21 |
Grand Duke
1540
Rep 1,114
Drives: 2023 M4CSL
My car just started doing the exact same thing as in the OP video. And the AC don't blow cold.
2023 M4CSL
2005 Lotus Elise |
05-13-2019, 08:02 AM | #22 | |
Rep 195
