05-17-2016, 05:49 PM | #1 |
Rep 891
M4 Oil consumption help?
Hello,
Just 2 weeks ago I bought a 2014/2015 M4 with 7.000 miles, the car was imported from USA to Germany and fully converted to euro spec (lighting,miles to km etc) all the small things necessary to register the car in germany. Before I bought the car I checked the VIN at BMW dealer and no red lights where there, the history was ok. Since than I did around 2.000km (1.200 miles) and the oil minimum warning came on, so I went to the BMW dealer and bought 1 liter of oil and immeadetly scheduled for a service since the car had a low number of miles. After pouring around half a liter of oil in the engine, I warmed up the engine drove a couple of miles and it was still showing minimum, than I poured the other half liter and it was showing full immeadetley. Since than I have done around 500miles of normal driving and again its just over minimum??? The car is 100% stock and I am very worried about it, do you guys have any experience with oil consumption?? Especially since the car is performing normal and nothing out of the ordinary? Thank you very much for your help |
05-17-2016, 06:06 PM | #3 |
Rep 10,509
05-17-2016, 06:07 PM | #4 |
Rep 245
When you fill it up is there a visible indication that it is full? Can you see the top of the oil or are you going on the sensor alone?
If it were just a bad sensor, filling it more and more would likely cause it to overflow. Is there a puddle of oil under the car? Is there bluish/oily exhaust? Do you smell burning oil? Is the engine making odd sounds or running irregularly? Is the engine overheating? In any case, get it to a dealer.
2018 M4 MGM/SO
05-17-2016, 08:41 PM | #5 |
Rep 431
I think it says it's normal for a car to use I think it was either 1.0 or 0.9 quart of oil every 600 miles in the manual somewhere, so they might just say it's normal and send you on your way if the sensor is not bad
Current Cars:
2017 GT350 2018 Mineral White M3 2015 ML63 AMG |
05-17-2016, 08:46 PM | #6 | |
Rep 394
Drives: 2015 MW M4
05-17-2016, 08:48 PM | #7 |
Rep 431
I'm sorry I got the car's mixed up, it says that in my other car's manual, I don't think it says that in the m3 manual, I apologize.
Current Cars:
05-18-2016, 01:17 AM | #8 | |
Rep 891
There is no smoke and the temperature is keeping great even after flooring it a couple of times through gears. I am scheduled for tommorow at the dealer. I thnik they will just make an service and tell me to monitor the oil level now that the oil has been changed. |
05-18-2016, 06:56 AM | #10 |
Rep 1,319
Get an oil change, and use that as your baseline. Can be an oil leak, can be burning. Fresh oil change will help establishing if there is a problem.
I have had n52 engines in my old x3 and 330i, identical motors, one burnt quart every 7500 miles, the other one consumed 1 quart every 1200 miles. It was annoying for sure as the car had less than 100 k on it. Dealers don't think it's a problem unless it's consuming quart of oil every 750 miles.
2016 F80 M3 BSM with Black interior DCT/Driver Assistance/Executive/LEDs/Adaptive/Black Wheels
2014 F32 435i xDrive AW/CR 2014 F25 X3 M-Sport Carbon Black 2011 e92 335is 2007 X3 122k miles 2006 e90 330i 132k miles |
05-19-2016, 10:45 AM | #11 |
Rep 891
UPDATE:
Just got off the phone with my dealer and they say that they see a some grease and oil drops from the oil cooler and that it needs to be replaced. Apparently it was slightley pressed against a curb or something?! So they can not measure the exact oil consumption until the cooler is replaced, so I will order a new oil cooler. The biggest BS is that they are denying me any kind of warranty because the car is from USA and imported in Europe. (I was not trying to get the cooler replaced under warranty). They say since the side markers have been removed the car has been tempered with so there is little to no chance I have a valid warranty. However since there were just a few grease spots (no puddle) and I was missing a quart over 600 miles I doubt its from that, but seems I have to go step by step. |
05-28-2016, 02:02 PM | #12 |
Rep 891
So I have replaced the oil coller what the dealer said it had some oil drops and done a oil change.
Unfortunatley still the same, I have done 500 miles and half a quart is missing??!! I think that is a bit much. I will go there on monday again and insist they take a look at it under waranty. |
05-28-2016, 09:04 PM | #13 |
Rep 431
You might be facing this http://f80.bimmerpost.com/forums/sho....php?t=1249588 maybe they will take a look if you point it out
Current Cars:
06-01-2016, 11:02 AM | #14 | |
Rep 891
But unfortunatley they say if if uf to 1 quart to 1000km BMW doesnt think it is a problem. I told them about the valve cover leak in the post above and they say nothing can be seen from their check. the car performes great, pulls hard and no codes or faults. Dont know what to think, should I insist on the dealer or just come to peace with it because its driving me nuts ) Not even my E46 M3 has nearly that much consumption and it has some miles on it.. |
06-01-2016, 11:39 AM | #15 | |
Rep 431
Current Cars:
06-02-2016, 07:03 PM | #16 |
Rep 601
If I a reading this right, they denied replacing the oil cooler under warranty because the car is a US car? If so, my bigger concern would be no warranty. I wouldn't want to drive the car at all until that's resolved.
2015 AY M4
06-03-2016, 01:48 AM | #17 |
Rep 891
They have denied me warranty because they had no record of first 1.200 mile service being done.
I sorted that thanks to a forum member who sent me the us history of the car. So waiting on their response now. |
06-03-2016, 05:53 PM | #19 |
Rep 891
06-04-2016, 06:22 AM | #21 |
Rep 615
Her buddy... Try us spec bmw friendly dealerships in Germany
Autohaus Euler in Kaiserslaughtern Autohaus Rhein in Wurzburg AutoHaus Hoffman in Regensburg Autohaus Praller in Duerling They help folks with us spec cars all the time and under European warranty... Last edited by MSport_Jon; 06-20-2016 at 03:28 PM.. |
06-04-2016, 01:57 PM | #22 | |
Rep 891
By the way this forum has been so helpful and its members truly help another. |
