04-11-2019, 09:15 AM | #1 |
Rep 229
Maintenance When you car tells you?
Seems people do oil change spark plugs etc when the maintenance light for service comes on? This would be the best recommended time right ? Or do we as m3 owners do maintenance before the service light comes on ? Im just confused I want to have a healthy motor but not sure if I do the maintenance before service light or just wait for service light then bring into Bmw?
04-11-2019, 10:39 AM | #3 |
Rep 2,147
When I came in for break in service, I asked my service adviser if they had a service schedule. I always ask for one for every car I buy to weigh cost of service/interval/necessity.
He looked at me like a deer in headlights and said BMWs are different, you just come in when your car tells you to. It knows everything that needs to be serviced at the correct time. I called BS, and just found the service schedule online. I've attached it here. |
04-11-2019, 11:23 AM | #4 | |
Rep 3,396
“Time intervals should be followed using the maintenance interval as indicated by the BMW Condition Based Service.
04-11-2019, 11:25 AM | #5 |
Rep 2,147
Not sure, but I was referring to my SA telling me service schedule/documentation not existing, not objecting to the CBS. If you read further in the documentation, there's recommended intervals for anything important. That is what I was calling BS on
shortseller1002.50 |
04-11-2019, 11:35 AM | #7 | |
Rep 3,396
As to the extras you mention above, Those are usually done at service intervals as well. For instance the second or third oil change depending on mileage or time gets you brake fluid, plugs etc. the diff fluid has become something of a weird spot for bmw, they seem not to require it but most know that to keep long term care helps, so why not replace, but it comes at owners costs. Also use to be you could squeeze in a brake job when it was 4yrs/50K. Those days seem gone too.
05-06-2019, 07:37 PM | #8 | |
Rep 646
Is this a correct guess? I don't feel any particular need to run in to get the car serviced immediately (7,000 km mileage in total) - I am sure I could put it off till June. |
05-06-2019, 08:31 PM | #9 | ||
Rep 6,862
03-09-2020, 03:07 PM | #10 |
Rep 2
Oil change interval
I’m in the process of buying BMW approved used 2015 M3 from a BMW dealer. The car has done 62k miles and the service history provided by the dealer is as follows
24/03/2015 1389 miles Running in Service 08/01/2016 18017 miles 23/01/2018 37917 miles 04/02/2020 61841 miles Since 2nd service and the car has done 20k miles and 24k miles between services Is this normal ? I’m new to BMW, any help would be greatly appreciated. |
03-09-2020, 03:28 PM | #11 | |
Rep 499
03-09-2020, 03:31 PM | #12 |
Rep 485
its probably OK. but 3x the interval I am comfortable with for oil changes. No way to know if the previous owner did their own oil changes or anything else in between. I would avoid this one myself.
03-09-2020, 11:29 PM | #13 |
Rep 2
Thank you for the reply. The dealer said “ The service intervals on BMWs now is every 18,000 miles, 24 months or condition based, depending on your driving style the car will tell you when the next service is due “
So by their own admission it looks like its been driven more than 6k miles over the limit before the last service. |
03-10-2020, 10:32 AM | #14 | |
///M SubDriver
1833
Rep 2,782
Drives: 2017 M3, 2020 X7 40i
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
03-12-2020, 10:16 AM | #15 | |
Assistant TO the Regional Manager
617
Rep 728
It is still a good document because it talks about different services performed with each CBS indication, because that isn't usually mentioned in BMW maintenance literature but still not the typical "maintenance schedule" we are used to seeing from other manufacturers.
2018 M4 Coupe. 6MT.
Der stärkste buchstabe der welt |
03-12-2020, 11:14 AM | #16 | |
Rep 2,147
- transmission fluid - differential fluid - coolant - spark plugs - O2 sensors - air filters - ventilation filter What I couldn't find specifically in the doc: - Engine oil, but it's common knowledge this is 5-10k miles/1 year with synthetic oil on almost any car - Brake fluid, which from my research every 2 years is recommended. - Belts I don't necessarily love the answers in the doc to every maintenance item, but I can't think of anything missed that isn't already naturally changed at a "CBS" as-needed interval, such as brake components, shocks, and battery. A lot of the above piggybacks off of which # oil change, but to me that's just another way of describing it vs. saying something like "at every 20k miles." It may not be as specific as we're used to, but I think it's good enough for most as a general guideline, and certainly better than my service adviser telling me the entire car is CBS, which is what motivated me to find the above doc in the first place. |
