05-09-2024, 08:02 PM | #1 |
Rep 1
M4CS low oil
After taking my 2019 M4cs to the shop to have the pcv valve and oil pan gasket replaced I checked the oil level and it said it was at minimum and to add a quart. I looked at the invoice and it said they added 7 quarts and the CS takes 8 quarts so I added .6 quarts to see if it would change the reading and it is still at minimum. Should I be scared to add anymore? Thanks for the help
05-10-2024, 09:16 AM | #3 |
Rep 961
Is either low on oil or your sensor is bad. Sensor goes bad, it has happened here and there. If you keep adding oil and says it's still low, the sensor is the culprit. Sensor is mounted on oil pan.
M4CS Frozen Blue
M4ston0.00 |
05-10-2024, 09:23 AM | #4 |
Rep 1,042
Drives: BMW X5M, M3 ZCP, MB E63 AMG
I suggest taken the car on a 20 minute drive to get the oil nice and hot, then remeasure it, then measure it again to truly verify that the level is correct.
M4ston0.00 |
05-10-2024, 11:01 AM | #5 |
Rep 319
Check if the spacer is installed it’s goes between the the oil sensor. If the spacer isn’t installed it shows low.
I wouldn’t add more oil if you don’t have any oil leaks. If you’re missing the spacer you can order it from Bimmerworld |
M4ston0.00 |
05-10-2024, 01:29 PM | #7 |
1323
Rep 2,004
Take it back to the shop. They seemed to have messed something up so it's their responsibility to fix it.
M4ston0.00 |
05-10-2024, 05:05 PM | #8 |
Rep 2,822
As has been said many times, if only someone would invent something like a metal rod, perhaps with a minimum and maximum marker on it, that you could quickly pull out and see exactly how much oil was in your car. Probably could call it a dipstick or something.
Honestly it boggles my mind that BMW have gone all electric for measuring oil
2020 M4 competition Mexico Blue / Opal white ultimate pack, full M perf carbon kit, MP HAS, Carbon Ceramics, 763M with cup2’s.
Instagram c1_cdg |
