08-01-2022, 11:52 PM | #1 |
Rep 335
BM3 Stage 2 Supporting Mods
Hi all,
Have a F80 M3 2018 w 30k miles, planning to run stage 2 on 93 with BM3 once crank hub is done. Any supporting mods/upgrades worth looking into? Currently have upgraded charge pipes, intakes and catless DPs, and will get new spark plugs (probably done with the CH). Was looking at top mounted intercooler, heat exchanger, oiler cooler, mosselman thermostat, etc. Don't plan on tracking it, it'll be more for daily road use. Thanks! Last edited by Pewtinn; 08-02-2022 at 12:10 AM.. |
08-02-2022, 12:17 AM | #2 |
Rep 3,726
Just the heat exchanger will do.
Everything else you listed is unnecessary for a street car. Mosselman thermostat keeps the engine oil too cool. By letting the car run up to temperature in sport mode (226f), you burn off water in the oil and extend the life of the oil.
Pewtinn105.00 |
08-06-2022, 09:08 PM | #3 | |
Rep 335
08-06-2022, 09:10 PM | #4 | ||
Rep 3,726
You could also get a fuel filter kit from Bend Calibration. It's a good safety item to have to avoid killing injectors from bad ethanol.
08-06-2022, 09:21 PM | #5 | |
Rep 335
Also a few questions about the flex fuel kit if you didn't mind - 1. In the PTF site, should I be getting the 'include flex fuel sensor' option? 2. If I did my research correctly, you fire up Multimap (stage 2 for me), and it will automatically adjust to the E mix, whether I have full 93 octane or partial E? Last edited by Pewtinn; 08-06-2022 at 10:11 PM.. |
08-06-2022, 11:45 PM | #6 | ||
Rep 3,726
1) Yes 2) Correct
Pewtinn105.00 |
