05-16-2016, 02:27 AM | #1 |
Rep 1,514
Help need with replacing LEd headlight
I replaced my headlight and the "new" used one is giving me problems.Turn signal is not working. the turn lights on back and mirror are working but not on the headlight. I think I'm doing it right with Rheingold. I select LHMR and code it to the car, it turns green on next check and all errors related are cleared. Then I select STMR an code it also but its always yellow. I can turn headlights on and off no issues. Any advise how to find if the turn signal module is working or not? Dont wont to buy new one to find out its something else. Also not sure if this is related but I got this error :
05-16-2016, 03:02 PM | #4 |
Rep 1,514
I think I did. there is no problem with high/low beam etc. Do you have some doc explaining how it has to be done? I did select both ecu's , components triggering and did every item listed there. As I mentioned after that the LHM was clear of errors but STM did stay yellow. I was able to turn headlights on from the switch and they worked. Will try to open the turn signal module tonight. Hope to be bad connection or something easy to fix.
05-16-2016, 03:42 PM | #5 |
Rep 1,481
The "teach in" procedure is not under the ECU "component actuation" menu, but under Vehicle Management > Service function > Body > Lighting. The turn signal malfunction is exactly what you would get if you did not run this procedure (which, per BMW instructions, is required after a headlight replacement).
2015 Mineral Grey ///M4 6MT
05-21-2016, 09:36 AM | #9 |
Rep 1,481
Yes, it needs to be performed each time a new LED headlight is installed.
07-06-2016, 08:57 AM | #11 | |
Rep 1,481
In any case, you could try to "Calculate test plan" in Rheingold and see whether or not it suggests to run the teach in procedure again.
07-06-2016, 09:51 AM | #12 |
Rep 1,132
07-06-2016, 09:59 AM | #13 |
Rep 1,481
That is correct: the retrofit is not going to be plug-and-play. A few ECUs will have to be recoded and Rheingold will be needed to initialize the retrofitted LED headlights.
07-06-2016, 05:39 PM | #14 |
Rep 2,809
07-06-2016, 06:16 PM | #15 |
Rep 1,481
All the coding can be done in E-Sys.
07-06-2016, 07:04 PM | #16 |
Rep 2,809
07-06-2016, 07:07 PM | #17 |
Rep 1,514
It is the same as if i never did teaching. Is also teaching the only step necessary? After teaching they still have errors and deleting them doesnt clear. I have to call each ecu and ecu functions and do some test and it activates them . After that i got no errors until battery is disconnected. Calculate plan shows teaching.
07-06-2016, 07:23 PM | #18 | |
Rep 1,481
07-06-2016, 07:27 PM | #19 |
Rep 1,481
It is going to be just VO coding: replace 524 (Adaptive Xenons) with 552 (Adaptive LEDs) in the FA and then VO code FEM_BODY, KAFAS, both LHM, both TMS, ICM, VDC and REM.
07-08-2016, 08:25 PM | #20 |
Rep 1,514
Behavior was right headlight wont remember teaching / adaptation. Turn ignition off and I had to adapt again . Specifically LHMR. So after another flash and disconnecting battery it seems to work.
09-28-2016, 10:56 AM | #21 |
Plenipotentiary
2614
Rep 3,046
Stumbled across this for another reason but think I have an answer incase anyone else runs into a problem with modules after using Rheingold. It appears some tests and service jobs are not actually completing the necessary functions; Headlight Electronics especially. In addition, Service Plan Actions and Test Modules that are not supported by the Boolean plausibility checks of the available VCS OrderData are sometimes being loaded by ignoring Boolean parameters until there are no more remaining to filter or the OK to deploy conditions are met. this continues on and on. For anyone who has used the program for replacement of LED Headlamp components or to perform teach-in/alignment after coding to enable GFHB or VLD, it's worth a look at the session logs in the main program folder. Search for these keywords:
die fingers crossed bogus verbose - a typo for verbote(n) default CAS DME kein This doesn't appear to be an installation issue but a problem with the patches utilized to proceed beyond the errors associated with conflicts between the actual vehicle configuration and the saved data both on the computer and in the car itself. The default data for the chassis obtained from the backup data in other modules or a manipulated data set is applied to force the job to process or appear to. This remains until the module is triggered to boot from the still unchanged eeprom backups. For a used replacement component, that backup is no longer valid. Hopefully a few of you will check and report back. Last edited by lemetier; 09-28-2016 at 06:05 PM.. |
